Old Mar 05, 2010, 12:34 AM
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Holy Hurricanes, 57oz!!! Manuel was spot on!
Thanks very very much Manuel! I've never seen that kind of fury on my test stand before; schtuff was blowing down from the top of my garage cabinets, planes came off their ceiling hooks... it was wild!!!
DT750-10Tx2-21awg-Y
APC 11x7e (29m/18.2C)
8556RPM/13.87V/27.43A/57.4oz/75.4%
That's already 94W heat, so no need to push any further trash my garage with a 1280hd. Efficiency was hanging in there pretty good at 380W though. A 12x6e is only slightly more load than an 11x7e at these RPM's, and that should make well over 60oz. I need to make a trip to my LHS for some more props now that I know this motor is a player. Also need to make something something big enough for this monster. Maybe a 90" 1/4scale slowfly, ROFL!
Kev
Truglodite is online now Find More Posts by Truglodite
Old Mar 05, 2010, 02:07 AM
Have a nice day! Kristjan
kristjane's Avatar
Slovenija
Joined Jan 2006
I also re-winded motors, used same turns as timocharis on first page of tread.
Motors will be on my tricopter for AP.
kristjane is offline Find More Posts by kristjane
Old Mar 05, 2010, 10:37 AM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Uh oh. "Gotta motor now I gotta make a plane" disease. It's getting serious...
Good to see the results come in positive! Nothing like 4-1/2 pounds of thrust to let you know the test stand is well built.
Dave
timocharis is offline Find More Posts by timocharis
Old Mar 05, 2010, 11:00 AM
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
Kev.
I have one foamie for your wind. (in construction)
Manuel V.
manuel v is offline Find More Posts by manuel v
Old Mar 05, 2010, 11:10 AM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Wow, that's nice looking work Kristjan. Have you rewound before?
Dave
Old Mar 05, 2010, 12:09 PM
kristjane's Avatar
Slovenija
Joined Jan 2006
@Dave
Thanks, I have done it in past. At least ten motors.
Kristjan
Old Mar 05, 2010, 08:17 PM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Originally Posted by manuel v View Post
Kev.
Manuel V.
Now that's what I'm talking about, awesome Manuel!
I was thinking something like that, but out of FFF, since I have a stack of sheets sitting around.
Kev
Old Mar 06, 2010, 01:24 AM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Don't need to dust my garage now...
Now that years of dust and cobwebs, from the top of my garage fluorescent fixtures, has been wiped off my bench:
DT750-10Tx2-21awg-Y
APC12x6e (29m/18.5C)
8370RPM/13.72V/28.73A/68.5oz/82.3%
That's no typo, it's 4.3lb, 394W, 70W heat, 4.9gm/W. That's from Badcock, DCalc SPC says 77.9%, which is 87W heat... right on the money for 1gm/W heat. The dt750 is finally showing it's cards. This foamie is going to have to be much bigger than I thought, LOL!
Kev
Old Mar 06, 2010, 02:23 AM
manuel v's Avatar
Joined Aug 2004
4.925 Watts /g for tork motor.
At this level of power, I would not trust the motor base.,
question would probably be to change the arrow and different engine mount.
Old Mar 06, 2010, 03:28 AM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Starting to look like a power motor more than a torque motor, isn't it?
Yeah, I was thinking the same thing, and those bearings won't last long at WOT, that's if the e-clip didn't pop off first.
Mounting it like that would take lots of load off the front bearing. I could just grind a new e-clip slot and flat spot for the grub screw on the stock shaft. So changing the shaft wouldn't be absolutely necessary; although I do hate the stupid threads.
Although, it would be cool to stick with the typical 3D foamy method so it looks just like a scaled up version. To do that I could just use a 4mm collet on the rear with the appropriate flat spots ground on the stock shaft.
Kev
Old Mar 06, 2010, 11:02 AM
I make bad look so good.
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Just reran my 1280HD with timing set to high. These are the numbers after the motor had been running about 1 minute.
GWS 1280HD
Volts: 14.71
Amps: 20.1
Watts: 292
RPM: 6518
I also took a temp reading after the motor was shut down. Highest reading was 204F.
SteveC68 is offline Find More Posts by SteveC68
Old Mar 06, 2010, 11:16 AM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
95C... that is waaay too hot.... you'll demag it if you keep that up.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Mar 06, 2010, 11:57 AM
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Yeah I think the 1280HD is way too much prop at this kv on 4S.
Old Mar 06, 2010, 12:29 PM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Those 1260 HDs would probably be great. Only place I've seen 'em is United Hobby City King though.
Dave
Old Mar 06, 2010, 01:03 PM
Dr Kiwi's Avatar
Joined May 2003
http://www.caliberhobby.com/propellers_reg.html [in 6-packs though]
lrk-torquemax diy brushless outrunner kit Ron van Sommeren Power Systems 2 Dec 22, 2011 07:45 AM
For Sale hexTronik 24gram Brushless Outrunner 1700kv tallflyer Aircraft - Electric - Power Systems (FS/W) 3 Jul 10, 2007 09:49 PM
English lrk-torquemax diy brushless outrunner site & mailing list Ron van Sommeren Electric Plane Talk 0 Sep 29, 2001 05:57 PM
E-fly-in&diy brushless outrunner meeting, Sept. 2nd, Winssen/Nijmegen,the Netherlands Ron van Sommeren Electric Flight Events 1 Aug 02, 2001 05:37 AM
diy brushless outrunner/LRK meet & E-fly-in, Sept. 2nd, Nijmegen, the Netherlands Ron van Sommeren Power Systems 0 Aug 02, 2001 05:32 AM
