![]() Again cheers for the help guys! Well I've eventually got all my kit together and I've stripped my first motor down, just a quick question, (sorry if its a bit dumb but these will be my first attempts at motor winding)..is this the correct pattern to wind dLRK? Thanks Ian |
Here's a link to Dave's (timocharis) excellent dLRK winding turturial. http://www.rcgroups.com/forums/showthread.php?t=736580 The tutorial for the Delta variant starts on 39. -Shawn |
My 18-turn finally saw air time Saturday at our annual Slow Stick Stuffup. Handled itself very well indeed. Good power and very durable... here's a photo showing the durability test. Note that the fuse is bent first toward you, then back toward the tail. That was a heck of a crash! Then the whole mess fell from about 100 feet straight to the dirt.
Motor runs fine! Dave |
Manuel
That is a pretty plane with classic lines. Must look great up in the air. The motor is a nice power unit for the plane. You must get many enjoyable flights with it. I have this motoat present flying 3 of my planes. I just ordered 2 more. I have 7 of these motors now. Three have been wound also with 16 turn 22AWG wire. One is in my 44oz. Fokker Dr-1 Triplane with a 13X4 APC-e prop. It is now perfect with this setup. I am very happy at this level. Good luck and thanks for your help once again. **Neons** Bob |
Dave.
Pretty good motor. Built like a rock. I have seen some of the Stck fuselages bend. Yours was extra bent. This Slo-Stick some day will be a classic. I bet it was a good seller for GWS. I see the newer ones have thicker tail feathers and fibreglass fuselage. I even saw a carbon fuselage replacement on the market recently. **Neons** Bob |
New wind, new (to me) plane
I bought a Typhoon 3D off a fellow RCG groups member a few weeks ago and finally got around messing with it yesterday. The plane originally came with an inrunner and a gearbox but I thought it was the perfect size for the DT750. I was right - the Hextronic is about the same weight as the inrunner and gearbox combo and is a perfect match for the model. I've rewound mine to 17T of 21awg Alltronics wire and am using a GWS 12X6 HD prop. I still wouldn't call this a 3D setup though and that's fine with me. I bought it with the intention of making it an aerobatic sport flyer and got what I was looking for.
Unfortunately, I can't give any any real test data with this setup yet though because I just moved last month and still don't a thrust stand yet. I've been looking at the one BPHobbies sells but don't think it's big enough for 200 - 300 watt setups. A quick reading from my WattsUp gives just under 22 amps static though and the plane has unlimited vertical with this powertrain combination. In case you're wondering, the mess in between the prop and the bell of the motor is for clearing the cowl of the plane. And for you motor p0rn fans, I've attached a couple photos of the 14T of 20 awg wire I did. It still hasn't been tested yet but the plan is to use it with a GWS 10x6 HD and the new A123 racing 1100 mah cells in a 3S pack. That should be a pretty petty setup for my little Super Cub. I'll report back after testing is complete. -Shawn |
Hi Shawn,
That Typhoon looks like it is going to be a fun sport flyer. The windings on your motor look great. I am still havivg great success with my motors also. I bought 2 more and they tested pretty good stock. I now have 7 of them and using 5 so far in different applications. 3 have been rewound. Good luck **Neons** Bob |
Versailles, France
Joined Jul 2008
Hi,
After reading all the good things about this motor here, I decided to order one a couple of weeks ago. I got it delivered yesterday with an APCe 12x6 prop (well, the "APC-style" prop sold at HC) and tested it today. It managed a cool > 6400rpm on a freshly charged Zippy 3S 1800mAh battery pack. ![]() The ESC is a Super Simple Programmable 30A and apparently it is working well with this motor/battery combo. After 35s WOT both the motor and ESC were barely warm, battery was cold. 6400rpm on this prop I believe works out to nearly 40oz. (1100g) thrust which is exactly the kind of thrust I need for the 25oz. (720g) Depron Regal Bipe (plans by Kaos2) I am building. ![]() Thanks to Shawn for answering my questions about this motor in a PM I shot him! BTW is there anything I should be aware of concerning this motor, or pay attention to? That's the paranoid side of me, I have to worry in advance...
| Thread Tools | |
| lrk-torquemax diy brushless outrunner kit | Ron van Sommeren | Power Systems | 2 | Dec 22, 2011 07:45 AM |
| For Sale hexTronik 24gram Brushless Outrunner 1700kv | tallflyer | Aircraft - Electric - Power Systems (FS/W) | 3 | Jul 10, 2007 09:49 PM |
| English lrk-torquemax diy brushless outrunner site & mailing list | Ron van Sommeren | Electric Plane Talk | 0 | Sep 29, 2001 05:57 PM |
| E-fly-in&diy brushless outrunner meeting, Sept. 2nd, Winssen/Nijmegen,the Netherlands | Ron van Sommeren | Electric Flight Events | 1 | Aug 02, 2001 05:37 AM |
| diy brushless outrunner/LRK meet & E-fly-in, Sept. 2nd, Nijmegen, the Netherlands | Ron van Sommeren | Power Systems | 0 | Aug 02, 2001 05:32 AM |
