Old Jun 12, 2010, 04:14 PM
airtimeasto is offline
Find More Posts by airtimeasto
There is only DS
airtimeasto's Avatar
Australia, WA, Baldivis
Joined Aug 2008
Oh no Joe, Sorry to hear ...
will there be a Round 3
130" That should be easier to carry
Mate your work has inspired me to build Thanks
Asto
airtimeasto is offline Find More Posts by airtimeasto
Old Jun 12, 2010, 09:57 PM
Pook is offline
Find More Posts by Pook
Pook's Avatar
Bolton,England
Joined May 2003
Bah...sorry to hear the bad news, but I guess you know have an excuse to make the next one...
Pook is offline Find More Posts by Pook
Old Jun 14, 2010, 12:32 PM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Chin up Joe. I said it before and I'll say it again, you have charted new territory and moved the bar well up for others. I hope and pray to read more of your adventures here in the future.
Watching your thread go along got me interested in CNCs and I started researching the shopbots. In November I decided to build my own instead. I finished my CNC in February and cut my wing molds in March and April. I just pulled the first DLG wing from those molds this past week. You probably have more weight in paint on your D160 than my airframe weighs (10oz) ready to fly.
I've always been a composites geek but you motivated me to get off my duff and do something more. Again, thank you.
tom43004 is offline Find More Posts by tom43004
Old Jun 14, 2010, 03:09 PM
Pook is offline
Pook's Avatar
Bolton,England
Joined May 2003
That's awesome to hear Tom...That's sort of the best thing about RCGroups nearly unlimited inspiration.
Old Jun 17, 2010, 03:50 PM
Geo420 is offline
Find More Posts by Geo420
Mach 0.261 ... Hiccup of Wiggy
Geo420's Avatar
Wiggy Poo, England!
Joined Mar 2006
Here Here!
Thanks RCG
George
Geo420 is offline Find More Posts by Geo420
Old Jun 18, 2010, 07:46 AM
Ralph Walton is offline
Find More Posts by Ralph Walton
The Flying Kiwi
Mt Maunganui New Zealand
Joined Oct 2005
Sorry to hear of the loss of your latest 160 Joe. If its some help to you, I was the mechanical engineering manager of a plywood factory for 17 years. I was intimately involved with the complete process of turning logs into plywood.
If you can find a small specialist plywood factory,(like we were) you will find they can make you virtually any plywood you want. I suspect that what you need is close to whats known as LVL (laminated veneer lumber)
LVL is usually made like conventional plywood, but with the grain of each layer, oriented in one direction only. A possible problem with it, is that it can end up with similar splitting/ warping problems , as solid lumber. usually , but sometimes.
If you could find a cooperative manufacturer, They could make you a few sheets of plywood/ LVL, out of a suitable type and thickness of veneer, with the grain, oriented alternately, a few degrees (maybee 10 degrees?) or so to each other, either side of the centerline, to each layer. (fyi super compressed plywood, with the grain spread alternately a a few degrees apart, around 360 degrees, was used for timing gears of various engines during WW2)
You would end up with virtually end grain only plywood, for your shear webs (maybee 5 degrees either side of it), with enough crossover of grain to eliminate any possible warping etc and give you the stability, and more than enough strength to be suitable for your purposes.
I'm unsure what would be a suitable wood for your purposes, but I am shure someone will be familiar with a factory that is up to the challenge,(hopefully close to you)
Ralph Walton is offline Find More Posts by Ralph Walton
Old Jun 18, 2010, 08:01 AM
Aerogance is offline
Find More Posts by Aerogance
Foaming agent
Aerogance's Avatar
United States, CA, Ventura County
Joined Sep 2008
Good call Ralph. Typically we order custom face layups on plywood out here, but controlling the core layup could be the answer $$$.
Aerogance is offline Find More Posts by Aerogance
Old Jun 18, 2010, 09:46 AM
joe manor is offline
Find More Posts by joe manor
Stay in it!!!!
Riverside, California, United States
Joined Aug 2004
really no need as even the crappiest plywood still holds ten times (just a rough number) the compression and shear loads required by our models currently. Because we are using such thick sparcaps to avoid bending alltogether the shear web never really sees much load in comparison. Thats at least they way I understand it after reading the very helpfull thread started by, I think, rothisburger?
We are now using substantial amounts of tip weight so the bending loads are even less.
joe manor is offline Find More Posts by joe manor
Old Oct 26, 2010, 11:48 AM
macinr is offline
Find More Posts by macinr
macinr's Avatar
USA, CA, Santa Barbara
Joined Feb 2003
whew. what a ride, i've been reading this thread from start to finish for the past two days (it's like a novel). i feel enthralled and inspired as ever.
macinr is offline Find More Posts by macinr
Old Oct 26, 2010, 06:20 PM
Stay in it!!!!
Joined Aug 2004
Did you read part one first?
Old Oct 26, 2010, 08:10 PM
Foaming agent
Aerogance's Avatar
Joined Sep 2008
I would like to see Joe make another 160, with all the improvements he has developed to date. I can't imagine the cost and man hours involved, but at least the tooling is completed!
Old Oct 26, 2010, 08:38 PM
macinr is offline
macinr's Avatar
Joined Feb 2003
No. This thread was linked elsewhere on another thread, but I will get to it next. The wind has been up in Santa Barbara so I need to go out and DS my Weasel first. It's not like the places in the videos linked but we have several peaks that are easy to get started making loops for DS newbies. Looking forward to part 3.
Old Oct 26, 2010, 11:30 PM
Foaming agent
Aerogance's Avatar
Joined Sep 2008
Head up to the crest and East of Gibraltor. There is an insanely good NW-N facing part of the ridge. Watch out for passer-byers though.
Old Jan 12, 2011, 03:34 PM
jfinch is offline
Find More Posts by jfinch
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
Hi Joe,
How did you fill in the area between the top and bottom skins at your TE? Epoxy splooge before mating the two halves? If so how do you clean up the area in front of the hinge (at each end of the hinge) for the wiper to slide? Dremel?
One more question, you mention a couple times in this thread that you use a kevlar live hinge with a backup of 3M5200. How is the 5200 applied?
Thanks for the thread it has been an inspiration and great source of info for me! I almost hate to resurrect it but I'm working though my own hollow molded issues...
jfinch is offline Find More Posts by jfinch
Yippee! It'll NEVER FLY!!! All carbon, hollow molded... winchdoc Slope 37 Jul 10, 2008 09:10 PM
Alert Testing the WM600 (part 2) winmodels Electric Ducted Fan Jet Talk 184 Apr 14, 2005 05:48 PM
Wanted: Carbon bagged or hollow molded HLG CDignition Aircraft - Sailplanes (FS/W) 0 Feb 03, 2004 06:48 PM
Jim Bourke's Moving Sale Part 2 -- Brushless motors jbourke Aircraft - Electric - Airplanes (FS/W) 1 Aug 07, 2001 02:00 AM
MIA's 12" House FLY Sub-Micro! NEWS!!! (Part 2) MicroRotors Electric Heli Talk 10 Jul 27, 2001 03:19 PM
