USA, ME, Ellsworth
Joined May 2008
There is a chance that you have not actually bent anything, you might have just pulled the shaft forward in the inner races and now the bearings are pulled together too tightly.
Look at these two sequences to see what I mean: The right way to mount a prop: end of shaft---> nut + washer + prop + washer + nut <---magnet housing top{ The wrong way to mount a prop: end of shaft---> nut + washer + prop + washer <---magnet housing top{ The only difference in those two methods is that the nut that is closest to the magnet housing has been left off. That nut would normally be bottomed out where the threads end and the shaft becomes unthreaded. In the wrong method prop is resting on the housing and as the nut is tightened it can pull the shaft forward through the inner bearing races. The pulling forces on the shaft is restrained at the back of the motor by a Circlip and that pulls the bearings towards each other and that is probably creating the drag you feel. You may be able to relieve the pressure on the bearing by removing everything from the shaft, loosening the grub screw at locks the magnet housing to the shaft. That grub screw, incidentally, has probably slipped downwards on the shaft a short distance as the over-tightening happened. Use a close fitting straight shank (not! ball ended) hex wrench to loosen the grub screw, if you use a ball ended hex wrench or loose fitting wrench it will probably strip the hex socket in the grub screw. Just loosening the grub screw may provide some relief on the drag. If it does not, put the motor back in the mount, rest the mount on a block of wood that has a hole in it that is large enough to clear the Circlip. A hole that is about 5/16"/8mm or so is about right. That will put the shaft point upward and the motor restrained on the block of wood. Put two nuts on the very end of the shaft and lock them together to protect the threads on the end of the shaft. Now use a small brass hammer and give the nuts a gentle tap. If that relieves the drag you are done. In a normal motor there will be a slight amount of play that will let the magnet housing move up and down, like one or two thousandths of an inch 0.025-0.050mm) or so. Now you can replace the grub screw and you should put blue (not red!) Loctite on it when you do that. It is not a bad idea to upgrade the headless (1.5mm socket) grub screw with a button head screw that has a 2mm hex socket and the same 3-0.5mm thread. You can see one of those here: http://www.rcgroups.com/forums/showp...postcount=1394 And you can find them at the LHS in the Traxxas car replacement parts assortment or on eBay. I never mount props on the DTA-750 motors by clamping them to the shaft with nuts. It is just a poor choice for getting adequate clamping force on the prop hub. I use wobbly prop savers and Thera-Band prop- saver bands as seen in the attached photos. And the full story on fiitting and using prop savers and making the bands is in this thread: Prop Savers - Fitting, Using, Testing, & Making Thera-Band Bands - http://www.rcgroups.com/forums/showthread.php?t=1419378 I have hundreds of hours of flying time with prop mounted with those bands (using two or even three bands) and have not once ever lost a prop in flight. I hear the silliest stories from multi-rotor guys about how prop savers cannot be used because they cause vibrations, are not reliable or strong enough, and other silly reasons. Those are simply lame excuses. If you fit a prop saver as shown at that link, use two or three Thera-Band bands, and have a balanced prop, the chances of losing a prop in flight are very remote. The bands are cheap (a fraction of a cent to a few pennies at the most) and can be replace occasionally for further insurance. You have my sympathy on the lack of success on the search engine here. If you use it in the Advanced Search mode and make sure to set the date range for the search to Any Date... it will work a little better. But for most searches you will get better search results from google by using a search like "rcgoups.com dt700". If the above does not fix your problem, you may have actually damaged the magnet housing by deforming the bell. That will be harder to deal with. If you need help on getting the motor apart this thread will help: http://www.rcgroups.com/forums/showthread.php?t=1079423 Jack |
USA, ME, Ellsworth
Joined May 2008
If you remove the bearings and use a butane micro torch to apply heat on the inside of the bearing tube you can usually soften the adhesive and twist the stator off. The problem on these motors is usually that of getting a good grip on the tube to do that. I would probably put the mount on the tube and attach the mount to a metal plate with a hole in it that allows the heating. Clamp the plate in a vise and use a gloved hand on the stator. When it will rotate slightly slide it off. If you get a chance, show us your mount. it will be interesting. Jack |
Finland
Joined Jan 2013
I'll post photos when it's coming together if it ever will. The project is still in design and "can it be done stage". I think I need to order few more motors or some enamel wire cause i dont think those windings will like heating that much. But for gripping i could use lathe chuck and use turning tool to keep the stator still and rotate the chuck while heating. And all if the heating thing works.
USA, ME, Ellsworth
Joined May 2008
If you heat the inside and quit as soon as it loosens it won't normally put much heat into the windings.
But most of the time when I do that the windings are either already gone or going to be stripped for rewinding. You're a lucky guy if you have a lathe to use. Do you have the newer motors with the 9mm bearing tubes? On those I think you could move the shoulder on the 9mm portion a little closer to the motor to take a little bit off of the height. I only have the original version moto with the 8mm tube. You can see them both here: http://www.rcgroups.com/forums/showp...postcount=1112 Jack |
| Thread Tools | |
| lrk-torquemax diy brushless outrunner kit | Ron van Sommeren | Power Systems | 2 | Dec 22, 2011 07:45 AM |
| For Sale hexTronik 24gram Brushless Outrunner 1700kv | tallflyer | Aircraft - Electric - Power Systems (FS/W) | 3 | Jul 10, 2007 09:49 PM |
| English lrk-torquemax diy brushless outrunner site & mailing list | Ron van Sommeren | Electric Plane Talk | 0 | Sep 29, 2001 05:57 PM |
| E-fly-in&diy brushless outrunner meeting, Sept. 2nd, Winssen/Nijmegen,the Netherlands | Ron van Sommeren | Electric Flight Events | 1 | Aug 02, 2001 05:37 AM |
| diy brushless outrunner/LRK meet & E-fly-in, Sept. 2nd, Nijmegen, the Netherlands | Ron van Sommeren | Power Systems | 0 | Aug 02, 2001 05:32 AM |
