Old Dec 25, 2009, 03:44 PM
joe manor is offline
Find More Posts by joe manor
Stay in it!!!!
Riverside, California, United States
Joined Aug 2004
Plywood is manufactured for it's shear strength. If you took regular hardwood and nailed it to the shear wall of a house for example it would split easily.
joe manor is offline Find More Posts by joe manor
Old Dec 25, 2009, 03:59 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
And plywood has more stability. I could see a solid piece of wood swelling a lot more while sitting in the sun.
Adam
wyowindworks is offline Find More Posts by wyowindworks
Old Dec 25, 2009, 05:39 PM
rothlisburger is online now
Find More Posts by rothlisburger
the occasional flyer
rothlisburger's Avatar
Rexburg, ID
Joined Jul 2008
No, plywood is manufactured for it biaxial strength, and for its dimensional stability. It has the same shear strength as the wood it is made of. But, as you point out, less tendency to split due to moisture variations (because of the cross-plies).
I hate to pull rank on you, but I have a PhD in mechanics of composite materials. Although I'm still learning. I'd be happy to see any data you have to the contrary.
As far as the build thread, it may happen in the coming years. I'm founding a collegiate team with the goal of fabricating a plane capable of taking the Idaho record, currently held by Tauno and an Opus.
But allow me to express myself in awe of what you have accomplished. I'd be pleased if my students could benefit from your (and others') experience.
-David
rothlisburger is online now Find More Posts by rothlisburger
Old Dec 25, 2009, 05:59 PM
Psionic001 is offline
Find More Posts by Psionic001
Psionic001's Avatar
Australia, NSW, Sydney
Joined Apr 2006
Why not a solid lump of carbon and be done with it
Psionic001 is offline Find More Posts by Psionic001
Old Dec 25, 2009, 06:29 PM
OZPAF is offline
Find More Posts by OZPAF
Sydney
Joined Apr 2009
Merry Christmas Joe. Its abnormally wet here instead of our normal heatwave.Brrr!
John
OZPAF is offline Find More Posts by OZPAF
Old Dec 25, 2009, 06:44 PM
Stay in it!!!!
Joined Aug 2004
-David
Thanks David. Maybe I will try the solid wood sometime. When I was at the lumber yard they had some very light mahagony that would have made this even easier. Think that would do the trick?
Do you know how to calculate compression and shear loads for my model?
Old Dec 25, 2009, 06:46 PM
Stay in it!!!!
Joined Aug 2004
John
I hate the cold too. Nothing a good build session cant fix. Must work faster.
We decided to build a rock wall the other day when we were waiting for the wind. Kept us warm and sore for days.
Old Dec 25, 2009, 07:39 PM
OZPAF is offline
Sydney
Joined Apr 2009
My building rate will never keep me warm.I sort of have a reputation of the reverse.
cheers
John
Old Dec 25, 2009, 08:43 PM
Jason Lilly is offline
Find More Posts by Jason Lilly
Go Faster!!
Jason Lilly's Avatar
San Diego, CA
Joined Apr 2004
-David
David,
If the plywood shearweb was made from +- 45 Deg plywood instead of 0-90 plywood would that be a better way to use plywood for a shearweb?
Jason Lilly is offline Find More Posts by Jason Lilly
Old Dec 25, 2009, 08:47 PM
Stay in it!!!!
Joined Aug 2004
Go Faster!!
San Diego, CA
Joined Apr 2004
Did I mention I have a bad case of ShopBot envy??
Stay in it!!!!
Joined Aug 2004
It's yours anytime you want to use it Jason.
Old Dec 25, 2009, 08:58 PM
Go Faster!!
San Diego, CA
Joined Apr 2004
I appreciate that, Cause I'm a DS Junky..... if you know what I mean!
Old Dec 25, 2009, 09:02 PM
Stay in it!!!!
Joined Aug 2004
Plywood is manufactured by slicing or rotary peeling thin [<2.5 mm] sheets of material [veneer] from a flitch or log and then laminating three or more veneers into a rectangular sheet perhaps 1200 mm 1200 mm for very thin sheets otherwise 1200 mm 2400 mm. Laminating an odd number of plies [3, 5, 7 ...] reduces warping while increasing the number of plies increases the resistance to shearing forces.
Old Dec 25, 2009, 09:06 PM
Dale Thompson is offline
Find More Posts by Dale Thompson
F3J-F3K-F3F- What to Fly??
Dale Thompson's Avatar
Cupertino CA
Joined Aug 2005
If I get the idea, when ripping the Ply strips treat it just like carbon cloth.
Cut some Ply strips at 0-90 and some on a 45 deg to the wood grain.
Treat the grain just like carbon tows.
When gluing the stack they can be alternated, then CNC as before.
Now the question is, will it really make a difference or just rip up a lot of plywood?
Dale Thompson is offline Find More Posts by Dale Thompson
Yippee! It'll NEVER FLY!!! All carbon, hollow molded... winchdoc Slope 37 Jul 10, 2008 09:10 PM
Alert Testing the WM600 (part 2) winmodels Electric Ducted Fan Jet Talk 184 Apr 14, 2005 05:48 PM
Wanted: Carbon bagged or hollow molded HLG CDignition Aircraft - Sailplanes (FS/W) 0 Feb 03, 2004 06:48 PM
Jim Bourke's Moving Sale Part 2 -- Brushless motors jbourke Aircraft - Electric - Airplanes (FS/W) 1 Aug 07, 2001 02:00 AM
MIA's 12" House FLY Sub-Micro! NEWS!!! (Part 2) MicroRotors Electric Heli Talk 10 Jul 27, 2001 03:19 PM
