Old Nov 23, 2007, 10:10 AM
Gary Binnie is offline
Find More Posts by Gary Binnie
Late for work again!
Gary Binnie's Avatar
Northampton, England
Joined May 2004
Build Log
Cambrian Elan 100S
Hello folks,
I have just received a Cambrian Elan 100S two-channel glider through the post. This glider might be familiar to UK readers as I think it has been around for a bit. I like these old fashioned traditional built up jobs (code for: can't afford a moldie!).
A search on the web reveals next to no info on this model so I thought I would help that a bit.
Cheers
Gary
Gary Binnie is offline Find More Posts by Gary Binnie
Old Nov 23, 2007, 10:34 AM
cosmicpossum is offline
Find More Posts by cosmicpossum
cosmicpossum's Avatar
USA, TX, Dallas
Joined Jan 2007
I'm guessing the span at 2.5-3M? Slick looking bird. Availability?
cosmicpossum is offline Find More Posts by cosmicpossum
Old Nov 23, 2007, 11:30 AM
Joined May 2004
Hi CP!
Yes, 100 inches or 2.5m span, uses the Eppler 205 section.
I got mine direct from: http://www.shop.edirectory.co.uk/cam...ia/pid/5594679
It does say they ship worldwide, mine took two days to arrive (from 50 miles away) so I presume they are in stock.
Cambrian have changed hands I think and I was not sure if they were still trading but they obviously are.
I've started on the wing already and hit a couple of problems (more later).
Really don't want to make any mistakes with this one.
Cheers
Gary
Old Nov 23, 2007, 02:10 PM
USA, TX, Dallas
Joined Jan 2007
Awesome....I'll have to follow your progress. I like the looks and cost.
Old Nov 23, 2007, 03:15 PM
Joined May 2004
I should say what you get in the box.
Two sheets of plans (only one wing, you have to trace through for the other side).
Some 'Liteply' parts (fuselage sides) and pre cut fuselage top and bottom.
A bag of pre-cut balsa ribs and a stack of ply ribs. Balsa sheet and strip wood, spruce (spars).
Bag of balsa/ply parts and a bag of hardware, snakes, moulded canopy cover and four pages of A4 for instructions (not illustrated).
Most parts are numbered.
Old Nov 23, 2007, 03:18 PM
LVsoaring is online now
Find More Posts by LVsoaring
Unrepentant Paragon addict
LVsoaring's Avatar
United States, OK, Moore
Joined Jan 2006
Gary, how would you rate the quality of the materials? It simply looks right...like a sailplane that would fly well.
LVsoaring is online now Find More Posts by LVsoaring
Old Nov 23, 2007, 03:36 PM
Joined May 2004
The instructions recommend building the wings first, starting on the root panels (the wings are made up of a parallel chord root panel and two outer tapering panels).
The trailing edge is made up of 1/16 sheet with trailing edge stock glued on top which gives a 'ledge' for the tail of the ribs to sit in. The problem here was that the trailing edge stock is too thick and it is also not 'right angle stock' (it's Isosceles triangle stuff). What that means is that the tail of the ribs would not be able to butt up squarely. Luckily I had some correct trailing edge stock in my scrap box so I've used that.
The first four ribs are doubled with 1/16 ply and take two brass tubes for the wing joiners.
I'm at the stage of fixing the upper spruce spar on, nothing too difficult here, just need to be careful before committing to glue.
Cheers
Gary
Old Nov 23, 2007, 03:47 PM
Joined May 2004
Hi LV!
Wood selection is generally good, I will have a better idea when I get further along. Some of the strip is out in size, think that has been caused by using imperial equivalents of the metric sizes, the leading edge is supposed to be 6x6mm but it's 6.5 (1/4") for instance. Not a problem really.
The ribs are nicely cut and seem to have been made 'sandwich style' as there are matching pin holes through them. Just as well as there are quite a few to assemble!
Cheers
GB
Old Nov 24, 2007, 11:06 AM
Twizter68 is offline
Find More Posts by Twizter68
Owns an Evil Black Rifle
Twizter68's Avatar
Kuwait
Joined Dec 2005
Those root ribs look....beefy.....looks like a nice kit!
Hmmm...where's that currency converter....
Twizter68 is offline Find More Posts by Twizter68
Old Nov 24, 2007, 02:59 PM
Joined May 2004
Well I hope that they're beefy enough!! Especially when I pull the bungee to full stretch!
I've got the best part of three wing panels done, sheeting the leading edges was a bit tricky (just needs some patience). All the ribs have capping strips.
I probably won't join them until I've got the fuselage joiner holes aligned.
Outer tip panel has balsa spars instead of spruce, this one needs the spar webs adding and sheeting, tips are carved out of balsa block.
Only three more panels to go!
Cheers
GB
Old Nov 24, 2007, 07:37 PM
dion9146 is offline
Find More Posts by dion9146
dion9146's Avatar
United States, KY, La Grange
Joined Feb 2006
Nice looking kit. I don't know why, but I thought of an old Airtronics kit when I first looked at the pic. Does anyone market this kit in the States?Looking forward to following this build log.
Dion
dion9146 is offline Find More Posts by dion9146
Old Nov 25, 2007, 02:50 AM
Joined May 2004
Hi Dion,
Cambrian don't seem to be supplying to shops in the UK but you could get one from the link in the post above.
I'm not sure quite how old this design is, I'm guessing at 15 years but could be older.
No building today, off to the airfield for some full size fun!
Cheer
Gary
Old Nov 25, 2007, 10:52 AM
StevenatorLTFO is offline
Find More Posts by StevenatorLTFO
AKA - The "Flywheel"
StevenatorLTFO's Avatar
SOAR Chicago!!!
Joined Jan 2005
Dion
It looks a little bit Saggita-ish in the nose doesn't it. Tails different, and the multi-poly wing whatever you call something with 6 bays is kinda cool.
S
StevenatorLTFO is offline Find More Posts by StevenatorLTFO
Old Nov 26, 2007, 03:42 PM
Joined May 2004
Think it's just called polyhedral (but don't quote me!). I like that feature too.
Sorry this picture is a bit dark, I laid the panels out next to a wing from my Flair Sunrise (also 100S). That wing has just been rebuilt from a nasty bungee launch that was all my fault (too windy for it). They should look good together.
Cheers
GB
Old Nov 26, 2007, 03:58 PM
GeeW is online now
Find More Posts by GeeW
SB-28 UK Display Pilot
GeeW's Avatar
ENGLAND
Joined Jul 2001
Hi Gary
You're sure going for it on this build.......is Mrs B out of town or something?
Best Regards
Gordon
GeeW is online now Find More Posts by GeeW
