Old Nov 30, 2007, 04:02 AM
KaanX is offline
Find More Posts by KaanX
Türkiye
Joined Jun 2007
Tips on how to remove stripped hex screws
As the topic title says.
It happened to me
I stripped the screw on my metal tail servo mount of t-rex trying to overtighten it
I tried to grab them by pliers, no luck. The heads are too small and round.
Does somebody have any tips on remove those screws without destroying the mounts?
KaanX is offline Find More Posts by KaanX
Old Nov 30, 2007, 04:19 AM
greenh0rn is offline
Find More Posts by greenh0rn
Joined Aug 2006
It happened to me
usually i'd cut a slot on top of the screw using my dremel tool and open it with a flat tip screw driver.
greenh0rn is offline Find More Posts by greenh0rn
Old Nov 30, 2007, 04:33 AM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
Sometimes using a fresh hex tip helps. use a new allen key or cut the tip to have fresh corners. Also in these helis, sometimes manufacturer uses a mix of 1.5mm and 1/16" hex. The 1/16" is bigger. Using 1.5mm on these will strip the bolt.
Gino CP is offline Find More Posts by Gino CP
Old Nov 30, 2007, 04:52 AM
KaanX is offline
Türkiye
Joined Jun 2007
Thanks, I'll try both. Maybe heating it up will let the loctite go, helping the screw turn.
Old Nov 30, 2007, 07:46 AM
Nick J is offline
Find More Posts by Nick J
Redding, Ca
Joined Nov 2005
I have the same issue, i am going to try and grind a flat spot right now..
Nick J is offline Find More Posts by Nick J
Old Nov 30, 2007, 08:40 AM
Lota Fun R is offline
Find More Posts by Lota Fun R
Joined Jun 2007
Clean bolt head to remove any grease/oil, take a small amount of JB weld or thick CA and glue to head of bolt. this tip is in the RCheli mag, Jan edition.
Lota Fun R is offline Find More Posts by Lota Fun R
Old Nov 30, 2007, 08:44 AM
Joined Jun 2007
If that doesn't work I would suggest using some soldering flux and solder the wrench on the bolt. This does two things, one, adheres wrench to bolt, two, it heats up the bolt only and what this does is "shift the clevis plates", the clevis plates are the threads. Let cool slightly before trying to remove.
Old Nov 30, 2007, 09:00 AM
hurleybt is offline
Find More Posts by hurleybt
United States, GA, Woodstock
Joined Mar 2007
great ideas lota...
hurleybt is offline Find More Posts by hurleybt
Old Nov 30, 2007, 06:41 PM
BowerR64 is offline
Find More Posts by BowerR64
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
Ive had a few instances where a flat head would fit into the head and turn it. Ive used a flat head on a few torx type screws before also.
You have to find the right tip that fits in tight, having alot of screws drivers helps.
Cutting a slot in the head is probobly the best as long as you can get the cutting wheel down into the head.
They sell easy outs also, its like a reverse drill bit that digs in when you spin it counter clockwise. We have a few of those around here
BowerR64 is offline Find More Posts by BowerR64
Old Nov 30, 2007, 06:48 PM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
Are there easy outs that small?
Old Nov 30, 2007, 07:01 PM
BowerR64 is offline
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
might not be but in the future some one on here may run into a problem similar with a larger size.
I may cut a slot into the nub that broke off in the nut on my king V2 spindle.
trid the Gino CP "i bend mine back" trick and just my luck it snapped. GASP!
Old Nov 30, 2007, 07:30 PM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
You bend it without the nut. LOL. It is thinner around the threads.
Old Nov 30, 2007, 07:36 PM
rwp is offline
rwp
Find More Posts by rwp
rwp
rwp
rwp's Avatar
Joined Nov 2003
Craftsman has a SCREW-OUT set, part #952157 that works well. Directions say to insert the tool in a drill but I have backed screws out without using a drill. Just put the extractor in a handle and carefully back the screw out. My set came with 7 sizes of extractors all the way from large to very small.
rwp is offline Find More Posts by rwp
Old Nov 30, 2007, 08:12 PM
BowerR64 is offline
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
oh great, NOW you tell me.... lol
I couldnt get any leverage so i put the nut on to use that tool to pry it with.
Ive bent it out a few times before it broke though
Old Nov 30, 2007, 08:31 PM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
Discussion Tips on How to remove and replace an outrunner motor shaft Radio Rookie Power Systems 0 Aug 28, 2007 09:51 PM
Help! How to remove a stripped set screw head from TTn? SlyRCr Motorcycles 19 Jul 26, 2006 10:18 PM
How to get stripped set screws from AXI LenBFP Power Systems 4 Jan 08, 2005 07:40 PM
Question How to remove a stripped setscrew (Eolo) Orion_V Electric Heli Talk 13 Apr 12, 2004 04:24 PM
Got my Soarstar, any tips on how to build? f2racer Foamies (Kits) 2 Sep 06, 2001 10:56 PM
