Old Apr 16, 2008, 08:22 PM
joe manor is offline
Find More Posts by joe manor
Stay in it!!!!
Riverside, California, United States
Joined Aug 2004
I was thinking of how cool it would be for Discovery or somebody to come out and document the build, maiden flight and record attempt. It would be cool to have Guiness people there to make it official if I ever get it up to a good high speed.. Maybe someday.
joe manor is offline Find More Posts by joe manor
Old Apr 16, 2008, 09:12 PM
wakumann is offline
Find More Posts by wakumann
wakumann's Avatar
Canada
Joined Jul 2003
Nice build tread
Joe
was wondering that no one has a mask, even the fumes of epoxy are quite harmful.
Know a few guys which developed nasty allergies over the years.
Or you have a good ventilation system.
Cheers
Thomas
wakumann is offline Find More Posts by wakumann
Old Apr 16, 2008, 09:43 PM
threcixty is offline
Find More Posts by threcixty
Not landing late ever again
threcixty's Avatar
United States, TX, Frisco
Ya get sensitized more from touching then breathing.. lol.. that sounds bad! In a shop that size, I doubt that the fumes would concentrate that much..
Joe.. Maybe send something to Mythbusters about a 400 mph glider..
threcixty is offline Find More Posts by threcixty
Old Apr 16, 2008, 11:00 PM
Stay in it!!!!
Joined Aug 2004
Originally Posted by wakumann
Nice build tread
Joe
Cheers
Thomas
That loud noise in the video's is coming from the ventilation unit in the shop. it pulls a lot of air through the shop. You can feel a breeze. It has a 30 or 35" duct. We were wearing gloves though.
Old Apr 17, 2008, 12:23 AM
samotage is offline
Find More Posts by samotage
find me @samotage
samotage's Avatar
Melbourne Australia
Joined Jul 2005
Maybe Myth Busters would be interested in documenting the attempt? If you can't beat the 400 mark, I'd love to see what they come up with to smash it!
Sam.
samotage is offline Find More Posts by samotage
Old Apr 17, 2008, 01:28 AM
daboz is offline
Find More Posts by daboz
daboz's Avatar
HB cali
Joined Apr 2006
new vid posted warp1.avi, bottom of the page. http://www.rcspeeds.com/160build.aspx
you will need the Divx decoders also located on the page.
daboz is offline Find More Posts by daboz
Old Apr 17, 2008, 07:05 AM
rcgroupie is offline
Find More Posts by rcgroupie
pushing the envelope
rcgroupie's Avatar
USA, CA, Los Angeles
Joined Jun 2005
Great video!
A couple questions, Joe.
1. Do you vacuum degass the epoxy right after mixing to remove entrained air, or does the rolling process make it moot?
2. Do you warm the epoxy slightly before you roll it in to reduce viscosity, or are you more worried about pot life?
Target: (VARTM)
Originally Posted by target
Could you not calculate the amount of resin required, then add a bit for a "fudge factor"?
I would think that this would just result in a small weight penalty, but also add peace of mind.
Target
The issue is not insufficient resin, it has to do with the way the distribution goes. In sort of a crude example, suppose you were trying to coat a canyon with resin using gravity instead of vacuum. If you poured the resin in 'upstream' and drained it out 'downstream' it would only coat the floor of the canyon, and not the walls. Does this make sense?
If these guys are really making a computer model of resin flow, that would be sweet!
rcgroupie is offline Find More Posts by rcgroupie
Old Apr 17, 2008, 07:14 AM
Daryl Wallis57 is offline
Find More Posts by Daryl Wallis57
Answer the far call.
Daryl Wallis57's Avatar
Australia, VIC, Creswick
Joined May 2007
Resin infusion
There is a great example of resin infusion in the pix about halfway this page on the HP-24 kit glider site, done in general workshop conditions.
http://www.hpaircraft.com/hp-24/update_4_april_08.htm
Incidentally it is one of the best build threads you will ever read, hard to top this one though! Go Joe!
Dash.
Daryl Wallis57 is offline Find More Posts by Daryl Wallis57
Old Apr 17, 2008, 07:30 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Originally Posted by rcgroupie
Great video!
Target: (VARTM)
I understand the point you are making now.
Maybe multiple points of resin introduction would be the key, one let in at a time, while the vacuum is continuous??
You're right though, no need for Joe M to be the trailblazer this time.
T
target is offline Find More Posts by target
Old Apr 17, 2008, 12:02 PM
djklein21 is offline
Find More Posts by djklein21
Challenge is rewarding
djklein21's Avatar
San Diego, CA
Joined Aug 2004
T
The trial and error part, is to place the infusion and extraction ports in locations such that the flow front never encircles a dry area, cutting the air off from the vacuum and leaving you with a dry fiber spot.
Again, please start a new thread as I don't want to clog up Joe's awesome build thread with a completely different topic.
Also, there are many commercially available VARTM flow modeling software packages, but none for 3-D flow, which captures the through thickness flow. Anyway, a new thread huh.
djklein21 is offline Find More Posts by djklein21
Old Apr 17, 2008, 12:12 PM
daboz is offline
daboz's Avatar
HB cali
Joined Apr 2006
Weight Penalty
Weight isn't that big of a deal, for DS, right? Seems, "to me" most planes @ over 200/250 seem as though they would fly better heavier. I like Opii ballasted all the time... 110oz @ 75inches. Joe will have a lot of wing area too, ?
Old Apr 17, 2008, 02:57 PM
djklein21's Avatar
San Diego, CA
Joined Aug 2004
Total weight isn't, but mass, and mass location are a very big deal for flutter. Most seem to overlook this, and only consider stiffness. When building an aileron, the heavier the surface, the larger its mass moment of inertia, and the further back its CG as compared to the hinge line all drop the flutter speed. Also the shear stiffness of a laminate is very sensitive to the amount of epoxy. The more epoxy, the worse the shear performance of the laminate.
Old Apr 17, 2008, 06:03 PM
daboz is offline
daboz's Avatar
HB cali
Joined Apr 2006
Well, many of us consider it, and many of us like our planes much heavier than they come for the 250/300mph range. SO, we add steel rod into all our ailerons, ruddervators, elevators and flaps to move the cg of the control surface forward and to increase torsional stiffness. Some glue in ballast. Others glue brass or lead into the wing tips and or the leading edge of the wings. I posted a document on aerodynamic flutter that address mass balancing.
Still, IMO, mass for high speed DS seems to be a friend,,, in the right place.
Chris
http://www.rcgroups.com/forums/showt...hlight=flutter
Old Apr 29, 2008, 06:56 PM
quigley257 is offline
Find More Posts by quigley257
Say when.....
quigley257's Avatar
United States, MO, Hillsboro
Joined Sep 2005
Kinda quiet here in Dynamic-land. Any updates for us Joe?
--quigley
quigley257 is offline Find More Posts by quigley257
Old May 06, 2008, 07:37 AM
Stay in it!!!!
Joined Aug 2004
Finished the inner skins yesterday. There were two of us working and it was a mad dash to get all of the pieces into the molds before the resin went off. Couldn't take any pics. Basically I used a couple fabric doublers in the tips with 1/16th balsa in between, two more layers for control surface doublers, kevlar hinge, several pulls of tow in the LE several pulls of tow and a few layers of fabric in the tounge and a full inner layer of carbon fabric to cover it all up. The skins are finished! All I need to do now is make a shear web, drag spar, install gear, and a couple of other small doodads and I can close the molds. I will have a wing by the weekend if I can get all the servos.
Yippee! It'll NEVER FLY!!! All carbon, hollow molded... winchdoc Slope 37 Jul 10, 2008 09:10 PM
Alert Testing the WM600 (part 2) winmodels Electric Ducted Fan Jet Talk 184 Apr 14, 2005 05:48 PM
Wanted: Carbon bagged or hollow molded HLG CDignition Aircraft - Sailplanes (FS/W) 0 Feb 03, 2004 06:48 PM
Jim Bourke's Moving Sale Part 2 -- Brushless motors jbourke Aircraft - Electric - Airplanes (FS/W) 1 Aug 07, 2001 02:00 AM
MIA's 12" House FLY Sub-Micro! NEWS!!! (Part 2) MicroRotors Electric Heli Talk 10 Jul 27, 2001 03:19 PM
