Old May 05, 2001, 11:40 PM
slowflyer is offline
Find More Posts by slowflyer
Flying slowly along..
Northern Ca.
Joined Dec 2000
New Zagi 400x builder, any tips for me?
Just started building it tonight. Any hints , tips or hop ups I can use?---Rob
slowflyer is offline Find More Posts by slowflyer
Old May 05, 2001, 11:46 PM
dave_lilley is offline
Find More Posts by dave_lilley
Texas
Joined Aug 1999
Don't use too much 3M-77. That stuff can add a lot of weight quickly. I know that a light coat doesn't look as if it is enough, but it is. When I was building my e-plane from JK, I put on too much 3M-77 because I couldn't see it on the foam. It was there, but when I finished adding enough so that I could see it on the foam, I had turned my e-plane into a non-flying brick.
Dave
dave_lilley is offline Find More Posts by dave_lilley
Old May 06, 2001, 12:12 AM
funflyer is offline
Find More Posts by funflyer
Fun Flyin
Escondido, CA, USA
Joined Mar 2001
Move the battery foward and DONT put the receiver in front. If you move the battery far up enough..It will balance out right. I have done this before and it flys great. Also..These planes are very sensitve to weight..Keep it "light for flight" Also dont use a lot of strapping tape. You dont a lot with a carbon spar. Use very little expoxy and a tiny amounbt of spray glue. Even a fex ounces will make a HUGE difference. Trust me on this one!
Have Fun
funflyer is offline Find More Posts by funflyer
Old May 06, 2001, 02:24 AM
Northern Ca.
Joined Dec 2000
Thanks guys, is the spray adhesive all that you need to join the wings together. I've triple read the instructions and see no mention of using epoxy.--Rob
Old May 06, 2001, 03:17 AM
volt flyer
volt flyer
Guest
n/a Posts
Yes, just use the spray glue to join the wing halfs.
Also think about some servo savers. I've gone through 2 sets of servos on mine.
Ya, mount the reciever in the foam just off to the side, the battery killed one of those too.
[This message has been edited by volt flyer (edited 05-06-2001).]
Old May 06, 2001, 06:43 AM
Ben C is offline
Find More Posts by Ben C
UK
Joined Jan 2001
1) Velcro the wingtips on, and they'll come off in a crash. My first set were epoxied on, but after a vicious attack from one of them 'zagi-eating trees', the epoxy had sheared clean off. It wasn't my fault.
2) DON'T colour your 'tips black. You'll never find them in the forest (guess how I found that one out).
3) Have fun bashing up the zagi. It won't complain.
Ben C
[This message has been edited by Ben C (edited 05-06-2001).]
Ben C is offline Find More Posts by Ben C
Old May 06, 2001, 06:52 AM
Greg Covey is offline
Find More Posts by Greg Covey
AMA 697691 / FAA 13675
Rochester, NY, USA
Joined Aug 2000
Rob,
It looks like these guys covered most of it. My only recommendation would be to epoxy the wing halfs together. Also don't be afraid to cover the ship with EconoKote or UltraCote (or similar). The shrink film covering looks better than the tape and gives it a protective skin that can be re-ironed over and over after it gets banged up.
Good luck!
[This message has been edited by Greg Covey (edited 05-06-2001).]
Greg Covey is offline Find More Posts by Greg Covey
Latest blog entry: Greg's Web Hangar
Old May 07, 2001, 01:15 PM
Rochester, NY, USA
Joined Aug 2000
costath,
Taping the elevons is a procedure in the manual, not really a modification or a tip. Since they are balsa, the film covering works well to protect them.
Old May 07, 2001, 01:22 PM
kenny_dilger is offline
Find More Posts by kenny_dilger
United States, IN, Evansville
Joined May 2001
I thought some of the purpose of the tape was to add strength. Does Ultracote do this also? Or is the carbon fiber (along with the CF rod) all that is needed for support?
Kenny
kenny_dilger is offline Find More Posts by kenny_dilger
Old May 07, 2001, 01:46 PM
Ben C is offline
UK
Joined Jan 2001
You need less strapping tape with a spar (a good, LONG spar, anyway) but you still need tape with the film covering.
Even with a spar, it is recommended that you follow the taping pattern in the book; only you can use 3/4 inch tape instead of 2 inches.
Ben C
Old May 07, 2001, 11:19 PM
Northern Ca.
Joined Dec 2000
Well, it's pretty much done. Looking rather menacing in it's bright yellow, with purple tiger stripes. I was going to make it look really nice and P.C., but said what the hell and made it look rather evil. Just have a few more things to finish, then off to fly it. Thanks for all your help--Rob
Old May 08, 2001, 12:41 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Install a pair of WeMoTec electric ducted fans with brushless motors and 20+ cells, yeah, that's the ticket!
GregG is offline Find More Posts by GregG
Old May 08, 2001, 12:50 AM
costath is offline
Find More Posts by costath
Quiet Power
USA, CA, Citrus Heights
Joined Mar 2001
Guys...you left off one serious modification....
Elevons need to be Taped to prevent them from splitting...balsa is just too thin...Also, re-inforce the control horn mounts...
costath is offline Find More Posts by costath
Old May 08, 2001, 07:22 AM
towlebooth is offline
Find More Posts by towlebooth
St. Paul, MN
Joined Feb 2001
Bright yellow with purple stripes? Do we have a closet MN Vikings (American Football) fan?? Great colors!!
towlebooth is offline Find More Posts by towlebooth
Old May 08, 2001, 08:19 AM
Rochester, NY, USA
Joined Aug 2000
Sounds good, Rob. With the noise a Zagi makes...evil is better!
Kenny,
On my previous post, I was refering to the packing tape on the elevons not the strapping tape. Ben is correct about still using the strapping tape on the foam.
Discussion PicoZ - Any tips for new owner PeteW Micro Ready-to-Fly 2 Jan 28, 2007 07:22 PM
Any Tips for a new flyer? haddorh Micro Helis 6 Jan 23, 2005 02:11 AM
New Zagi 400X for sale or trade Jodie Aircraft - Electric - Airplanes (FS/W) 17 Apr 21, 2003 01:29 PM
New Zagi 400X For Sale Jodie Aircraft - Electric - Airplanes (FS/W) 11 Apr 20, 2003 08:49 PM
any tips for me? pedsnurse Parkflyers 1 Mar 16, 2003 02:26 AM
