Old Feb 24, 2008, 11:47 AM
DrEvil is offline
Find More Posts by DrEvil
Plane and multirotor's - FPV
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
Hi there dave
I am quite a newbee , so speed is not the issue, but desent scale speed and , most of all plenty thrust is important.
Will a 9" give me thrust to spare ??
This 10x10" is a APC-E , i also have a 10x8,5 4blade noname, butt i guess it works best on the ground
Thanks for the quick reply...
Kai
' And up she goes '
DrEvil is offline Find More Posts by DrEvil
Old Feb 24, 2008, 11:55 AM
timocharis is offline
Find More Posts by timocharis
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Try the 1170 to begin with and adjust from there. It's a very thrusty prop. The 1080 is an okay choice if you think the 1170 is too slow... or maybe the 10x6 or 10x8 APC.
Dave
timocharis is offline Find More Posts by timocharis
Old Feb 24, 2008, 12:24 PM
DrEvil is offline
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
Dave
Ok, i will do a Amp. draw mesure later this evening with the 11x7GWS.
I want to ceep it its most effectiv range.
But do you think a 10x10 is too much for the motor, or does it get inneffectiv ?
Sorry about my English...Not perfect
How about 4cell, will it be able to run a 9" or a 10" ??
I have several 2cell i can conect in series.
Thanks... Kai
Old Feb 25, 2008, 08:11 PM
shawn595 is offline
Find More Posts by shawn595
shawn595's Avatar
United States, VA, Bedford
Joined Sep 2006
The wire I got from Dave just showed up my mailbox today but before I rewind I did a little testing first to get a baseline.
Here's my result:
GWS 10x6 HD; Loong Max 3S 1300 battery; 18T Delta 22 awg dLRK
7050 rpm: 9.46 amps, 10.5 volts; 634grams/22.36 ounces thrust
Note that my efficiency numbers are calculated, not measured and I can't give an effeciency result because Badcock won't calculate them.
RPM was measured using a Tower Hobbies Digital Mini-Tach and amps and volts were measured using a Watt's Up meter. The test was run twice indoors and an LED flashlight was suspended in front of the prop while the tach took a reading from behind the prop. The ESC is a Turnigy Plush 18.
Interpret these results as you see fit and make suggestions as necessary. I'm very green to testing motors and would rather be notified of a flaw in my setup than provide incorrect numbers. (Note picture of testing setup below.)
-Shawn
shawn595 is offline Find More Posts by shawn595
Old Feb 25, 2008, 08:39 PM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Drive Calculator will give an efficiency/thrust reading for the 1060. It says you just got:
25.18oz thrust @ 82.4% efficiency. I find DC to be just a hair optimistic on thrust and therefore a hair optimistic on efficiency. But not a whole lot, and sometimes it hits the ball cleanly. Badcock tends to be a bit low on the 1060, probably because of using older Dr Kiwi prop data.
Dave
Old Feb 26, 2008, 08:01 AM
shawn595 is offline
shawn595's Avatar
Joined Sep 2006
Thanks for the info Dave. Sounds like my numbers are realistic enough so that means I have enough of a baseline to compare my rewind too.
I'll look at Drive Calculator too. It'll be nice to have something to compare Badcock to.
-Shawn
Old Feb 28, 2008, 12:09 AM
manuel v is offline
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
Finally came my BW with steroid HXT DT750. and now need 21 or 20 AWG
I am doing a little EP foamy for the. But I leaving something this big. So I think that would put 2 engines together in tandem.
Manuel V.
manuel v is offline Find More Posts by manuel v
Old Feb 28, 2008, 11:14 AM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Manuel, mui macho! Carramba!
Dave
Old Feb 29, 2008, 11:04 PM
jkarnacki is offline
Find More Posts by jkarnacki
USA, CA, San Carlos
Joined Nov 2007
Manuel, what's the plane on the bottom left w/ the blue cockpit? Looks spiffy and I'd like to make one : ]
- Jeff
jkarnacki is offline Find More Posts by jkarnacki
Old Mar 01, 2008, 12:52 AM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Jkarnacki.
The plane is a Skeeter with flat wing of EP foam 1/2 inch.
9 oz. with Blue wonder Kit 17T Star and 3s 500ma. GWS 9x5.
http://www.rcgroups.com/forums/showthread.php?t=797010
original plane: with plans.
http://www.rcgroups.com/forums/showthread.php?t=360600
Manuel V.
Old Mar 01, 2008, 12:17 PM
shawn595 is offline
shawn595's Avatar
Joined Sep 2006
18T of 21 awg
I finally got the 18T of 21 wound up and tested. This definitely isn't my prettiest wind but it does run and the results are.. well.. judge for yourself:
GWS 10x6 HD; Hextronic D9 3S 1300 battery; 18T Delta 21 awg dLRK
7260 rpm: 9.8 amps, 10.6 volts
So there's an extra 200 rpm with about half an amp and 1/10th of a volt increase. It would have been more interesting to run this test again with the same Loong Max battery I used in the first test but unfortunately that battery is no longer with us. Anyway, using Drive Calculator's Simple Prop Calculator I came up with 758 grams of thrust (26.73 ounces) with an efficiency of 85.3. This mimics the slight improvement that was shown by Dave's calculated numbers below.
So it's only slightly better than the 18T of 22 and honsetly I'm not so sure it's worth the extra trouble. 18T of 22 is a easy wind. Almost too easy really. And the difference between 22awg and 21 awg with regard to amount of effort to wind it is amazing. You just don't get this difference in workabilty between the smaller gauges in only one step up. So I'll leave it up to you to decide if it's worth the extra effort. It would be really hard to justify the extra effort using the numbers shown above.
-Shawn
Old Mar 01, 2008, 12:49 PM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
First let me say that's a Kick Grass wind without any Gr needed. Exactly how a packed wind should look -- the best motors almost never look perfect because you have to tickle the wire a little bit for a full fit. (Compare to "am I awake yet" 22g wind...)
What's with that chip? Did I sell you some crap wire?
Love the result. It's so close to what I saw with the 22g that I'm darned glad I gave up on the motor when I did. My opinion? Definitely not worth it. I know what you just went through, and it's a great experience. You should be proud of yourself! But with my clacky hardware (I got a bum motor! The dirty rats) I'm certain I'd have been getting nowhere. Thanks for confirming.
That motor makes no sense to me at all. Manuel nailed it cold: wind it with anything, give it the right watts in, and it will pull a tugboat.
At any rate, I think that's a beautiful job.
Dave
Old Mar 01, 2008, 01:37 PM
shawn595 is offline
shawn595's Avatar
Joined Sep 2006
Dave,
Thanks for the compliments! It was definitely one of my toughest winds and there's no doubt that it took the longest. Still, it's done and my fingers are happy for the rest.
I chipped that wire myself. I have the standard dLRK pattern committed to (muscle) memory but still don't have the Delta variant fully memorized yet. As you can guess, I wound two teeth using the standard version and had to unwind and rewind them to get the correct result. That's probably where the chip make from. Needless to say, I'm happy it even runs because if that chip had been anywhere else it could have been a show stopper.
Oh, I appreciate the deal you gave me with the wire. I'd still be waiting another week and or more for it to arrive from AllTronics. Those extra wing saddles are comforting to have in the hobby box too.
This motor is certainly a conundrum. It's efficient as is but refuses to show any improvements. Whether that's comforting or frustrating defends on your point of view but I'm currently going with the latter. That'll probably change after a flight or two with it though..
I do have some GWS 11x7 *D props on the way and I'll give them a go when they arrive. I don't expect any miracles but it'll be interesting to see how it compares with the 10x6. I don't really need any more power so I may just settle for using the 10x6 and going with a 3S 800 mah lipo. Half power (crusing speed) requires approx 4 amps so that's certainly not out of the question on a calm day.
-Shawn
Old Mar 01, 2008, 03:59 PM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Basically I found it frustrating too. Join the club! I do think the 800 3S sounds like the way to go....
Dave
Old Mar 01, 2008, 06:51 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Shawn
Very neat winding. paint the chip with nail paint.
Today, i wind a 17T 21awg. horrible wind but its working.
No load, 9200 rpm, 11.40V, 1.4A. 3s 900ma. KV 807.
GWS 10x6, 7300rpm, 10.8V, 10.9A, 3s1600.
GWS 10x6, 7600rpm, 11.4V, 12A, 3s1300
APC 10x7, 7500rpm, 11.72v, 14.3A, 3s 2250
APC 12x6, 7100 rpm, 11.44V, 18.3A, 3s 2250, 47 oz, 83.5%
Im very happy. with this motor,
Is very cheap remplace for E-flite 480-920 and only with 209 Watts,
Manuel V.
lrk-torquemax diy brushless outrunner kit Ron van Sommeren Power Systems 2 Dec 22, 2011 07:45 AM
For Sale hexTronik 24gram Brushless Outrunner 1700kv tallflyer Aircraft - Electric - Power Systems (FS/W) 3 Jul 10, 2007 09:49 PM
English lrk-torquemax diy brushless outrunner site & mailing list Ron van Sommeren Electric Plane Talk 0 Sep 29, 2001 05:57 PM
E-fly-in&diy brushless outrunner meeting, Sept. 2nd, Winssen/Nijmegen,the Netherlands Ron van Sommeren Electric Flight Events 1 Aug 02, 2001 05:37 AM
diy brushless outrunner/LRK meet & E-fly-in, Sept. 2nd, Nijmegen, the Netherlands Ron van Sommeren Power Systems 0 Aug 02, 2001 05:32 AM
