Old Dec 05, 2007, 12:20 AM
sea hawk westoz
sea hawk westoz
Guest
n/a Posts
best way to solder flex shafts , and enny iders on shafts
im trying to find the best way the repar my flex shafts and .the best
thins to use .do you guys use the outer plastic tubing to stop water
cumming into the hull whyll its running as i get water in my hull from
the drive tube. also on a cat( 1meter long 26cc gas motor) with a
serface prop and should the prop be set up high or shoud it be set
low. i dont realy know where it should be ran. also if there is enny
way better to set up my boat. with a stronger drive line or moving the
motor so theres less bend in the flex shaft unit. as when i stop to
quick i get alot of water over the transum. but i dont want to move the
motor forwort to much if its not going to handle enny better. ill just
not slow down to quickly.lol...
also dose enny one think a cat at one meter long would go enny good
with a out board ar one of those sterndrive units on it. and if enny
one knows where to get ones able to be adapted .sterndrive that is for
a gas 26cc motor. or large nitro motor.
thanks... im in australia so ennyone over here with enny help would
be great or enny where realy.:cool: :cool:
sea hawk westoz
sea hawk westoz's Profile: http://www.modelpowerboat.com/forum/...hp?userid=2463
View this thread: http://www.modelpowerboat.com/forum/...read.php?t=407
Best way to solder these is? highace1 Parkflyers 10 May 03, 2005 12:59 PM
Question Best way to solder wires on Deans Ultra Conn. Orion_V Power Systems 24 May 07, 2004 08:54 PM
Best way to install pinon on MPjet GB splatman Power Systems 7 Aug 21, 2003 05:28 PM
best way to put elevons on a wng? thor4944 Electric Plane Talk 2 Jun 28, 2003 11:30 PM
Best way to put pinion on EDF spark363 Parkflyers 1 Mar 18, 2003 08:29 PM
