Old Nov 28, 2007, 02:03 PM
Vyceroy is offline
Find More Posts by Vyceroy
G G Ghost Pirates !!!
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Guillows Aeronca Champ and Hellcat..
After a 20 year lull in Balsa building .. i decided to finally build a Kit that a Late friend (RIP Jack) gave me ..
The last balsa plane i built was a Goldberg Eaglet at least 20 years ago .. I figured it was time to get back to it ..
First off i could see the Guillows kit has not improved one little bit over the years (Really makes me appreciate the laser cut kits) .. Why would anyone Die cut anymore?? I would think printed wood would be better ..
Here are a few pics of the RTC plane .. I am going with a Little silver bullet Outrunner and 3-4 gram servos..
My big question now is what do you guys think i should cover it with?? I can use tissue .. i can use silkspan .. or i can use Econokote Ultrakote or another lite Iron on film ..
Any suggestions would be helpful ..
Vyceroy is offline Find More Posts by Vyceroy
Old Nov 28, 2007, 02:05 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
More pics ..
Old Nov 28, 2007, 02:40 PM
HanksGB is offline
Find More Posts by HanksGB
confused poet
HanksGB's Avatar
USA, CA, Orange
Joined Feb 2004
Vyceroy,
I covered mine with so lite. I find it to be the easiest to work with on models this small.
Here is a link to my post build thread.
Henry
http://www.rcgroups.com/forums/showthread.php?t=609406
HanksGB is offline Find More Posts by HanksGB
Old Nov 28, 2007, 03:36 PM
Bob Benjamin is offline
Find More Posts by Bob Benjamin
Olympia, WA USA
Joined May 2001
covering your Champ
IMHO...If you already know how to cover with silkspan and/or tissue, I can't imagine why you'd want to step down to an iron-on material. Personally, I'd use lightweight (OO) silkspan, dye it with RIT for your main color, and finish with non-tautening nitrate clear dope. Trim could be more dyed silkspan, decals, or lightly airbrushed acrylic as per those plastic models.
Bob Benjamin
Bob Benjamin is offline Find More Posts by Bob Benjamin
Old Nov 28, 2007, 03:38 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
I think that Solite is similar to Microlite which is another popular light weight iron on covering, If you don't mind more transparency you might want to use Lightspan AKA Corverlite. If you want to duplicate the typical Champ two tone yellow and orange fuselage color scheme, things get trickier. Probably the easiest way is to cover the fuselage in yellow iron-on , mask and airbrush the orange over the yellow. You could also cover the fuselage with yellow Microlite and very carefully apply orange Microlite covering over the yellow. If you are trying to keep the model as light as possible, a single color Microlite or Lightspan type covering is proabably best. To get a small Guillows model to fly well, you will need to use a very light receiver and servos ( 3.6 gram) and light power system ( See RC Hot Deals ) for a tiny brushless outrunner and speed control that will spin a 5" prop on a 400mah 2-cell lipo pack. You may consider using a 12 mm "inrunner" brushless motor, like the Faigao and a direct drive GWS prop. Take your time deciding and get more advice as needed. Good luck!
E-Challenged is offline Find More Posts by E-Challenged
Old Nov 28, 2007, 04:05 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Bob, dope is my biggest problem tissue covering.. as a kid i always used an Elmers/water mix on my tissue .. but i cant honestly tell you how heavy it was .. i just prefer not to use the Dope if possible ..
Old Nov 28, 2007, 05:34 PM
NCNeal is offline
Find More Posts by NCNeal
Foamy Builder 167
NCNeal's Avatar
United States, NC, Mooresville
Joined Oct 2007
Hi Ron.
I can't get an idea of the size. Can you post some pictures sith something for reference? What do you think the end specs will be? Wing span, Length, weight?
NCNeal is offline Find More Posts by NCNeal
Old Nov 28, 2007, 05:38 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
wingspan Neal is 24 inches i will try to put a pic up later of it with something for scale ..
Old Nov 28, 2007, 06:31 PM
GeoffinIN is offline
Find More Posts by GeoffinIN
Two left thumbs
Muncie, IN
Joined Sep 2006
The Champ is a cute little bugger! I noticed that in one of the face-on photos it appears that the two cabin sides aren't parallel at the wing root. If that's not an optical illusion, be sure to square it before too much more work gets done or it's gonna handle a might funny!
Since I have a terrible time with these super-light plastic coverings, I plan to go the silkspan/dope route on my present build. Yeah, I'm old-fashioned, but as the saying goes, I like what I know and I know what I like!
I'll be following this to see where all the innards go.
BTW, is the Bellanca Junior still in the air museum at the Charlotte airport?
Geoff
GeoffinIN is offline Find More Posts by GeoffinIN
Old Nov 28, 2007, 07:19 PM
Konrad is offline
Find More Posts by Konrad
Everett Wa.
Joined Jun 2001
Did you cover the Eaglet with film? If so the Champ would be a doable in Solite, Nelson Film or Coverite's Microlite. As you can see film offer many advantages over tissue and dope. Take a look at the tail fillet on HanksBG's Champ.
I use the property of film to assemble and cover at the same time. I like to cover the sides of the fuselage and add side windows prior to gluing the wings on. I also cover the bottom of the wing as the struts interfere with the covering. I can glue the strut and adjust dihedral and washout (twist) through the top of the wing as there isn't any covering on the top surface. After all is dried I cover the top of the wing and the rest of the ship. Yes; the side are not parallel in any plane (geometric term) by design.
I like die crushed parts as I don't need to sand off the Laser Slash marks. With dope or film covering the burns look like Crap! Most of the damage from the die crushed part can be repaired by soaking the crushed wood with water. This allows the crushed wood to expand back to size. this plus a good sanding on the back side of the sheet allow the parts to fall away almost as fast a as Laser cut parts.
The Higley's book Tom's Techniques taught me all I know about film covering.
http://www.hobbylinc.com/htm/hig/higbok004.htm
Do look at these threads :
http://www.rcgroups.com/forums/showthread.php?t=52764
http://www.rcgroups.com/forums/showthread.php?t=656609
http://www.rcgroups.com/forums/showthread.php?t=374028
Konrad
Konrad is offline Find More Posts by Konrad
Old Nov 28, 2007, 07:41 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Geoff i dont think its there anymore .. now they have a replica of one of the Wright Flyers ..
Konrad ..thanks for the links and info .. i will check them out tonight .. i have some aerofilm for this size model .. well actually i got it by accident .. wife bought wrong thing .. so i will use this film to make the Scheme pictured ..
Old Nov 28, 2007, 08:00 PM
Konrad is offline
Everett Wa.
Joined Jun 2001
Be warned silver (gray) is the hardest color to cover with be it tissue or film.
Tell the wife for me; That was not a mistake.
I now only use dope and tissue for my Peanut planes 13 inch wing span rubber powered ships. These new ultra thin coverings have made Dope obsolete.
Now if you want the best and worst of both world, dope and film covering you might want to look at this covering Litespan. It is a plasticized tissue, I love it for these 30 inch or smaller ships
All the best,
Konrad
Old Nov 28, 2007, 09:50 PM
UBILDIT is offline
Find More Posts by UBILDIT
Victoria Super Mortem
UBILDIT's Avatar
BIRMINGHAM ALABAMA
Joined Jan 2006
Smokin cool..
Looking good there Julio!.. Did'nt know you had it in ya. I say cover it with 3mm bluecore then paint it with sharpie markers.. To heck with all this film and tissue stuff... oh and seal it all with hot glue, oh and use bottle caps for the wheels and the bottom of a 20 oz. coke bottle for the cowling.... Perfect eh??
Bo
UBILDIT is offline Find More Posts by UBILDIT
Old Nov 28, 2007, 10:15 PM
AmpAce is offline
Find More Posts by AmpAce
AmpAce's Avatar
North by Northwest
Joined Nov 2003
Vyceroy,
Nice looking build of the little "Airknocker"!
As for covering, I would also vote for the Nelson "Litefilm", "Solite", or Twentyfirst Century "Microlite". They are all the same thing. They are quite easy to use after a little practice. I'm an "old guy" with limited dexterity in my hands, and even I can wrap up an airframe with it, so I'm sure you will be able to do it!
Another product you might try is "Doculam", ducument laminating film, if you can find it. I had to buy two 500 foot rolls to get it. Personally, I don't like it very well, so I sold one roll, but still have most of the other. It is clear, and is about as light as the abovementioned films, has heat activated adhesive on the back, and is paintable, which the above light films are not, for practical purposes.
There is a long thread in this forum about it, called "Doculam Discoveries". I'm sure you can easily find it, or do a search.
I would definitely advise against using Ultracote or Econocote. They are much too heavy for this size of light weight model, and the strength of the shrinkage would probably damage the framework of your plane.
Best of luck with the little Champ!
AmpAce
AmpAce is offline Find More Posts by AmpAce
Old Nov 28, 2007, 10:30 PM
Bill Covert is offline
Find More Posts by Bill Covert
Bill Covert's Avatar
Grove City, PA
Joined Sep 2007
24" should do real well with this plane. I built the Cessna 150 and cheated by adding 1/2", to make 20.5". Flies fine at 6.5oz. Figured I'd blast the "that's too heavy types" out of the way for you.
Recently put a little $15 Aoxing outrunner in it, that mounts perfectly, versus the 12mm DD Feigao that was thrown in it originally.
The plane has Microlite (like Solite) on the wings and tail, but the fuse is 1/32" light balsa sheeted with Econokote. No gain in having to add paint weight over Solite on sheeted balsa, since it is translucent and shows the wood underneath.
The Microlite can be painted, but holds paint like crap, and has to be painted slowly. It tends to loosten it, and I carefully reshrink it under a sunlamp.
Still a nice covering over foamies for lightweight, where you have to cover it with some paint to look like anything.
Moot point for builders, but on these separate panel wings, attention has to be paid to matching incidences. I had to cut and remount a panel, since the plane was a sidewinder at first, with a degree of mismatch in incidence.
Bill Covert is offline Find More Posts by Bill Covert
Guillows 24" Aeronca Champ looks like it was made by a CHIMP! nhorianopoulos Scale Kit/Scratch Built 19 Mar 21, 2015 03:46 AM
Woohoo! Guillows Aeronca Champ Flies! ZRX Doug Parkflyers 18 Sep 24, 2003 07:31 PM
Aeronca Champ plans by Vintage R/C Any good David Pentland Scale Kit/Scratch Built 0 Sep 25, 2002 01:42 AM
Scale 24" Aeronca Champ freeflyer is HEAVY! nhorianopoulos Scale Kit/Scratch Built 2 Aug 07, 2002 11:52 PM
guillows 24" aeronca champ rubber to electric conversion davidbogart Scale Kit/Scratch Built 9 May 28, 2002 07:52 AM
