hexTronik DT750 Brushless Outrunner 750kv
Okay, I laid out the big bucks and got one of these new big motors from HobbyCity DoNotSayUnitedHobbiesOrGetSuedByJerkCo. You can see their specs at:
http://www.hobbycity.com/hobbycity/s...idProduct=6247 First, I'll toss out some numbers at you. The Kv computed out to more like 800 than the 750 indicated, but this should not be a surprise. The stator was probably supposed to be wound with 18 Turns of 8-strand 34swg wire, and indeed five of the teeth were. However, those other three proved a little challenging for our overworked winding slave, so they settled for 17, 16 and in a fit of pique, a mere 15 turns on one tooth. So I got a little bit "hotter" wind than intended. Nevertheless, here are the stock numbers with Rod Badcocks calculator giving the thrust and percentage figures. The thrust is very close to what I observed on the stand, so I'll concur with those numbers. Hex DT750 Stock 8strand 34swg ~18 Turn GWS 10x4.7sf TP 1320 3S: 7210 rpm @ 10.76v/13.96a 962 grams 34 oz/thrust 83.9% Efficient APC 11x4.7sf TP 1320 3S: 6446 rpm @ 10.5v/17.3a 1218 grams 43 oz/thrust 81.6% Efficient Make of that what you will, it's quite good compared to almost everything else I've tested with those props, but weighs about .7oz more, so that should be no big surprise. What is surprising is it does so well with random winding. Makes me curious what it will do if wound somewhat properly. |
One economic remplacement for E flite 480-920.
http://www.rcgroups.com/forums/showt...ght=blue+motor I like this motor. I thing that one APC 12x6e is a good choice and 6446 rpm is over rpm for APC 11 x 4.7 Manuel V. |
Joined Aug 2007
On the contrary , not a waste of time , from my point , one point is that amazing same result , data wise Whats your opinion on heat shedding , will the birds nest shed heat better than the 22g or not , I would go for the 22G, someone will know this
I guess my take is heat just isn't going to be much of an issue. PeakEff thinks the motor as it stands is fine to 18 amps and my impression is that's correct. I also suspect anyone who feels the need to push harder might want to consider blowing a little more than $11. I'd feel comfortable running in that range.
Hey, Manuel: I finally got an "e" prop to balance! All it took was patience and a hand drill. Wow that thing was wayyyy out. Dave |
So far all I've learned is 15-turn Delta and 16-turn Delta (both 21 awg) show considerably less efficiency than the 18 Turn. Okay results, but nowhere near as good.
Weird. One more experiment (9 or 10 turns Wye to see if that makes any difference) and I'll just put it back to stock. Messing with this motor has been extremely unproductive! Dave |
Timocharis.
That data got these windings and propeller used. I will dare to infer a bit about these windings. Only theory. Since I had come to test my motor. It is clear that this motor in the area of 185Watts input gives us an efficiency above 80%. If rewound to 15 o 16 turns delta. Give us a Kv. About 936 and 837. To continue to sustain the level of efficiency, I think we should continue in the range of 185Watts input. And in that case for the 936kv, 15T. A propeller APC 10x5 and GWS 10x6 would be very small. And a APC 11x5.5 or APC 10x7 be very large. In this range of any type SF us serve as RPM exceeds limits. Since it be run around 8000rpm. In any case, insisting, only one APC 10x4.7. With 16T delta and 837kv. A propeller APC 11x5.5 be run in rank. The GWS 11x7 be very large. For more of this engine is needed to push a level of 70% efficiency. Manuel V.L |
| Thread Tools | |
| lrk-torquemax diy brushless outrunner kit | Ron van Sommeren | Power Systems | 2 | Dec 22, 2011 07:45 AM |
| For Sale hexTronik 24gram Brushless Outrunner 1700kv | tallflyer | Aircraft - Electric - Power Systems (FS/W) | 3 | Jul 10, 2007 09:49 PM |
| English lrk-torquemax diy brushless outrunner site & mailing list | Ron van Sommeren | Electric Plane Talk | 0 | Sep 29, 2001 05:57 PM |
| E-fly-in&diy brushless outrunner meeting, Sept. 2nd, Winssen/Nijmegen,the Netherlands | Ron van Sommeren | Electric Flight Events | 1 | Aug 02, 2001 05:37 AM |
| diy brushless outrunner/LRK meet & E-fly-in, Sept. 2nd, Nijmegen, the Netherlands | Ron van Sommeren | Power Systems | 0 | Aug 02, 2001 05:32 AM |
