Old Nov 28, 2007, 04:37 AM
hadihf is offline
Find More Posts by hadihf
Joined Dec 2003
Imax B6 temp sense probe
Hi,
Anybody tried diy B6 temp. probe? I think LM335 should work.
Regards
hadihf is offline Find More Posts by hadihf
Old Feb 04, 2008, 01:21 PM
serioussam is offline
Find More Posts by serioussam
Registered abUser
serioussam's Avatar
Queensland, Australia
Anyone ?!
I think it's either the LM335, or possibly the LM35.
I've got an LM35 on order with a bunch of other stuff, so I'll give it a try when I get it. If it works I'll let you know.
Sam.
serioussam is offline Find More Posts by serioussam
Old Mar 19, 2008, 08:30 AM
Registered abUser
serioussam's Avatar
IMAX B6 Temperature Sensor -> LM35
Just tested the LM35 (not LM335) and it works well. Wiring diagram attached.
Old Mar 24, 2008, 08:07 AM
lyclyc is offline
Find More Posts by lyclyc
Pirouetting flip master
Malaysia
Joined Jul 2007
how much is the LM35?
i bought for my estation BC6 for 10USD...
think i'm stupid...
lyclyc is offline Find More Posts by lyclyc
Old Mar 28, 2008, 04:34 AM
Registered abUser
serioussam's Avatar
LM35 should be about 2USD I think. Plus cost of plug.
Old Mar 29, 2008, 05:13 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
FYI here's an actual E-Station temperature probe with the shrinkwrap removed. Same chip, same connections...
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Mar 30, 2008, 12:05 AM
Registered abUser
serioussam's Avatar
Thanks for the confirmation Bruce.
Old May 21, 2008, 02:13 PM
natterjak is offline
Find More Posts by natterjak
Asks too many questions
natterjak's Avatar
Berkshire, UK
Joined Nov 2005
I know this is a stupid question, but please humour me. What is the purpose of a temp sensor on a charger like this? Are you supposed to position the temp sensor on the lipo pack so the charger terminates the charge when the pack gets too hot, or is it about sensing the ambient temperature and varying the charge voltage as a result?
natterjak is offline Find More Posts by natterjak
Old May 21, 2008, 03:34 PM
bruce_c is offline
Find More Posts by bruce_c
Glasgow, Great Britain (UK)
Joined Sep 2004
its normally used when charching NIMH/NICD batteries which heat up towards the end of the charge.
When charging at a high rate they can get really hot. Charger can be set to terminate charge if temp exceeds a preset.
In some cases (hotliners spring to mind) some people keep charging untill the pack hits a certain temp (as high as 80C sometimes, if remember rightly) - then immediately use the hot pack (apparently give better output on launch or something)
bruce_c is offline Find More Posts by bruce_c
Old May 22, 2008, 05:19 AM
natterjak's Avatar
Berkshire, UK
Joined Nov 2005
So it's not to do with terminating a lipo charge before 4.2V / cell if you're going to use the cells in a cold environment?
Old Sep 12, 2008, 09:16 PM
sneasle is offline
Find More Posts by sneasle
War Eagle!
sneasle's Avatar
United States, AL, Huntsville
Joined Sep 2006
I hope I don't get yelled at for dragging this thread up.
Is this the same type of probe used by the Triton series?
sneasle is offline Find More Posts by sneasle
Old Sep 12, 2008, 10:02 PM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
I use my lipo only Cxarge charger's temp probe to charge my tx nimh pack. I set the charger to 3S and temp cutoff to 35 deg C. It works like a charm, cutting off current at exactly 35 deg C and sounding an alarm.
Gino CP is offline Find More Posts by Gino CP
Old Sep 12, 2008, 11:56 PM
sneasle is offline
War Eagle!
sneasle's Avatar
Joined Sep 2006
Was that meant for me somehow?
Old Sep 13, 2008, 05:18 AM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
It's meant for anyone who could use the information.
Old Sep 13, 2008, 08:57 AM
Joined Jan 2001
Yes.
http://www.rctech.net/forum/2445303-post1222.html
Originally Posted by gusanoloco
the thermal probe for Duratrax ICE, G.Planes Triton, and Supernovas, Robitronics and clones is based on an integrated circuit, this is the LM35
Discussion IMAX B6 -- Read this before you buy.. jackyfu Batteries and Chargers 307 Jun 24, 2016 03:03 AM
Discussion Imax B8 Temp Error gilera180 Batteries and Chargers 7 Feb 29, 2008 02:02 AM
Discussion Just received an IMAX B6 charger... FerryP HobbyKing 3 Dec 18, 2007 06:48 AM
Discussion Imax B6 balancer faulty MartinL HobbyKing 8 Nov 15, 2007 04:00 PM
Wanted IMAX B6 or B8 (used) gp125racer Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 29, 2007 03:22 AM
