Old Nov 29, 2007, 01:18 PM
salmas is offline
Find More Posts by salmas
Joined Nov 2007
Question
HELP Please!!.....yes another newbie!!
HELP Please.........!!
Ok so there i am with new Walkere 22E fresh out of the box.....
Must learn to fly on the simulator first....
Install the FMS software on the laptop and it runs up fine
Put new batteries in the transmitter plug in the cable to the back then the other end into the laptop........NOTHING....
Tried playing with the settings on tehhe laptop but with no joy..
The cable i have has a D type serial connector (9-pin)
Now i have been searching through the forum and there is lots of talk of new cables, rewiring the cable, using the sound card?, serial to USB converter etc.etc.
So can anyone help me make sense of it all?
What software/driver do i need to get it up and running?
Or do i need some new hardware/cable modification?
You'd think it would come with suitable instructions......alas no so hopefully you good people out there can help...before i decide sod it and fly the chopper with out learning on a sim!!!
Apologise if i'm asking the same old questions...just getting very confused!! (which is very easily done!)
Thanks in advance for any help you can give me!
Cheers
Steven
salmas is offline Find More Posts by salmas
Old Nov 29, 2007, 01:21 PM
p4ddy is offline
Find More Posts by p4ddy
RC4Life not just 4 xmas
p4ddy's Avatar
southampton uk
Joined Jun 2006
Have you downloaded ppjoy ?
p4ddy is offline Find More Posts by p4ddy
Old Nov 29, 2007, 02:03 PM
Starcraft-ix is offline
Find More Posts by Starcraft-ix
Starcraft-ix's Avatar
Beaverton, OR
Joined Jun 2006
I screwed around with ppjoy and everything else trying to get a serial cable to work. I even bought a serial to USB converter, but to no avail. I finally just bought a USB calbe on ebay and it works great. The underlying problem, from the way I understand it, is that XP doesn't like serial ports.
Starcraft-ix is offline Find More Posts by Starcraft-ix
Old Nov 29, 2007, 02:19 PM
p4ddy is offline
p4ddy's Avatar
southampton uk
Joined Jun 2006
Yeah the proper cable is cheap & saves all the trouble
Old Nov 29, 2007, 06:49 PM
ra99gt is offline
Find More Posts by ra99gt
Joined Aug 2006
i just used a gamepad with dual analog joysticks
ra99gt is offline Find More Posts by ra99gt
Old Nov 29, 2007, 06:54 PM
claves_10 is offline
Find More Posts by claves_10
Northern Spain
Joined Nov 2007
I had similar problems when I started with my honey bee CP2. Then I found this cable on Ebay and works like a charm for me. Perfect for clearview and others. Esky TX or Futaba.
http://cgi.ebay.com/FMS-Simulator-US...QQcmdZViewItem
claves_10 is offline Find More Posts by claves_10
Old Nov 29, 2007, 08:01 PM
HeliSmith is offline
Find More Posts by HeliSmith
=>] Smack 3D Head [<=
HeliSmith's Avatar
United States, CA, Chico
Joined Feb 2007
Take the back off that TX and make sure there are wires running to the DPIN connector. Some of them have none so I have heard. Walkera
HeliSmith is offline Find More Posts by HeliSmith
Old Nov 30, 2007, 01:32 AM
Northern Spain
Joined Nov 2007
I am sure that the Tx will have wires connected to the "DPIN". No need to open it
Salmas does your cable connect to the computer via pararell or USB???
Parerell gave lots of trouble. Useless, with USB NONE AT ALL
Give us more info about the cable you are using. Any links of where you bought it??
Old Nov 30, 2007, 03:26 PM
salmas is offline
Joined Nov 2007
The cable is a serial cable so not USB or Parralel and it sounds like my problem is the use of serial cable with XP. the game pad is a good idea although i would like to learn with the actual Tx i will be using....probably make no difference at all!!
Looks like just buying a USB cable is the way to go although i will look at the PPJOY???
I'll let you know how i get on
Thanks for the advice guys will get back to you with the next set of question once i have trashed the heli after first flight.......!!!!! )
Steven
Old Nov 30, 2007, 04:58 PM
HeliSmith's Avatar
Joined Feb 2007
Yeah true I guess I don't know what I am taling about.
Anyway here is the cable I made for a Walkera #4-1. Has some basics on PPJOY.
http://www.helismith.com/index_files/simcable.htm
Old Dec 01, 2007, 08:49 AM
salmas is offline
Joined Nov 2007
HeliSmith,
Looks like i have the cable you detail on your website.
So will PPJOY the get the controller working through the serial port on my laptop? (XP)
Did it work well for you?
Old Dec 01, 2007, 11:10 AM
HeliSmith's Avatar
Joined Feb 2007
Yes but mine is a 4#1 and I think you have a 22e. It's worth a try though.
Question HELP Please.......yes another newbie!! salmas Electric Heli Talk 2 Nov 28, 2007 01:12 PM
Help with setup (Another Newbie) OzzieFlyer Micro Helis 5 Apr 22, 2004 04:57 PM
Newbie needs some help please G1K Foamies (Kits) 6 Dec 08, 2002 07:44 PM
Eager Newbie Needs Help - Please! pfchico Parkflyers 11 Nov 25, 2001 09:16 AM
Newbie Help Please!!! Jonathan Beginner Training Area (Aircraft-Electric) 2 Apr 23, 2001 08:30 PM
