Old Nov 27, 2007, 08:52 PM
Jeanseb is offline
Find More Posts by Jeanseb
Winnipeg, Canada
Joined Nov 2005
Using Flightgear for UAV simulations
Hello,
I have been contemplating using Flightgear to similate UAV control algoirhtms. I was wondering where to find a tutorial, which would specially put the emphasis on this subject.
Any idea?
Thanks!
Jeanseb is offline Find More Posts by Jeanseb
Old Nov 28, 2007, 06:56 AM
clolson is offline
Find More Posts by clolson
Minnesota
Joined Sep 2004
Hi,
I'm not aware of any tutorials available that are directed to this subject, but please feel free to post questions to the FlightGear developers mailing list. (And since FlightGear is an all volunteer project, if you do work through the process, you could be the first to write such a tutorial for the next person.) :-)
Curt.
clolson is offline Find More Posts by clolson
Old Nov 28, 2007, 08:12 AM
zlite is offline
Find More Posts by zlite
Chris Anderson
San Francisco/Bay Area
Joined Mar 2007
Yes, we have covered that at DIY Drones, and have links to a tutorial:
http://www.diydrones.com/profiles/bl...ogPost%3A12111
zlite is offline Find More Posts by zlite
Old Nov 28, 2007, 01:55 PM
Jack Crossfire is offline
Find More Posts by Jack Crossfire
Jack Crossfire's Avatar
Calif*
Joined Sep 2006
Everyone who read the DeNardi paper on neural networks is aware of at least the autopilot.sourceforge.net simulator being used to test autopilot software. Not sure how good that method is at teaching the autopilot how to fly the real thing vs. how to overcome the nuances of the simulator.
Unfortunately most of the methods to train neural networks on the ground are heavily patented.
Jack Crossfire is offline Find More Posts by Jack Crossfire
Old Nov 28, 2007, 02:31 PM
Jeanseb is offline
Winnipeg, Canada
Joined Nov 2005
Hello,
Thanks for the link. Unfortunatelly I do not have VB installed on my conputer...
Old Dec 03, 2007, 07:26 AM
Jeanseb is offline
Winnipeg, Canada
Joined Nov 2005
Hello,
I went back to this tutorial and even talked to its author. Unfortunately this does not cover what I would like to do with FlightGear.
Ideally I would like to embed my PID controller in FlightGear (replace FlightGear’s), that same PID controller I fly on my plane. There would be a wrapper that would provide sensor data and output to the actuators, a bridge between my PID and FlightGear. I would also modify an existing FlightGear airframe so it comes as close as possible to what my real plane does.
So far I haven’t found any paper that describes how to do this. I went through the FlightGear’s code but this is a bit abstract at the moment. I’ve seen a couple of PID classes but I am not sure how to modify them, how to use the sensor inputs and actuator outputs.
If anybody has any idea of how to do this, that would be appreciated!
Jean-Sebastien
Old Dec 03, 2007, 07:54 AM
wadiprawita is offline
Find More Posts by wadiprawita
Joined Nov 2005
Try to read this :
http://wadiprawita.files.wordpress.c...ceei2007-1.pdf
Regards
-doni-
wadiprawita is offline Find More Posts by wadiprawita
Old Dec 03, 2007, 10:24 AM
Vindication is offline
Find More Posts by Vindication
Joined Mar 2005
Also- check out this link for interfacing to flightgear
http://linkslink.wordpress.com/
check out the links on the side.
Vindication is offline Find More Posts by Vindication
Old Dec 03, 2007, 05:11 PM
Jeanseb is offline
Winnipeg, Canada
Joined Nov 2005
Hello,
Thank you to you both for the links. While browsing the Albatros project (http://www.albatross-uav.org) I realized they are using another simulator called CRRCSim. I quoting the albatros project here: "The core CRRCsim simulation is performed by LaRCSim, and open source flight dynamics simulation engine developed at the LARC (NASA Langley Research Center). " They also make it like it's easy to use...
Has anybody used this yet?
Thanks!
Old Dec 05, 2007, 08:52 AM
Unterhausen is offline
Find More Posts by Unterhausen
5 miles from the geographical center of Pennsylvania
Joined Aug 2005
I think the crossbow micronav project on sourceforge has used crrcsim
Unterhausen is offline Find More Posts by Unterhausen
"Mildly" OT: NASA using SBXC for UAV thermal flying surfimp Slope 21 Dec 03, 2007 05:01 PM
Look at what the good folks at NASA are using for uav's randall1959 Aerial Photography 6 Apr 09, 2005 12:46 AM
Using a litestick for arial photography?? jayboy Parkflyers 9 Jul 12, 2002 11:54 PM
Ray-O-Vac AA's & AAA's, Anyone using them for a while? Looooeeee! Power Systems 3 Sep 24, 2001 08:16 AM
Using Motocalc for helis J.Critchfield Electric Heli Talk 0 May 20, 2001 11:07 PM
