Old Nov 21, 2007, 05:40 PM
bigandy is offline
Find More Posts by bigandy
Pesky Landings!
bigandy's Avatar
Abergele, North Wales, UK
Joined Apr 2004
Dynamic balancing of Props/shafts/rotating assemblies
Good evening all.
I have been having a bit of a ponder about the balancing of small ducted fan rotors, props and shafts. I am finding it difficult to get a decent state of balance on the smaller stuff, and I was wondering about the possibility of designing or building a dynamic balancing type machine to try and improve the balance of the small stuff a little.
I have seen a few designs, where the rotating assembly sits in a couple of cradles, and is spun up to speed. There is then a box of electronics that read out the magnitude of the imbalance, and the angle of rotation (from a datum mark) where the imbalance is located.
Does anyone know of any DIY circuit references, or machines that are available out there that can do something like this box of tricks? I'm not too fussed about having a readout and angle, but the more advanced the better
I'm off to have a search through the RCgroups archives now for any links, although asearch for "dynamic balancer" has turned out rather a lot of results.... Hopefully that is a good thing, but in the meantime, if anyone has any useful info, feel free to post it!
Thanks in advance
Andy
bigandy is offline Find More Posts by bigandy
Old Nov 21, 2007, 05:51 PM
ZAGNUT is offline
Find More Posts by ZAGNUT
supreme being of leisure
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
this project might be helpful: http://www.turbinemuseum.de/Gasturbi...cing_tool.html
dave
ZAGNUT is offline Find More Posts by ZAGNUT
Old Nov 22, 2007, 03:23 AM
bigandy is offline
Pesky Landings!
bigandy's Avatar
Joined Apr 2004
That's a brilliant link, cheers for that Dave!
Andy
Old Nov 26, 2007, 11:31 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
I spin boat props with air, and use an automotive strobe with a pulse generator feeding the sense. A pot adjusts the frequency (555) to get a steady reading.
If you mark the blades with a pen, you can easily read the numbers to see the heavy blade(s).
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Nov 26, 2007, 04:37 PM
bigandy is offline
Pesky Landings!
bigandy's Avatar
Joined Apr 2004
Is that using the mechanics and sensors (piezo) as per the link in the post above Andy?
I've actually been reading up on a few different balancer designs (On the GTBA forums), and some of the theory when it comes to dynamic balancing, and the design of the mechanics becomes quite critical when you start to balance down to low inbalances.
I'm still deciding which way to go regarding the mechanics, but the link provided above seems as good a solution as any
Cheers
Andy
Old Nov 26, 2007, 06:22 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
No. The mechanics are a balanced magnetic balancer. You need to replace the the curved stock rod and centering plastic blobs - they are useless! Use compressed air to spin the prop up and the strobe to see which blade is heavy. If the strobe and prop are slightly out of synch, you can watch the free end of the rod draw a circle. It's actually very easy to see which blade is heavy.
I did a write-up on doing it this way for boat props several years ago. You can find it on several websites. Google for "andy kunz balancing props" (w/o the quotes) and the top few non-paid links are what you want.
Andy
Site Sponsor
Old Jul 08, 2009, 12:23 PM
MDGrissom is offline
Find More Posts by MDGrissom
MDGrissom's Avatar
Morrisville, NC USA
Joined Apr 2009
I've got a factory dynamically balanced Neutrino outrunner with a recently machined aluminum centrifugal impeller (also supposedly balanced by nature of the precision machining) but after the impeller was heat mounted (for tight fit) to the motor hub an imbalance now exists. When running the motor/impeller assembly I can ease a pencil lead up against the side of the impeller which leaves 1 half inch lead lines on only one side of the 1.5" diameter impeller hub. Note that the impeller does not wobble.
Question: Can I dynamically re-balance this assembly to some extent by lightly touching an appropriate spinning Dremel cutting bit to the spinning impeller hub where I touched the lead pencil to remove aluminum from the heavy side? Or, is it a lot more complicated than that?
MDGrissom is offline Find More Posts by MDGrissom
Old Aug 01, 2009, 04:43 PM
Bob Blackburn is offline
Find More Posts by Bob Blackburn
Bob Blackburn's Avatar
UK, Greater Manchester, Manchester
Joined Jul 2004
http://www.rcgroups.com/forums/showthread.php?t=1081834
Don has one of these and seems to like it!
Bob Blackburn is offline Find More Posts by Bob Blackburn
Old Sep 10, 2010, 10:32 AM
stegla is offline
Find More Posts by stegla
stegla's Avatar
Guernsey
Joined Jan 2002
I made this balancer using vero-board and 18mm mdf. I seem to be getting very good results using it on micro edf.
It is a rip-off of this.............
but dumbed-down to suit my skill-level.............. and pocket...............cost 7!
Steve
stegla is offline Find More Posts by stegla
Old Sep 10, 2010, 03:37 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Hi Steve, would you care to explain your "dumbed-down" circuit?
coriolan is online now Find More Posts by coriolan
Old Sep 11, 2010, 04:37 PM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
Hi Coriolan,
The circuit is an exact copy of the circuit diagrams on the website but I used through-hole components and stripboard instead of surface-mount.
The website uses milled aluminium............I used mdf, balsa and pva glue.
Steve
Old Sep 11, 2010, 07:15 PM
coriolan's Avatar
Canada
Joined Sep 2006
The CNC hoopla trew me off, like your simplified version better!
Balancing Props (aeronaut) nik_leeson Power Systems 6 Aug 13, 2013 10:14 AM
Discussion Balancing Props SuperHornet Pusher Prop Jet Models 10 Apr 30, 2006 08:33 AM
Balancing props - advice needed Artemetra Electric Plane Talk 19 Feb 24, 2005 12:05 AM
Balancing Props LJH 3D Flying 0 Nov 22, 2004 01:43 PM
Experiments in Dynamic Balancing OmegaDot Micro Helis 6 Nov 21, 2004 10:31 AM
