This thread is privately moderated by rc808, who may elect to delete unwanted replies.
Old Dec 04, 2007, 09:20 PM
rc808 is offline
Find More Posts by rc808
Honolulu, Hawaii
Joined Apr 2007
Starting the Slofly
It'll be hard to exceed the Superflea but i hear good things about the Sofly 28. Just got the epp cut out and the spars installed. Hopefully finish her up this weekend.
rc808 is offline Find More Posts by rc808
Old Dec 04, 2007, 10:17 PM
zillacapt is offline
Find More Posts by zillacapt
Plane Addiction
United States, AZ, Scottsdale
Joined Apr 2007
You will really like this plane. Is that a 3000 motor? it will do much better with a 1500Kv motor and a 800Mah 2cell batt. Mine flys like a dream. I took a carbon fiber flat piece and glued it to the bottom and it wont tear the foam on landing.
zillacapt is offline Find More Posts by zillacapt
Old Dec 04, 2007, 10:53 PM
rc808 is offline
Honolulu, Hawaii
Joined Apr 2007
It's the 1500kv motor. Good idea with the carbon strip. How much wind can these handle?
Old Dec 05, 2007, 06:42 AM
jim e is offline
Find More Posts by jim e
Closed Account
Joined Sep 2005
carbon reinforcement
Hello- i have two slofly 32's (foam only) and would like to know where u install the carbon rods or tubes and flat strips and what size(s) u are using? jim
jim e is offline Find More Posts by jim e
Old Dec 05, 2007, 09:58 PM
rc808 is offline
Honolulu, Hawaii
Joined Apr 2007
i had 2 .125 carbon tubes. 1 on the middle of the underside of the wing and 1 you can see in the photo on the lower part of the fuselage. The tubes were big enough that i'm only going to use 1 on each side. Most builds i've seen have 1 on each side but they're .060 or so. Hope that helps.
Old Dec 06, 2007, 06:59 AM
jim e is offline
Closed Account
Joined Sep 2005
Appreciate
Your response. If i understand correctly u are using one tube in the bottom half of fuse, and one tube in the wing-perhaps around the center of gravity. Goodwinds kites has the .125 tubes in 32"- perfect for the wing (32"). Will also get a few strips when i finally put in an order. Thanks for the help, jim
Old Dec 15, 2007, 08:53 PM
rc808 is offline
Honolulu, Hawaii
Joined Apr 2007
Got everything semi assembled. Installed control rods and glued the tail. I'll get pictures of that shortly.
