Go Back   RC Groups > Aircraft - Electric - Airplanes > Foamies (Scratchbuilt)
Old Dec 01, 2007, 11:14 PM   #1
Try, how hard can it be?
Rad Racer's Avatar
BluCor - Nakajima Ki-43 Hayabusa "Oscar"....profile scale,built from 3-view drawings
I have always liked the profile of the Nakajima Hayabusa, so I decided to build a profile scale from 3-view drawings I found online.
This build log will show you the steps I used to complete this airplane.....enjoy.
Step one:
convert and scale the 3-view drawing.
  • Name: ki43 3-view.jpg
Description: 3-view drawing found online. 3-view drawing found online. 110.0 KB · Views: 341
  • Name: DSCN3590.jpg
Description: Final CAD plans.
The 3-view JPG was coverted to raster graphics and pulled into my CAD system. I keeped only the necessary lines (plane outline), all other lines were deleted. Final CAD plans. The 3-view JPG was coverted to raster graphics and pulled into my CAD system. I keeped only the necessary lines (plane outline), all other lines were deleted. 54.4 KB · Views: 525
Rad Racer is offline Find More Posts by Rad Racer   Reply With Quote
Old Dec 01, 2007, 11:21 PM   #2
Rad Racer's Avatar
My first build.
This is my first build. The test flights went ok, but found it needed a few tweeks before it is ready for prime time
  • Name: Haysbusa.jpg
Description: First build of this model. First build of this model. 110.6 KB · Views: 370
  • Name: Hayabusa.jpg
Old Dec 01, 2007, 11:33 PM   #3
Rad Racer's Avatar
The plans were scaled for a 24" wingspan. The plans were printed using a 60" inkjet plotter.
I cut out the plans with a Exacto blade. The plan templates are traced onto the BluCor foam using a Sharpie pen.....the residual ink is easily removed with rubbing alcohol.
BluCor cuts easily with a "fresh" exacto blade.
  • Name: DSCN3576.jpg
Description: Plans were scaled for a 24" wingspan. Plans were scaled for a 24" wingspan. 112.3 KB · Views: 256
  • Name: DSCN3578.jpg
Description: All parts have been cut. All parts have been cut. 115.0 KB · Views: 282
Old Dec 01, 2007, 11:51 PM   #4
Rad Racer's Avatar
Fuselage assembly is easy and quick. My design uses a lock/alignment tab system that makes for a straight/strong fuselage.
I have found "Gorilla Glue" works perfect with BluCor. I use a light Coat of Gorilla glue on all the joining surfaces then simple slide the fuse parts together for assembly.
Although this glue is meant to have the surfaces wetted before the glue is applied....I discovered if you do not wet the surfaces the glue still works, but you don't get so much foaming from the joint on to other surfaces.
I really believe Gorilla glue will replace epoxy.....it's that good!
  • Name: DSCN3584.jpg
Description: Fuselage assemble is easy and quick Fuselage assemble is easy and quick 109.2 KB · Views: 302
  • Name: DSCN3585.jpg
Description: Notice the alignment tabs or keys, makes for a straight/strong fuselage. Notice the alignment tabs or keys, makes for a straight/strong fuselage. 78.4 KB · Views: 214
  • Name: DSCN3586.jpg
Description: I use the same locking tabs in the back. I use the same locking tabs in the back. 74.2 KB · Views: 238
  • Name: DSCN3587.jpg
Old Dec 02, 2007, 09:06 AM   #5
Trailer Parts Guy
Xanadu's Avatar
The pros and cons of Gorillia glue is the it foams, and it foams.
Good to expand and foam up a bit to get all those hollow spots, but bad to foam since it leaks out all the edges too.
One way around leaking out is to put painters tape over the seam line, stops the foaming out.
Xanadu is offline Find More Posts by Xanadu   Reply With Quote
Old Dec 02, 2007, 09:17 AM   #6
Rad Racer's Avatar
Good hint....I will keep that in mind as I complete this build.
thanks
Wayne
Old Dec 02, 2007, 09:44 AM   #7
Rad Racer's Avatar
The airfoil shape is added to the wing with the following technique....it's really slick.
I first saw this method used by the guys at Rabidmodels.com. To my knowledge, they use this method of airfoil forming on all their foamy warbirds. Checkout their website, they have some really cool warplanes.
This process gives the wing a natural curve or airfoil shape, you also get tip washout if the fold lines are layed out correctly.
I found the sharp edge of a board works great for creating these creases, it does not cut into the plastic skin.
  • Name: Crease lines.jpg
Description: The blue dashed lines are crease lines.  This layout provides for natural washout at the tip. The blue dashed lines are crease lines. This layout provides for natural washout at the tip. 115.0 KB · Views: 251
  • Name: DSCN3580.jpg
Description: I use the shape edge of a cut board for creating the crease.   Simply press the board edge into the foam. Please note: you do not want to cut the plastic skin...it gives the wing much strength. I use the shape edge of a cut board for creating the crease. Simply press the board edge into the foam. Please note: you do not want to cut the plastic skin...it gives the wing much strength. 117.2 KB · Views: 308
  • Name: DSCN3581.jpg
Description: Pressing the crease lines into the foam Pressing the crease lines into the foam 111.0 KB · Views: 261
Old Dec 02, 2007, 10:00 AM   #8
-+- PhlatBoyz -+-
kram242's Avatar
Nice build, do you have the vector version of the plans to share?
Mark
kram242 is offline Find More Posts by kram242   Reply With Quote
Old Dec 02, 2007, 10:11 AM   #9
Rad Racer's Avatar
Here you can see the natural arc or airfoil shape created by creasing the under side of the wing.
The wing slides nicely into the ClarkY cutout in the fuselage.
During the test flights of the prototype, I found the plane wanted to climb excessively, in-fact I needed a fair amount of down elevator just to maintain level flight.
At first I thought my CG was off, but found even shifting and adding nose weight really didn't help. My next thought was that my thrust line was postive...that to checked out fine and wasn't the problem.
I went back to my plans and looked at the incidence angle of the wing....it was 3 deg., exactly where it should be. I started to wonder about the airfoil and where it started to generate lift. After some quick analysis with Profi Pro, I discovered the problem.....a ClarkY foil starts generating lift at -3 degrees. My original design added +3 degrees of incidence, so the wing effectively had 6 deg of incidence, too much for this model.
  • Name: DSCN3588.jpg
Description: Here you can see the natural airfoil shape created by creasing the bottom surface of the wing. Here you can see the natural airfoil shape created by creasing the bottom surface of the wing. 66.7 KB · Views: 249
  • Name: DSCN3589.jpg
Description: The wing slides nicely into the cutout in the fuselage.  I used a ClarkY airfoil in this design....judging from the test flights of the prototype, it seems like a good choice. The wing slides nicely into the cutout in the fuselage. I used a ClarkY airfoil in this design....judging from the test flights of the prototype, it seems like a good choice. 63.8 KB · Views: 295
Old Dec 02, 2007, 10:29 AM   #10
Rad Racer's Avatar
Mark
Thankyou. I will share the plans, but I am not sure of the best format.
I typically like to use DXF files, but see many of the plans on RC Groups are in paged PDF format so people can print them on their home printer.
Not sure how these "paged" PDF files are made, so if someone wants to volunteer to make the PDF file...I will gladly supply the design in DXF format.
Old Dec 02, 2007, 01:32 PM   #11
Rad Racer's Avatar
How is this for a profile match, almost looks like the real thing (well, accept for the tail in the snow bank thing)
  • Name: DSCN3595.JPG
Old Dec 02, 2007, 07:34 PM   #12
Rad Racer's Avatar
These photo's show the wing assembly.
Apply plenty of Gorilla glue to the wing ends and fuse cutout. Pins are needed to keep everything square and held together until the glue dries.
  • Name: DSCN3610.jpg
Description: Draw line 1/8" in from the edge. This line is used to make sure each wing is inserted halfway into the fuselage. (Blucor is 1/4" thick) Draw line 1/8" in from the edge. This line is used to make sure each wing is inserted halfway into the fuselage. (Blucor is 1/4" thick) 59.8 KB · Views: 271
  • Name: DSCN3609.jpg
Description: 1.53" dehedral blocks installed. 1.53" dehedral blocks installed. 118.7 KB · Views: 286
  • Name: DSCN3611.jpg
Description: wing inserted into fuselage. wing inserted into fuselage. 59.0 KB · Views: 242
  • Name: DSCN3613.jpg
Description: Apply plenty of Gorilla glue to the wing ends and fuse cutout.  Pins are needed to keep everything square and held together until the glue dries.  Besure to sight down the fuse....make sure tail is square with wing. Apply plenty of Gorilla glue to the wing ends and fuse cutout. Pins are needed to keep everything square and held together until the glue dries. Besure to sight down the fuse....make sure tail is square with wing. 64.6 KB · Views: 291
Old Dec 02, 2007, 07:38 PM   #13
Rad Racer's Avatar
Enough for today....time to let the glue setup.
  • Name: DSCN3614.jpg
Description: Ok, the major assembly is complete.  Be sure to let the glue dry before moving assembly. Ok, the major assembly is complete. Be sure to let the glue dry before moving assembly. 107.0 KB · Views: 322
  • Name: DSCN3612.jpg
Old Dec 02, 2007, 08:18 PM   #14
Rad Racer's Avatar
Hayabusa plans
Here are the plans for the Hayabusa.
Old Dec 02, 2007, 08:46 PM   #15
kdahlhaus's Avatar
Looks great. Another good profile foamie - don't forget to add it to the list of plans at the start of this forum.
kdahlhaus is online now Find More Posts by kdahlhaus   Reply With Quote
Discussion Warbirdkits.com Nakajima Ki-84-i Hayabusa "Oscar" St. Martin Scale Electric Planes 69 Jun 12, 2006 09:35 AM
Alfa Nakajima ki-84a Hayate CUBANO8 Parkflyers 24 Jun 26, 2005 08:04 PM
Hobby Lobby Nakajima KI-84a, Anybody flying One? WhiteCloud Parkflyers 11 Jan 15, 2005 08:05 PM
Royal Thai Airforce KI-43 wespe Scale Electric Planes 5 Jan 13, 2004 04:54 PM
Nakajima Ki-44 "Tojo" LawnDart Scale Electric Planes 1 Nov 02, 2001 06:50 PM
11
