If it’s foam you need to make hot wire templates for the root and tip airfoil section then attach them to the foam at the angles that you calculate with something like the Panknin twist spreadsheet . If you want to work in balsa then you will have to draw each rib and calculate the angle of attack for each rib. Back in the stone age we used to do it all with pencils and a calculator, it took days. Now a program like CompuFoil can do all the work for you in less time than it takes to pick the airfoils you want to use from the menu.
--Norm |
http://h1.ripway.com/cloudyifr/index.html
They must have been doing some maintenance as it's rare to go down, I use the website for my job on a daily basis too. I checked and bandwidth wasn't exceeded, try again and you should be able to get in. Do you have a link to the article? Thanks Curtis |
CloudyIFR:
I found the design procedure in this site http://www.b2streamlines.com/OTW.html,check this link and the download link is http://www.glide.net.au/on-the-wing3...tware-Windows/ and thanks for all buddies who reply my thread
| Thread Tools | |
| Got any ideas on how to make a foamie wing removable? | WilliamSettle | Foamies (Kits) | 5 | Jul 20, 2005 04:20 PM |
| Lets compare notes on how YOU make a fast wing. | WingMan33 | Foamies (Kits) | 2 | Feb 12, 2004 04:44 PM |
| Need suggestions on how to stabilize a T-Hawk wing | worldzfree | Parkflyers | 6 | Feb 14, 2003 11:44 PM |
| Any ideas on how to eliminate rear wing flutter from a zaggy 400x modified | ducatista | Foamies (Kits) | 8 | Apr 18, 2002 07:31 PM |
| Any advice on desiging a slow fly wing? | slowflyer | Foamies (Kits) | 7 | Mar 08, 2002 04:46 PM |
