I am trying to dial in my E3D for harriers and I just so happened to bump into a buddy who does large IMAC 3-D stuff. I complained that my plane kept rocking and falling out of the hover at high alpha. He said that I needed 45 degree elevator throw and bury the stick, I only had 30-35 degrees. Then, the altitude is controlled by throttle, the rudder for turning, and ailerons just for keeping the wings level. I will see how his advice works this weekend after I dial more throw in. I believe this was my problem in the past on another plane trying to get it to harrier.
Latest blog entry: My creative replacement Quad body for...
I also have to remember to take off my flap-to-elevator mixing when entering the manuever because the flaps down causes micro tip stalls and the wings "wag". I have another mix that puts a slight amount of reflex into the ailerons to counter that but it's kind of hairy because it basically kills the lift on the wing when you pull up. Gotta trust the power to pull you out and click it off after you exit. I'm starting to enjoy the 3D stuff the more I dial the plane in right. I just need to stuff more power into the airframe to get where I want to go. I need a new GB for my motor in wait.
