Old Nov 23, 2007, 12:46 PM
eajohnson is offline
Find More Posts by eajohnson
The Eh Team
Ottawa, Ontario, Canada
Joined Aug 2000
11xx shaft sizes 3.20 or 3.17?
Are the 11xx shafts really 3.20mm or are they standard 1/8" (3.17mm)? If they are really 3.20, is this likely to be a problem when fitting pinions designed for 1/8" shafts? Does it tend to be close enough to use a heat-assisted or press fit, or does it mean these motors are just not going to be compatible with the wide range of stuff intended for 1/8" shafts? Also, if I heat the pinion and slide it on, is the heat from the hot pinion likely to interfere with the shaft metallurgy? How hot can I let the pinion get before it's likely to do harm to the shaft?
eajohnson is offline Find More Posts by eajohnson
Old Nov 23, 2007, 01:19 PM
The Eh Team
Joined Aug 2000
In another forum one of the users has mentioned that the docs for the 1105 refer to the shaft as 0.125" (1/8") so I'm guessing these motors will be perfectly compatible without resorting to "drastic measures". Can someone confirm?
Old Nov 23, 2007, 01:40 PM
Mike Palko is offline
Find More Posts by Mike Palko
Mike Palko's Avatar
Telford Pa
Joined Aug 2002
I use a 1/8" collet adapter on my 1105 with a 3.2mm shaft with no problems. The fit is as good as any.
Mike Palko is offline Find More Posts by Mike Palko
Help! 3mm shaft prop designed for 3.17-3.2mm Biopraetorian Power Systems 5 Jan 31, 2006 10:08 AM
Astroflight 20 or Mega 16/15/3 ? rc-kosi Mini Helis 11 Dec 12, 2005 02:05 PM
Looking for 3 naros or 3 HS-55 N/T livinma1 Aircraft - Electric - Airplanes (FS/W) 0 Nov 02, 2003 05:36 PM
3.6 or 3.7 V for LiPos on Triton? NewNCEGuy Batteries and Chargers 1 Jul 09, 2003 04:08 PM
