Old Nov 30, 2007, 03:08 PM
newtohelis is offline
Find More Posts by newtohelis
Joined Dec 2006
my first glider need help with tips on how to set it up
i ordered a multiplex easy glider electric but im wondering if i should just step up to brushless right off the bat are there any inexpensive
motor/esc s that will work well without a lot of mods to install
i am planning on using a tp 2100 3s lipo in it
any suggestiond would be great im planning on flying the glider on a slope
and in the park once in a while
thanks for any info guys
newtohelis
newtohelis is offline Find More Posts by newtohelis
Old Nov 30, 2007, 05:43 PM
planeaddiction is offline
Find More Posts by planeaddiction
United States, CA, Aptos
Joined Oct 2007
I have the EGE. I bought the kit not the RTF. The RTF comes with the fuse halves glued together so doing the mods is harder. I am using the Multiplex 480 4G motor with the 3.3-1 gearbox, a Thunderbird 54 amp ESC and a Thunderpower 2100 3cell lipo. I had to cut the Bat. compartment out a little for the pack to fit. I cut some of the nose off and mounted a fiberglass firewall. Even with the geared brushless I still had to add some weight to the tail to get the propper CG. The plane will climb vertical till it's out of sight but still slows down to a crawl.
planeaddiction is offline Find More Posts by planeaddiction
Old Dec 15, 2007, 02:06 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
I used this motor, KM0203800, in an e-glider as a direct replacement for a speed 400 that was attached to a gearbox.
http://ecsvr.com/abm/ShopDisplayproducts.asp?Search=Yes
On that plane with the stock prop the motor is running at 130 watts. I think the motor is good up to about 160 watts. That should give you a good climb on your EG.
I am using this ESC - Electronic Speed Control 25A KC2030A01
It is not what I am using in my EG, but it is a low cost combo that will probably fit.
You may need a gear puller to get the gear off the stock speed 400 motor so you can use it on this one.
aeajr is offline Find More Posts by aeajr
Discussion painted my first body, need help with rider columbo Motorcycles 11 Dec 31, 2006 01:14 AM
My First Lipo, Need Help, Whats with the two wires? Photo Attached for reference ontheweekend Batteries and Chargers 8 Sep 10, 2004 08:47 PM
Need help with upgrades on my new Dragonfly tekforce Micro Helis 18 Feb 08, 2004 03:25 PM
narrowed down choices for my first HLG! Need help selecting. MichaelConnally Hand Launch 19 Sep 08, 2002 03:40 PM
Need help with geared Mag. Mayhem set up slowflyer Power Systems 4 Aug 03, 2001 10:58 PM
