Old Nov 27, 2007, 10:08 AM
rmteo is offline
Find More Posts by rmteo
User
Colorado
That's great that they have +/-4 ppm. Could you provide info on the manufacturer/part number of the resonators?
rmteo is offline Find More Posts by rmteo
Old Nov 27, 2007, 11:07 AM
wrightme is offline
Find More Posts by wrightme
Trons and Fumes
wrightme's Avatar
Fallon, NV
Joined Mar 2007
If the answers to these questions are so important to you, why don't you work it out in email or PM with Mr Drew?
wrightme is offline Find More Posts by wrightme
Old Nov 27, 2007, 10:10 PM
skubacb is offline
Find More Posts by skubacb
skubacb's Avatar
Tucson, AZ
Joined Aug 2006
RMTEO, try asking Horizon or Futaba that kind of detail. I worked Electronic Warfare for 25 years. As an operator, how about sticking to performance questions and leaving the design implementation to the people producing it.
If you want more than that then go design a system yourself.
skubacb is offline Find More Posts by skubacb
Old Nov 27, 2007, 11:40 PM
rmteo is offline
User
Colorado
Originally Posted by skubacb
....I worked Electronic Warfare for 25 years....
And that proves what?... LOL!!!
Old Nov 28, 2007, 07:45 AM
wrightme is offline
Trons and Fumes
wrightme's Avatar
Fallon, NV
Joined Mar 2007
RMTEO, his statement about his experience was a direct lead-in to his main assertion that operators should be worried about how to OPERATE , not how to DESIGN
Old Sep 24, 2012, 11:13 PM
Mauricio2346 is offline
Find More Posts by Mauricio2346
Mauricio2346's Avatar
Medellín, Colombia
Joined Jan 2010
Hi guys.
it's a must to use some kind of vibration damper to our receivers. maybe if electronic components with low mass and hence, inertia doesn't be affected with vibration, solder joints on the PCB does!.
is not a good deal to think that a MCU, resonator, crystal would be damaged, if you don't think how those components are connected together!.
tiny receivers uses thinner PCB's (more flexible and fragile), also, less solder. if any solder joint just break, can make our plane fall as a rock.
please, don't you think that spending some cents on foam or velcro worth more than loosing a expensive plane?
just think about it!
Mauricio2346 is offline Find More Posts by Mauricio2346
Old Sep 25, 2012, 12:10 AM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
ooh, sweet thread necromancy
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Sep 25, 2012, 04:14 PM
E_ferret is offline
Find More Posts by E_ferret
E_ferret's Avatar
Launceston Arpt, Tasmania, Australia
Joined Jan 2004
well, some people are not impulsive, they take their time to think things over.
E_ferret is offline Find More Posts by E_ferret
Old Dec 16, 2012, 11:29 AM
dirtybird is offline
Find More Posts by dirtybird
United States, AZ, Queen Creek
Joined Aug 2004
Many years ago I borrowed an accelerometer from the Boeing Labs and checked the K&B 40 pylon racer I was using.(In the early 70's) I found about 100g's when the engine was running at top speed. Since the accelerometer was about the size of a servo motor I put it inside of a servo case and found the same 100 g's. That vibration was so fierce and at such high frequency it went right through the mounting rubber grommets just as though the were made of wood. Since that time I have ignored those rubber grommets and screwed my servos down solidly. I have never had an inflight servo failure.( I feel it helps prevent flutter)
You people that feel that cushioning is helping you are fooling yourself.
I mount my 2.4 receivers on velcro so I can remove them easily.
dirtybird is offline Find More Posts by dirtybird
Futaba MCR-4A 4 channel AM Receiver with built in ESC Jason M Aircraft - Electric - Airplanes (FS/W) 1 Jan 07, 2002 04:02 PM
Receiver with built-in ESC crashnburn Electric Plane Talk 7 Oct 18, 2001 03:51 PM
Feather receiver with 3 crystals frankenfoamy Aircraft - Electric - Airplanes (FS/W) 0 Oct 01, 2001 10:47 PM
PCM receiver with brushless? Fred Bronk Electric Heli Talk 20 Jul 25, 2001 12:50 AM
Any problems using a 4 channel receiver with a 7 channel radio? bluex Power Systems 6 Jul 06, 2001 12:23 AM
