This thread is privately moderated by darkfa8, who may elect to delete unwanted replies.
Old Nov 27, 2007, 07:01 PM
darkfa8 is offline
Find More Posts by darkfa8
Trader Rating: 26
darkfa8's Avatar
United States, NJ, Brick
Joined Jul 2005
Trader Rating: 26
For Sale
Hirobo Freya - EVO 90 Parts
Tail Section:
1. (2) Freya upper boom band clamp $1ea
2. (7) used freya tail grip half $5/for all
3. 0412-147 sd tail pitch lever NIB $5
4. 0414-328 e3 tail boom brace band NIB $5
5. 0404-662 tail blade holder set NIB $6
6. evo 90 boom brace ends $1
7. tail belt pulley new $1
8. r-side tail case w/ output shaft bearing & pitch arm assy $10
9. freya/evo tail output bearing block w/bearing & hardware $6
10. freya/evo tail output bearing block $1
11. freya/evo tail pulley assy - shaft/pulley/gear/brgs/spacer/brg $5
12. silver aluminum boom support rods $5
13. new tail boom servo mount $3
14. new frame tail output shaft w/ belt pulley $3
15. new tail case output shaft $3
16. used tail case output shaft $2
17. (2) aluminum tail pushrod $3
18. (2) pitch plate arms w/ balls $1
Rotor Head:
1. freya flybar cage metal rods $2
2. 0403-085 w-type washout control arms NIB $5
3. 10mm main shaft stopper, set-screw type & 1 clamp-style (not pictured) $2
4. 2.8mm & 2.5mm hirobo plastic main blade washers $2
5. swash plate with linkage balls $13
6. L & R x-levers w/ BRGS $10
7. (4) freya/evo aluminum main grip bearing spacers $1
8. used swash plate w/o link balls $10
9. (4) 65mm pushrods $1
10. NIB link balls $4
11. NIB link ball screws $4
12. washout base w/ one mixing arm and bearings $5
Bearings:
1. 2500-051 BRG 4x8x3zz NIB $8
2. 2500-061 BRG 4x9x4zz (3) NIB $8
3. 2500-073 BRG 4x8x3Fzz NIB $8
Pushrods:
1. (4) 65mm pushrod $1
2. (12) miscellaneous pushrods $5
Drivetrain:
1. NIB freya 10t pinion/clutch bell assy $15
2. freya clutch bell - needs bearing & pinion $4
3. freya/evo motor collet, fan/clutch hardware NIB $12
4. fuel tank stopper assy $2
5. nib freya motor mounts w/ frame hardware $8
6. freya motor mounts $2
7. (2) engine fan new $10ea
8. clamping style main shaft stopper 10mm $5
9. 2nd-gear $5
10. main shaft stopper set-screw style $2
11. engine fan, clutch hub, governor magnet, stepped washer & collet $10
Electronics:
nib carbonxtreme avant switch plate $5
Misc. Hardware:
1. 2521-085 collar 3x5 2x2 NIB $2
2. 2506-017 13 1.7mm flat washers $2
3. 2507-001 e-ring m1.5 NIB $4
4. (2) 2400-014 heat shrink tube W=36 NIB $4ea
5. (2) 2506-004 flat washer 3x8x0.5t NIB $4
6. 2532-031 cap screw m2x6 NIB $5
7. 2506-035 flat washer 8x12x0.1t NIB $4
If you're interested in a bunch of specific parts, message me with your list and I'll give you price.
BUY IT ALL FOR $90 shipped!!!
Paypal accepted if you pay the 3% fee. Money order also accepted. Please contact me for a shipping quote.
darkfa8 is offline Find More Posts by darkfa8
Hirobo Evo 90 E Conversion Albig Electric Heli Talk 235 May 22, 2008 04:39 AM
For Sale Avant - Freya - EVO 90 - More Parts for Sale! darkfa8 Aircraft - Fuel - Helis (FS/W) 4 Sep 23, 2007 03:07 PM
For Sale Freya & EVO 90 Parts - CNC Auto Hubs too! darkfa8 Aircraft - Fuel - Helis (FS/W) 1 Apr 12, 2007 01:30 PM
Discussion Freya Evo 90 conversion, battery options? Paul Susbauer Electric Heli Talk 5 Dec 05, 2006 06:06 PM
For Sale hirobo freya evo 90 f/s or f/t supraman22 Aircraft - Fuel - Helis (FS/W) 3 Oct 20, 2005 10:24 AM
