Old Nov 30, 2010, 04:01 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Bob,
I noticed a nice servo tester at Neu motors the other day, only $10 and it is nicer than the one I have that cost the same:
http://www.neumotors.com/store/page9/page9.html
I use a external BEC to power up my servo tester and it will then handle a pair of servos. It is so quick and handy I couldn't live without it.
I got that one from Strong Motors but Don is out of stock on them now. Check out his instruction for doing motor tests, that is another good reason for having a servo tester.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Nov 30, 2010, 05:51 PM
**neons** is offline
Find More Posts by **neons**
5,200 Led Lighted Bike-Bob P.
**neons**'s Avatar
USA, MA, Swansea
Joined Mar 2003
Thanks Jack,
I got it on order. The user info is good also. This may be a safer way to run the motors than with the radio in hand. Good servos setups too.
**Neons** Bob
**neons** is offline Find More Posts by **neons**
Old Nov 30, 2010, 06:38 PM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
Wow! This I'd one little powerhouse. I just soldered up the connectors and mounted the TP 3015-7 to the front of the Typhoon and used a new 11x7 3-blade prop. I used a 4s 2250 25c Zippy pack and a 50amp SS esc and an external ubec. Connected an Astro meter and let her rip. 37amps and 509watts. I'll have to check rpm's outside tomorrow. Maybe I'll pick up a fish scale one of these days so I can measure thrust. The Typhoon weighs 3.75 pounds and I plan to hand launch her. Might just have enough go. How do you calculate pitch speed?
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Nov 30, 2010, 07:29 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Sounds impressive, Mike.
How was the heat after that run? Did it get very warm?
I like this calculator here, quick and simple:
http://www.rcpro.org/rccalc/PitchSpeed.aspx
Your actual flight speed will generally be 10% or so less I'm told.
If you loaded that 4S down to 14V or so (3.5V per cell) and got 80% of the no load RPM (14V x 1000 = 14,000) you might have had around 11,200 RPM. And that calculates out to 74 MPH. That might be in the ball park.
Jack
Old Nov 30, 2010, 08:53 PM
Joined Jan 2004
Jack
Thanks Jack. I'll try to make time to run it again tomorrow and note the voltage under load. The can was no more than warm after three run ups of about 5-10 seconds each. While I had the watts slightly above the claimed max the amps were lower so I'm hoping that it balances out and won't cook the motor. It'll unload in the air as well so it might be ok.
Old Dec 12, 2010, 06:17 PM
9XTremist is offline
Find More Posts by 9XTremist
San Bernacesspool
9XTremist's Avatar
United States, CA, San Bernardino
Joined Feb 2010
not the stock wind we get?
this is the first time i've seen this motor anywhere but on a chinese website. i wonder if the factory is winding to this kv or if "airfield rc" is doing it. if the factory is why can't we get them wound with 21awg at 18 turns. this is on hobbypartz website i don't know if "airfield rc" is their stuff or not.
michael
9XTremist is offline Find More Posts by 9XTremist
Old Dec 13, 2010, 04:32 PM
manuel v is online now
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
Jack
I have a EXcel with this function.
La convertidora.
Conversiones.
De Pulgadas a Centimetros.
De centimetros a Pulgadas
De gramos a Onzas
De Onzas a Gramos
Pies cuadrados a Decimetros cuadrados
Decimetros cuadrados a Pies Cuadrados
Pies cuadrados a pulgadas cuadradas
Pulgadas cuadradas a Pies cuadradas
De kilos a libras y onzas.
Calculo de KV Ratio
Duracion de bateria
Velocidad del modelo
Velocidad de perdida. Con datos en sistema Imperial y Metrico.
Area para DF,
para servos de oz a kilos.
manuel v is online now Find More Posts by manuel v
Old Dec 15, 2010, 03:27 PM
doggit is offline
Find More Posts by doggit
doggit's Avatar
northenden, manchester, england
Joined May 2009
ok i have had this DT750 for a while, and i have been using it in a spaffnutz wing, i have been reading some of the comments and there seems to be quite a lot of different wind numbers, and was just wondering what you guys consider the best wind number and AWG to use, i dont plan on using anything bigger than a 10" prop, the plane i plan to use is a pusher with twin tails, which only allows a 10" prop due to the gap, its mainly for AP and possibly FPV so hope someone can give me the best combo for a 10" prop
carl
doggit is offline Find More Posts by doggit
Old Dec 15, 2010, 03:48 PM
manuel v's Avatar
Joined Aug 2004
maybe 12 turns. 20AWG.
KV 1143, GWS 10x6, 9862rpm, 300 watts , 71% effy. 1.4 kilos
Manuel V.
Old Dec 15, 2010, 04:17 PM
Jocke is offline
Find More Posts by Jocke
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
michael
Quite funny, today i got this motor (looks the same) from a friend, he had got it in an RTF Cessna kit, but tought it was realy bad, so he gave it to me. I removed the winding (badly made) and it was 18turns multistrand of 6x 0,25mm (i think 0,25 or simular) wires, terminated in Delta. The "soft" long shaft was bent after a crash, and i need some new bearings to.
Jocke is offline Find More Posts by Jocke
Old Dec 15, 2010, 05:15 PM
doggit is offline
doggit's Avatar
Joined May 2009
thanks manuel v but at the moment i dont have any 20AWG, but i do have some 21, 22, 24 AWG could you give me any numbers for any of these sizes please, i have just unwound it and it was 18turns multistrand of 6x 0,25mm (i think 0,25 or simular) as jocke states in his post, so now i have an empty motor waiting for fresh wire
thanks
carl
Old Dec 15, 2010, 05:48 PM
Jack
USA, ME, Ellsworth
Joined May 2008
carl
Hi Carl,
I'm using this motor on my SpaFFFnutz too as you know. I thought I had done a 16 turn 21 AWG rewind on that but, as Manuel has pointed out, the 927 Kv that I got suggests that I probably actually did a 15 turn rewind. But I'm very happy with it.
I get the following in static testing on that motor with a Great Planes PowerFly Slow Fly 10 x 4.5 prop:
Amps: 22.75A
Watts: 231W
7,350 RPM
That is with a 4S A123 1100 mAh pack, the pack voltage started and 13.2V and pulled down to 10.1V under load. Performance with a 3S LiPO would be very similar.
When I fly with that motor it gets very little time at much more than half throttle. It is too fast and even a little scary for me at full throttle, I like to fly it most at half throttle or so.
There have been a couple of times when I flew in higher winds when I used most or even all of the power to get the plane back upwind against a heavy headwind. Those were times when I was glad to have that extra power in reserve of course.
I've flown the eLogger on the SpaFFFnutz a few times too and find I'm doing most of my flying at 5,000 to 6,000 RPM and with the motor pulling from 5A to 9A and generating 50 to 100 Watts or so.
So I'm not sure about best but the 16T21AWG DLRK wind with a Delta termination has been good for me.
Jack
Old Dec 15, 2010, 09:13 PM
Jack
USA, ME, Ellsworth
Joined May 2008
The bearings are a little undersized for the motor I think. But they are what they are. Two bearings are needed, the size is 4 x 7 x 2.5mm (MR74ZZ).
It is not uncommon for people to complain that the bearings that these motor come with are noisy. I found lubricating them before the first use to be a good idea and also noticed that they don't seem to be particularly well made (a shield fell out while I was handling one). I lube them with 10W-40 Mobil 1 pure synthetic oil and use a vacuum chamber to get the oil inside the shields.
Shafts are easy enough to replace, you need a 4mm shaft that is about 50mm or longer. There are several shafts here that can be made to fit by cutting them to length and/or cutting an E-clip groove:
http://www.headsuprc.com/servlet/the...FTS/Categories
If you need help on cutting shafts to length or cutting grooves for E-clips this thread explains how to do it:
http://www.rcgroups.com/forums/showthread.php?t=1240725
Jack
Old Dec 15, 2010, 11:43 PM
San Bernacesspool
9XTremist's Avatar
Joined Feb 2010
Jocke wrote,
"Quite funny, today i got this motor (looks the same) from a friend, he had got it in an RTF Cessna kit, but tought it was realy bad, so he gave it to me. I removed the winding (badly made) and it was 18turns multistrand of 6x 0,25mm (i think 0,25 or simular) wires, terminated in Delta. The "soft" long shaft was bent after a crash, and i need some new bearings to."
the bearings are MR74ZZ = 4 x 7 x 2.5 mm.
bphobbies<dot>com did have them on sale for (2) for $0.10, i bought 40 of them for $2.00. RC - Bearings<dot>com usually has them, not quite that cheap. the last 5 motors i bought from r2hobbies (turborix label) were pretty neatly wound, for this motor. the 2 i bought from hobbyking before that were a rats nest. that's just luck of the draw, no reflection on h/king. stock wind @ 750kv gives 40 oz. of thrust @ 19 amps with an apc 12 x 6e prop. the 1050kv that's in those
"airfield rc" planes isn't going to have the guts compared to the 750kv, i don't think. (but what do i know)
if you rewind with 18 turns of 21awg and run your motor on high timing you get 60 oz. of thrust @ around 24 amps with an apc 12 x 6e prop. for $10.00 that seems like a heck of a deal to me. let me know if you can't find any bearings and i'll mail you (2) of them. surely Sweden has a bearing or two somewhere.
michael
Last edited by 9XTremist; Dec 16, 2010 at 07:51 AM. Reason: don't know my sweden from my uk
Old Dec 15, 2010, 11:52 PM
manuel v's Avatar
Joined Aug 2004
Carl
12,13 turns is for 20AWG.
14,15,16 is good for 21AWG. maybe 17turns.
to 3s lipo, 11Vots and GWS 10x6.
to 13 turns., 9473rpm,. 254 watts. 75% effy.
to 16 turns, 8188 rpm, 156 watts, 76.7% effy.
Manuel V.
lrk-torquemax diy brushless outrunner kit Ron van Sommeren Power Systems 2 Dec 22, 2011 07:45 AM
For Sale hexTronik 24gram Brushless Outrunner 1700kv tallflyer Aircraft - Electric - Power Systems (FS/W) 3 Jul 10, 2007 09:49 PM
English lrk-torquemax diy brushless outrunner site & mailing list Ron van Sommeren Electric Plane Talk 0 Sep 29, 2001 05:57 PM
E-fly-in&diy brushless outrunner meeting, Sept. 2nd, Winssen/Nijmegen,the Netherlands Ron van Sommeren Electric Flight Events 1 Aug 02, 2001 05:37 AM
diy brushless outrunner/LRK meet & E-fly-in, Sept. 2nd, Nijmegen, the Netherlands Ron van Sommeren Power Systems 0 Aug 02, 2001 05:32 AM
