Old May 04, 2001, 11:57 PM
mrebman is offline
Find More Posts by mrebman
Cincinnati, Ohio USA
Joined Nov 2000
What Battery Packs do you use in the Teddy?
What types of battery packs do you use in your Multiplex Pico teddy? I got the "Complete Kit" with the 6-Cell Battery :::
Will the Radio Shack 1600 Nimh batteries work in this plane or should I stick with the Teddy stock 6-cell Battery?
What kind of flight times can I expect with the stock pack? Where can I get an NIMH pack?
mrebman is offline Find More Posts by mrebman
Old May 05, 2001, 12:35 AM
Muah is offline
Find More Posts by Muah
Muah's Avatar
Singapore
Joined Jan 2001
Hi there......
Just got back from flying my teddy....=) In calm winds on a 7 cell 600mAh cell i get about 12-14 minutes....just cruising around. In slight winds, need more throttle to overcome the wind and thus fly time goes down to about 7 minutes....i am going to get a pack of 8 cell 1100 mAh NiMh cells...hope to get more fly time.....oh can see me PT-19 version of the Teddy here <http://albums.photopoint.com/j/AlbumIndex?u=1557776&a=11823468>....
have fun!
Muah is offline Find More Posts by Muah
Old May 05, 2001, 07:00 PM
mrebman is offline
Joined Nov 2000
I bought the Complete Set with my Teddy, It includes the Speed Control, 2 #msx-3 Sub-micro servos & the Stock Teddy 6-Cell 600Mah Pack, the Motor they supplied is a Permax 7.2 volt Speed 400 Motor. Will the Teddy even fly with a 6-cell pack on a 7.2V motor?
Where do you get your Teddy Packs or do you make yours yourself?
Old May 06, 2001, 01:38 AM
Muah is offline
Muah's Avatar
Singapore
Joined Jan 2001
I make my own packs....made a mistake in calculation...should have made packs of 8 as i still needed some noseweight to get the CG right. Oh....do get the CG right as per instructions or else you will have a very 'handful' Teddy to fly.
good luck!
Old May 06, 2001, 07:40 AM
mrebman is offline
Joined Nov 2000
Thanks Muah:
What configuration did you make your Teddy packs into? Like this :::: (turned upright?)
Also, where did you get your batteries?
P.S. - I agree with the 8-Cell pack idea.
Old May 06, 2001, 09:52 AM
Muah is offline
Muah's Avatar
Singapore
Joined Jan 2001
Yup.....line them up like that :::: and squeeze it into the nose....check the other threads for teddy, one of them showed 6 AA size batteries.....have fun flying your teddy...oh....don't forget to put some tape on the wings, first teddy's wing folded!!! have fun!! =)
Old May 06, 2001, 09:59 AM
mrebman is offline
Joined Nov 2000
Thanks Muah:
What kind of tape do you use, I have some of the 3" wide clear tape we use in our shipping dept, is that what you use? or the kind thats about 1/2" wide & has fibers running thru it?
Old May 07, 2001, 10:30 PM
sbarrow is offline
Find More Posts by sbarrow
Australia
Joined May 2001
I use a 7 cell pack and the nose still needs some extra weight! more lead . I have 700 and 500 mah pack but as the test flights with the cg just on the recommended spot proved a real handful I am going to add a little extra nose weight to get it to balance.
sbarrow is offline Find More Posts by sbarrow
Art hobby "High Force" owners, what battery pack do you use?? Masterpiece Electric Sailplanes 3 Oct 16, 2005 09:58 PM
Question What battery connectors do you use? Ado Electric Ducted Fan Jet Talk 4 May 31, 2004 04:48 PM
XE2 flyers what battery charger do You Use? jschick Foamies (Kits) 9 Nov 26, 2003 10:16 AM
What battery packs do yous use in your Speedy? Ryan Nau High Performance 20 Jul 16, 2001 12:32 AM
What battery charger do you use? jdmartin8 Parkflyers 11 Apr 21, 2001 05:49 AM
