Nov 27, 2007, 07:50 PM
San Diego, CA, USA
Joined Nov 2001
Originally Posted by dessertracer
Thank you very much. Where could I get more information on the specs of this adapter and the procedure for installing the 15xx gearbox on an 11xx motor? I'm assuming there's a special pinion gear required--would that be the factory installed hot-press one or a set-screw one? Or perhaps could the motor be purchased with this setup pre-installed?
You can order the 11 series motors with the larger gearboxes installed.
Chuck
