Riverside, California, United States
Joined Aug 2004
I am using a rubber squeege as a flexible sanding block. It's real purpose is to sweep away water and sanding dust when wet sanding so you can see the surface dry to determine where your at in the sanding process. I am using rags for that. I start by getting some soapy water on the mold half. Im doing one side of each half at a time. This is the elevator mold for those who are wondering. In order to keep the surface true I start sanding at a 45 degree angle. Im sanding all the way up to the leading edge and stopping about 75% back. I then sand at the same angle from the trailing edge overlapping the previous pass. I work from the root to the tip and back again. I then do a pass at the same angle from the root to the tip and back but this time Im sanding all the way from the leading edge to the trailing edge. I then repeat the process 90degrees off the last sanding angle. Once finished I then sand spanwise starting at the leading edge and going back. I am cleaning up the sludge and adding fresh water in between each steps.
| Thread Tools | |
| Yippee! It'll NEVER FLY!!! All carbon, hollow molded... | winchdoc | Slope | 37 | Jul 10, 2008 09:10 PM |
| Alert Testing the WM600 (part 2) | winmodels | Electric Ducted Fan Jet Talk | 184 | Apr 14, 2005 05:48 PM |
| Wanted: Carbon bagged or hollow molded HLG | CDignition | Aircraft - Sailplanes (FS/W) | 0 | Feb 03, 2004 06:48 PM |
| Jim Bourke's Moving Sale Part 2 -- Brushless motors | jbourke | Aircraft - Electric - Airplanes (FS/W) | 1 | Aug 07, 2001 02:00 AM |
| MIA's 12" House FLY Sub-Micro! NEWS!!! (Part 2) | MicroRotors | Electric Heli Talk | 10 | Jul 27, 2001 03:19 PM |
