Old Nov 26, 2007, 05:46 PM
dvlflyr14 is offline
Find More Posts by dvlflyr14
I'm ahead of Rob
dvlflyr14's Avatar
Tempe, AZ
Joined May 2005
LiPo Cold Weather Performance
I understand that cold weather does not appreciably reduce the total capacity of a LiPo pack but it certainly has an impact on the voltage that can be delivered under load at a given point in time. I am looking to see if anybody has data, such as voltage vs. time graphs at various discharge rates (1C, 5C, 10C and 15C) at different temperatures (100F/40C, 75F/25C, 50F/10C and 32F/0C) for a LiPO Cell or one of the general sized packs (2S 1200, 3S 1200, 3S 2100, etc) that we use.
The reason I ask is because as we get into the colder months of the year we all notice that our LiPo's performance seems to fall off. People are running into LVCs, lack of zip in the plane or heli, etc.. It seems some of us are only getting 2/3s the performance or flight time that we had in the warmer months. I have spent a little time looking for this data on the web but no where have I been able to find it.
thx,
Dan
dvlflyr14 is offline Find More Posts by dvlflyr14
Old Nov 26, 2007, 05:53 PM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
if U voltage stabilize them at their respective 2S or 3S , 7.4 or 12.6 levels, U should'nt have any problems
I use a VOLTAGE CLAMP for this purpose
my packs hold a charge indefinitely and PUT OUT when I need it
hall woo is offline Find More Posts by hall woo
Old Nov 26, 2007, 06:19 PM
oceansfiftyseve is offline
Find More Posts by oceansfiftyseve
Joined Jun 2004
I suppose in southern california you have no idea what he is talking about...Anyway, when it is cold I notice that the initial power is down but once the pack warms up during the cycle the power comes back. I have not noticed any loss in duration though.
oceansfiftyseve is offline Find More Posts by oceansfiftyseve
Old Nov 26, 2007, 06:31 PM
Chophop is online now
Find More Posts by Chophop
Not like poor old Ibzan
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
I have a Walkera 4 that has the battery on the bottom, exposed to the 25*F air I fly in. The batteries chill too much to deliver full capacity, and I read It can damage them the same as >100% discharge. I used some foam sheet from the Hobby Lobby the ladies shop at to make a battery case. Now they heat to about 80*F.
A graph I saw, maybe at FMA Direct or Kokam showed a 2100mah lipo is only able to deliver about 1600 mah at about 25*F.
Better look into it.
CH
Chophop is online now Find More Posts by Chophop
Old Nov 26, 2007, 07:47 PM
fly4fun is offline
Find More Posts by fly4fun
Joined Jun 2001
AZ and cold weather. Where and when.
fly4fun is offline Find More Posts by fly4fun
Reply With Quote  (Disabled)
Old Nov 26, 2007, 07:49 PM
wilscor41 is offline
Find More Posts by wilscor41
Progress not Perfection
wilscor41's Avatar
Palmdale, Ca.
Joined Dec 2005
Flagstaff in January
wilscor41 is offline Find More Posts by wilscor41
Old Nov 26, 2007, 08:00 PM
fly4fun is offline
Joined Jun 2001
ok you got me there
Old Nov 26, 2007, 08:03 PM
wilscor41's Avatar
Palmdale, Ca.
Joined Dec 2005
Anytime, (gotta love this site)
Old Nov 27, 2007, 08:47 PM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
Cold batteries!
My daughter complained her car started sluggishly.
Temperature has recently dropped into 30s.
Time to replace her car battery.
Cold weather may not affect the voltage,
but it will affect electrolyte ability to pass current.
This is true for all types of cells.
Leave your alkaline powered flashlight out in freezing weather, then try to use it.
Dismal.
The workaround for some is to keep the pack in an inside pocket of your jacket until ready to fly. Could also restrict airflow to pack when in fuselage.
rick.benjamin is offline Find More Posts by rick.benjamin
Old Nov 27, 2007, 10:28 PM
BEC is online now
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
I was flying my Stevens Aero SHAFT (review in progress) late Sunday afternoon in 45 degree air. The SHAFT has a pretty good battery ventilation system built in. As such, my flights were shorter before the LVC cut in than when flying at 15-20 degrees higher temperatures. The difference is only 10-15%, but if it were freezing out it would have been much more dramatic.
I was flying with an EagleTree logger and had ESC and motor temps that never got above 65 degrees. These were noticeably lower than the prior flights on a warmer day. I should put a sensor on the battery next time I go out and see what it does.
In general in the cool weather I recommend getting the battery out of the prop blast. Then its natural tendency to warm under discharge will keep it working pretty well once you start to fly. For this airplane I probably ought to block the air inlet on the nose when flying in the winter.....
BEC is online now Find More Posts by BEC
Old Nov 28, 2007, 06:40 AM
Chophop's Avatar
Joined Sep 2006
BEC, I don't know what your LVC is set for, but you should average your flight time and try to land at 80% discharge. I use a Walmart timer to come back slightly under 80% discharge with 3.8v/cell average open terminal voltage. Seems to be working, I am over 150 flights on a battery people are saying dies at 50 cycles, a Megapower 2100 15C, and it seems as strong as new, and almost kicks as hard as a TP2100 with 90 cycles.
CH
Old Nov 28, 2007, 08:29 AM
wolw is offline
Find More Posts by wolw
<- Balsa flies better ->
wolw's Avatar
Gustafs, Sweden
Joined Feb 2006
Until you tried different conditions and different type of aircraft you're pretty much in the blue.
Winter flying with temperatures ranging between -5C/23F - -15C/5F takes a lot of different measures to be possible. A lot of trial and error. Fly, measure motor and LiPo temperature until you get a "mental template" (or simply write it down ) for what's needed in a surtain model type.
The lower the amp draw the more difficult it gets as a high amp draw at "normal temperatures" usually involves special air intakes that you can plug when it gets cold. The batteries is kept in the pocket or in a friggo box until flight and the high amp draw will keep them warm during flight.
My experience is that trainers and thermal E-gliders are the most difficult ones to get a successful winter flying setup with, a friggo battery bay and a "pocket pal" usually does the trick.
Anyone who thinks 5 months of winter with snow is exotic can PM me for a "house swap", SE Asia/Australia or Florida preferred, kids and wife not included
Peter
wolw is offline Find More Posts by wolw
Old Nov 28, 2007, 09:08 AM
Chophop's Avatar
Joined Sep 2006
I have been trying to find that graph, I am not severly schizo but it did state the reduction in capacity. I am finding conflicting statements about the situation so in order to settle my logical lobe, I am assuming the low discharge capacity is still there and you can draw 2000ma SLOWLY from a cold 2000ma battery. So that brings me to assume the chart implies that you get an EQUIVALENT reduction in useable high discharge capacity. That would serve as a flight time prediction tool.
CH
Old Nov 28, 2007, 10:09 AM
reylf_gnijieB is offline
Find More Posts by reylf_gnijieB
Beijing, China
Joined Nov 2006
I'm pondering these same questions myself. Beijing gets well below freezing in winter.
Maybe going from 2 to 3 cell packs in winter might make up for lower performance?
what do you guys think?
reylf_gnijieB is offline Find More Posts by reylf_gnijieB
Old Nov 28, 2007, 10:48 AM
mrhook is offline
Find More Posts by mrhook
Joined Apr 2007
This is from a battery manufacturers specs, "Lipo batteries will experience a 30% temporary decrease in capacity at temperatures below 32 deg. F. Flying in extreme cold weather should be done with great care. never expose them to temp. below -4 deg. F." and i have found this to be true when flying in idaho.
mrhook is offline Find More Posts by mrhook
Discussion LiPo and Cold Weather BOING Mini Helis 2 Jan 24, 2007 02:28 PM
Cold Weather Performance On Brushless Motor rdelrosario Flying Wings 3 Oct 23, 2004 02:27 PM
LiPo and cold weather... Bad performance issues? pwkpete Batteries and Chargers 2 Nov 30, 2003 06:47 AM
Lithium cold weather performance Aviron Batteries and Chargers 2 Nov 22, 2003 01:05 AM
Lousy performance in cold weather? JensJakob68 Electric Plane Talk 12 Dec 21, 2001 12:41 AM
