Old Nov 23, 2007, 12:23 PM
designer/builder
madrob's Avatar
Kars, Ontario, Canada
Joined Apr 2004
Gee Bee Z - 28" span
So here's what I have been spending some spare time on lately.
I had been thinking of converting the Dumas 24" GBZ to RC but it just seemed a little too small for what I had in mind and I wanted to have a more scale looking plane. The only solution was to design my own and might as well have it laser cut as well.
Specs are:
Wing Span: 28"
Wing area: 128 sq in
Target wing loading is under 10 oz/sq ft so my target weight is 8.9oz RTF.
Power plant with be a GWS IPS-A gearbox with the Medusa MR-012-030-4000 (4000Kv) motor and a 3 cell 300-350 mah lipo.
I'm going to try using the GWS Pico servos since they are cheap and work very well.
(Feb. 16, 2008)
**** KITS NOW AVAILABLE FROM MANZANO LASER ****
Short kits including plans, canopy and most of the wood (you supply the 1/8" X 1/16" sticks for stringers) are now available.
http://www.manzanolaser.com/index.html
Full graphics sets are available from Callie Graphics:
http://www.callie-graphics.com/
madrob is offline Find More Posts by madrob
Old Nov 23, 2007, 12:30 PM
designer/builder
madrob's Avatar
Joined Apr 2004
The fuselage took a long time to design but it turned out to be very easy to build and light.
First, the side formers are glued to the fuselage sides.
Old Nov 23, 2007, 02:46 PM
Current project: Electrolyte
pdawg's Avatar
SoCal
Joined Apr 2004
Sweet project! Can't wait to see how you designed the parts to ease construction. Do you plan to sell kits?
pdawg is offline Find More Posts by pdawg
Old Nov 23, 2007, 08:22 PM
designer/builder
madrob's Avatar
Joined Apr 2004
Next, the fuselage sides are glued onto the fuse top and inner former section installed.
Old Nov 23, 2007, 08:31 PM
designer/builder
madrob's Avatar
Joined Apr 2004
We'll need the fin before continuing with the fuselage so here's the tail surfaces all built up. You can see the parts all interlock so they come together very fast.
Old Nov 23, 2007, 08:42 PM
designer/builder
madrob's Avatar
Joined Apr 2004
The fin is glued in place and then start adding stringers. The stringers are all 1/16" by 1/8" balsa. After the side stringers are attached the 1/32" forward skins can be installed.
Old Nov 23, 2007, 08:51 PM
designer/builder
madrob's Avatar
Joined Apr 2004
Next, the aft upper stingers are installed along with the stab filler piece. Then the rear sheeting is installed. This is a laser cut 1/32" balsa part with pre cut lines for cutting out the cockpit hole later.
Old Nov 23, 2007, 08:59 PM
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
I'll watch this one with interest.
Steve
Vintauri is offline Find More Posts by Vintauri
Latest blog entry: WATTS over Owatonna
Old Nov 24, 2007, 01:13 PM
designer/builder
madrob's Avatar
Joined Apr 2004
The tail skid is glued in place and then the belly stringers are installed around it. Next, the battery hatch is built and sheeted.
Old Nov 24, 2007, 01:16 PM
designer/builder
madrob's Avatar
Joined Apr 2004
The forward fuselage is built up with laminations of 1/4" balsa. these will be sanded to give this section a rounded profile.
Old Nov 24, 2007, 01:25 PM
designer/builder
madrob's Avatar
Joined Apr 2004
Now for the cowl. It's all balsa and just needs a little sanding......Ok, a lot of sanding!
Old Nov 24, 2007, 02:00 PM
Res Ipsa Aviatur
Longhorne's Avatar
Sonoma County CA!
Joined Jul 2007
Madrob,
This is coming together really nicely.
Good work,
Longhorn
Longhorne is offline Find More Posts by Longhorne
Old Nov 24, 2007, 02:06 PM
ParkScaleModels
zbrubaker's Avatar
United States, PA, Loganville
Joined Feb 2002
Nice...I like it!
zbrubaker is offline Find More Posts by zbrubaker
Old Nov 24, 2007, 06:11 PM
designer/builder
madrob's Avatar
Joined Apr 2004
Thanks guys!
The parts I got from Charlie at Manzano Laser are great. Good choice in balsa weight and the cutting is very nice.
More updates soon.
Rob
Old Nov 24, 2007, 06:47 PM
Veni, Vidi, Napi
catrancher's Avatar
Cumming, GA
Joined Sep 2004
This is indeed... schweet!!
Tom
catrancher is offline Find More Posts by catrancher
Fan Fold Gee Bee Z Vyceroy Foamies (Kits) 33 Jun 17, 2004 11:33 PM
Old Gee Bee Z Mystery Model E-Challenged Scale Electric Planes 4 Nov 05, 2002 09:37 AM
Adrian Page Gee Bee Z mario alvarez Scale Electric Planes 8 Sep 11, 2002 10:39 PM
FS: Herr Gee Bee 25" span -- $old-- Twmaster Aircraft - Electric - Airplanes (FS/W) 1 Aug 27, 2002 07:17 AM
Gee Bee Z Viper Pilot Power Systems 9 Apr 04, 2002 08:43 AM
