Old Nov 28, 2007, 02:14 AM
numba1st4r is offline
Find More Posts by numba1st4r
smaller faster=better
Joined Jun 2007
first pattern plane?
i have flown 3d freestyle and some pattern but that was on a friends aircraft that he lent me..... Now its time i had one of my own so i was thinking of making somthing loosly based on the murcury.
My main question is how to mount the servos
here are some specs:
Controll: throttle, aileron, elevator(so not true 3d/pattern)
Reciever: 3.05 g
Servo x2: 2.85 g each(manufacturer is dumb because he uses metal case for servo! could save at least .6 - 0.7 g!!!!!)
Speed controller:1.9 g
Motor: (undecided)
Battery:1cell lipo(undecided what Mah)
Wingspan:16 inches
so it will be micro and mainly for indoor use
I probably sound like one of those guys who is paranoid that his model will be too heavy but weight is very critical at this size.
My main problem is how to mount the servo's
happy flying
numba1st4r is offline Find More Posts by numba1st4r
Old Nov 28, 2007, 09:30 AM
Vasikn is offline
Find More Posts by Vasikn
Czech Republic - Tưn nad Vltavou
Joined Oct 2006
I used 2-side tape, but nowdays I'm simply glueing it. I'd glue them directly onto depron. According to me is it the best way.
Vasikn is offline Find More Posts by Vasikn
Old Nov 28, 2007, 09:57 AM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
num,
The servo mounting question has been addressed in this thread. I think you will find some helpful ideas on mounting servos.
http://www.rcgroups.com/forums/showthread.php?t=777189
Mini Ifo
aerolite is offline Find More Posts by aerolite
Old Nov 28, 2007, 10:00 AM
Aio_1 is offline
Find More Posts by Aio_1
Aio_1's Avatar
Ireland, Kildare, Leixlip
Joined May 2002
I agree. I had been using double sided tape. It works okay at first but I found that after a while the servo can shift slightly, changing control trim or even fall off altogether. I'd suggest wrapping the servo in a strip of masking tape and then mounting it with a very small amount of epoxy. That's what I've done the last couple of times and it seems to work very well. The masking tape is intended to allow you to remove the servo without having it covered in epoxy - that's the plan but I haven't removed one yet since I've only been doing this a while!
Aidan
Aio_1 is offline Find More Posts by Aio_1
Old Nov 28, 2007, 10:01 AM
aerolite is offline
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Num,
just noticed your 16" wingspan. Most F3P indoor planes havd 32" wingspan, and weigh about 145g.
Not sure the dimensions you have described will work well for F3P. I would recommend a Clik!, Manta, Mercury, Nexus, or Vrolet, build the kit, and you will get lots of good ideas on how they recommend mounting components.
Mini Ifo
Old Nov 29, 2007, 01:19 AM
Joined Jun 2007
funfly
i think you've got the wrong idea.....
I only intend this to be a fun little aerobat for my local gym. not for serious competition.
thanks anyway
Old Nov 29, 2007, 09:48 AM
ChrisBowker is offline
Find More Posts by ChrisBowker
RC Bum 4 Hire
ChrisBowker's Avatar
United States, NM, Albuquerque
Joined May 2004
thanks anyway
what ever you end up building in that size i'd like to see pics of it.
Chris
ChrisBowker is offline Find More Posts by ChrisBowker
Old Nov 30, 2007, 06:49 PM
Joined Jun 2007
wont be pics for a while as i cant really start till school holidaus come(1 week left)
even then i still need to order crystal, battery and motor.
it will probably be based on the murcury or extra 300
First electric plane for an experienced glow flier? Digital Beginner Training Area (Aircraft-Electric) 20 Nov 04, 2008 09:52 AM
Discussion First "pattern plane" a few questions <Newbie> Tommy D Sport Planes 1 Aug 25, 2006 03:16 PM
Watt-Age Super 400 F3-EP Micro Pattern Plane Thomas Manson Foamies (Kits) 0 Jul 30, 2001 04:47 PM
First aileron plane, any advice on setup? slowflyer Beginner Training Area (Aircraft-Electric) 4 Apr 30, 2001 10:37 PM
E-Factor electric F3A pattern plane ShredAir Sport Planes 0 Apr 20, 2001 11:06 PM
