Just posted some photo notes on half-parallel. Take a glance here:
http://www.rcgroups.com/forums/showthread.php?t=1249657 Dave |
USA, ME, Ellsworth
Joined May 2008
I'm finally getting a handle on using the eLogger. I got some better numbers this morning in testing on my recent 16T21AWG Delta rewind on my DAT-750.
The peak figures with a Great Planes PowerFly Slow Fly 10 x 4.5 prop is that it is pulling 22.75A, generating 231W, and turning 7,350 RPM. That was with a 4S A123 1100 mAh pack, the pack voltage started and 13.2V and pulled down to 10.1V under load. I did another no load test on it too, that produced 12,004 RPM at 12.95V for a Kv of 927. For some reason I didn't expect to get quite that much power out of this wind. Jack |
Jackerbes.
I think, your motor is 15Turn. becouse 927KV. maybe is the first 15T wind for this motor in the thread. Kev. I congratulate you for making a wind of 20t, 21awg. Today finishes a 19T, 21AWG, half parallel and it is quite difficult. I do not think he could turn around No 20. Now in this type of wound, I'm crusader floss all the teeth of the stator to hold wires in place. both this engine and the AX. Manuel V. |
Thanks Manuel,
I've tried 20T on a few other stators with no success. I've had to punt to 18T twice. The insulation thickness varies a lot, and that one had "Komodo thin" insulation so I went for it. I might nail the wires with some rubberized CA before I fly it... used cheap wire and it's tight on the hammers. Kev |
USA, ME, Ellsworth
Joined May 2008
So I have been counting every strand crossing the bottom as a turn including the ones that might not cross the top again because they may go off to start winding the next stator arm. Jack |
I did 3 motors back in October 2008. I did a pair for my USCG Hu-16 Albatross seaplane. It was 15T 23AWG wire. It uses opposite direction Master Airscrew 10X6 3 blade props. I did the other for Steve Shumates Fokker Dr-1 triplane. That had 15 T 23AWD wire with a APCe 13X4 prop. I am very happy with the power and performance of these motors. I think 15 turns has been a good performer for my use.
http://www.rcgroups.com/forums/showp...&postcount=226 **Neons** Bob |
Bob.
Do you know what is the KV in your 15 turns motors. pictures of my 19 turns. three layers. 9, 7, 3. Data. Not load. 11.37V, 9400 RPV, 1.31A, 826Kv. GWS 10x6, 11.69V, 8100 RPM, 13.90A, 75.5% effy. 162 watts. APC e12x6, 11V, 6900 RPM, 19.25A, 76.3%, 46oz. New test. APC SF 11 x 7, 10.8 volts, 6400 rpm, 28.8A. Manuel V. |
Manuel,
I have not ever checked Kv on my motors. I did not know how to do it. Even now I do hands on testing in the plane after a Whattmeter and postage scale bench test. I determin the prop that works best with amps and thrust relations on the bench then I go fly them. I am evidently not technical as some are here. All I can say is I throw a large prop very well on my Fokker Dr-1 triplane and the motor runs perfect. The twin also has great power for my use with the same turns. **Neons** Bob |
USA, ME, Ellsworth
Joined May 2008
Do any of you guys ever use these Strong Motors Winding Terminators?
http://www.strongrcmotors.com/Winding%20Terminators.htm I used one on my DAT-750 rewind and it worked out very nice. The hole in them is sized perfect for the bearing tube and the holes are large enough to take two or even three 21 ga. wires. I filed the mount a little bit shorter to make up for the thickness (0.025" or so) of the terminator. I left a short stub at the terminator and then soldered stranded wires onto the stubs. Really makes for a strong termination. A slight up angle on the stubs and the leads clear the mount nicely. Jack |
suggestions
I've rewound three of these motors (22g 18t delta), the first one didn't work(I've only wound 9 pole one direction wraps before) and I must have
screwed up something. The next two worked but they are cutting out at about 90% throttle. I'm swinging a 11/8 prop, the same prop I've been using on the factory wind with no problem It's not a low voltage cutoff, sounds more like a timing problem. The motors have plenty of power, out performs the stock. Suggestions
| Thread Tools | |
| lrk-torquemax diy brushless outrunner kit | Ron van Sommeren | Power Systems | 2 | Dec 22, 2011 07:45 AM |
| For Sale hexTronik 24gram Brushless Outrunner 1700kv | tallflyer | Aircraft - Electric - Power Systems (FS/W) | 3 | Jul 10, 2007 09:49 PM |
| English lrk-torquemax diy brushless outrunner site & mailing list | Ron van Sommeren | Electric Plane Talk | 0 | Sep 29, 2001 05:57 PM |
| E-fly-in&diy brushless outrunner meeting, Sept. 2nd, Winssen/Nijmegen,the Netherlands | Ron van Sommeren | Electric Flight Events | 1 | Aug 02, 2001 05:37 AM |
| diy brushless outrunner/LRK meet & E-fly-in, Sept. 2nd, Nijmegen, the Netherlands | Ron van Sommeren | Power Systems | 0 | Aug 02, 2001 05:32 AM |
