Dave: Sadly, I think you're right on both counts. And now that I've actually my Slow Stick with the "Big Wonder" I have to reconfirm that it's really quiet. Not entirely silent but no growling either. I'm still on the fence about getting another one esp now that I know there's an off chance that I might get a loud one. I certainly don't have another model that it'll fit in but it's an intrigueing motor all the same. If it was 15 grams lighter I'd work towards an efficient 9x4.7 wind (if one even exists) and mount it in the nose of my Mini-Mag.
NX: The flight was good but it was a little too windy for flying a Slow Stick today. There were no crashes but it's hard to get a feel for the plane - let alone trim it for level flight - when it's that windy out. Still, it was a good time even if it was a bit cold out and I'm very happy how well the SS flew. I have more than enough power to do inside loops at 3/4 throttle. And honestly, I was suprised at well the SS absorbed the power. I have a Blue Wonder wound 14T of 25 on my Pico Stick and even short bursts of WOT cause all kinds of structural drama with that flimsy little thing and I've done a lot to strengthen the wings on it. GWS has done a lot to reinforce the main wings of the Slow Stick lately - my kit had an extra brace in it that added a lot of rigidity to the main wings - perhaps they'll do make changes to the Pico Stick as sell. At the very least maybe they'll make the wing mounting brackets out of a stronger plastic. I did a tight outside loop with my Pico Stick once and it fluttered back to the ground in three seperate pieces... ![]() -Shawn |
I did some outside loops with mine and it didn't fall apart, but the fibrillations were definitely dramatic. My favorite "outsider" was unsuccessful: I did a half outside to inverted and it just wouldn't go any further. By the time I realized it was stuck, I was too low to try to drop it back into upright. So with the wings fluttering like a spastic sparrow, I slowly landed it in the grass upside down. Struck me funny at the time, anyway. Dave |
I just ordered Hex. 750kv also. I built a Fokker DR-1 and I have a new BP Hobbies motor in it.BP's BL2217/9 outrunner with projected 2lb. thrust. Very nice motor I love it. It is light weight too. I had to add 2.5 ounces to the nose. This Hextronic shows more thrust. I get about 32 ounces with a 11x3.8 APC. I think the added weight of the Hextronic will give me same or more thrust and best of all I can remove some lead nose weight out of the plane. The noise may also be benificial in the old timer. What is the final synopsis of the rewind of the Hex 750? Should I leave it alone or rewind it.? Is it worth the effort for a slight gain?
**Neons** Bob |
Bob,
I don't think anyone but yourself can really say if a rewind is "worth it" or not. Me personally, I rewound mine for the two main reasons. The first was because I wanted to see what it was like to rewind a motor in the dLRK for Delta pattern. The second was because I just couldn't stand to look at the bird's nest of wires they had going on behind the bell. It was a total wreck of wires and it didn't need to be like that. And no, I'm not trying to say I'm an elitist or that my winds are the best - far from it. I just couldn't stand to leave the motor wires that messy even if I knew that the performance wouldn't improve by any noticable amount (at least not while in the air). So there you have it - if you don't care what the winds look like then save yourself the trouble. There may be other reasons for rewind the motor - a broken wire would be a good one - but there's no reason to rewind it until that happens if the bird's nest doesn't bother you. Hope the helps. -Shawn |
Yes, good point here. I will leave it the way it is and try to get what I can out of it. I like the report in the thread. If it breaks a wire I will also rewind mine to save it. I have done a few recent TowPros and my own home built CDROM years ago. At these prices it sure looks like a nice bang for the buck. I am eagerly waiting to try one. Thanks
**Neons** Bob |
We can not say that the changes I make Timocharis were in vain.
Now is a better engine with wire thickest and a winding-18T evenly in each tooth. In addition there is an error in their early data. 6446 produced 1132g or 39.9oz. Stock motor. 6666 produced 1226g or 43.2 oz. Rewound motor. Representing an increase of 3.4 oz. With the same amperage and better efficiency Manuel V. |
Actually, that's a pretty good story and I do wish that in similiar experiences I'd been so lucky. This plane is so easy and slow to fly that it encourages bad behavior. The last time I tried to do an outside loop it was around a soccer goal (no net installed of course). I got almost 180 degrees around the soccer goal but was quickly running out of airspace on the back side. I was determined though and gave full throttle and more elevator... It wasn't pretty. In other news, I just ordered some 20, 21, 24 and 27 guage wire from AllTronics and will probably order a DT700 from UH soon. Although it might seem really silly at first to spend so much time trying to optmize the motor for a Slow Stick I'd like to see if it's possible to do 19T of 20awg delta. Whether overall efficiency will improve or not is another matter but aesthetics call for a thicker wire. Although I've yet to do any testing with the 18T of 22awg delta yet it certainly "felt right" in the plane with a 10x6 *D prop on a 3S 1300 Loong Max battery. So whatever I'm getting now is my "target" but if I can do it using a little less power that would be good by me... -Shawn |
Dave |
Honestly, I've never seen anything bigger than 22 though so chances are it'll be good for a laugh when it arrives. Unfortunately, that arrival date just got pushed back a bit because the lady at Alltronics just called and said the 27awg I just ordered is out of stock and won't be in for a couple weeks. I'll let you guys know how it turns out when it does though.-Shawn |
Thanks Dave - that worked out very well.
In other news, I just got back from flying my Slow Stick and the 18T Delta really suits this model perfectly. Vertical flight with the 10x6 *D is slow but nearly unlimited - which is not what this plane is about - and slow cruise is between quarter to half throttle. So it's perfect. And I had a close call today too - the last flight of the day ended with what was more of a stall at 5ft than a landing and I broke the prop. My initial thought was that I also bent the shaft or trashed the bearings but thankfully neither turned out to be true. So while this motor might not be the paradigm of rugged durability it's quite servicable if you don't abuse it. I'm really happy I bought it. -Shawn |
10x10"
Hi all !
I was wondering if anybody have tested this motor with a 10x10" APC propp ?? I am about to complete a 1\9 scale depron Spit from H-J plans and have a 11x7 HD GWS but i am not shore about pichspeed, AUW will be aprox 750-790g (28oz) and WS 48". Thanks ! Kai `And up she goes.....` |
| Thread Tools | |
| lrk-torquemax diy brushless outrunner kit | Ron van Sommeren | Power Systems | 2 | Dec 22, 2011 07:45 AM |
| For Sale hexTronik 24gram Brushless Outrunner 1700kv | tallflyer | Aircraft - Electric - Power Systems (FS/W) | 3 | Jul 10, 2007 09:49 PM |
| English lrk-torquemax diy brushless outrunner site & mailing list | Ron van Sommeren | Electric Plane Talk | 0 | Sep 29, 2001 05:57 PM |
| E-fly-in&diy brushless outrunner meeting, Sept. 2nd, Winssen/Nijmegen,the Netherlands | Ron van Sommeren | Electric Flight Events | 1 | Aug 02, 2001 05:37 AM |
| diy brushless outrunner/LRK meet & E-fly-in, Sept. 2nd, Nijmegen, the Netherlands | Ron van Sommeren | Power Systems | 0 | Aug 02, 2001 05:32 AM |
