Espritmodel.com Heli Air
Old Nov 17, 2007, 06:39 PM
Moorpark, Ca.
Joined Apr 2004
Question about using LiPO for Rx power
I'm setting up a large pusher jet and the 65amp ESC dosn't have a BEC. I have been using 3amp, 5vdc out, UBECs for the last couple of my planes and would normally just disconnect the ESCs BEC and tap into the main battery leads to power up the UBEC. Is there a problem with using a seperate 450mah, 3cell, 10c Lipo to power up the UBEC? The UBEC would be powering up 3 HS-81 servos along with the Rx. Thanks for any help.
Rick
RickAvery is offline Find More Posts by RickAvery
Old Nov 17, 2007, 07:10 PM
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
Not at all.
I use a 450mah 2S to power my one of my UBECs for one of my pylon planes and as long as the UBEC can handle that voltage it's not a problem.
fly_boy99 is offline Find More Posts by fly_boy99
Old Nov 17, 2007, 07:18 PM
I'd rather be Flying
davecee's Avatar
Nashville, NC, USA
Joined Mar 1999
I'm doing the same thing right now. I've got a 29% giles 202 on a 10s system. I'm using a 6 volt UBEC with a 2S 2200 mah Lipo pack. I'm powering 4 high torque servos and 1 digital high torque servo from this with good results. I remove the pack from the plane to charge. I can get several flight sessions per charge.
Dave
davecee is offline Find More Posts by davecee
Old Nov 17, 2007, 07:19 PM
Moorpark, Ca.
Joined Apr 2004
Thanks FB99 & Davecee,
It didn't seem like there would be a problem I just figured I'd throw it out there and see what folks have/are doing. The UBEC is rated at 5-24vdc. I'm going to give it a shot.
Rick
Discussion Question about using 110 v a/c "block" for charging richg99 Batteries and Chargers 13 Oct 19, 2007 07:19 PM
Question Question about removeable lipo for Picco 11861 Micro RTF 9 Sep 14, 2006 03:03 AM
Question about using a seperate servo for each aileron Swissross GWS (Grand Wing Servo) 1 Mar 11, 2004 05:34 PM
Question about using fireproof safe for charging LiPo's nadt770 Batteries and Chargers 1 Jan 12, 2004 09:03 PM
