Old Nov 16, 2007, 09:29 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
New Product
DonsRC Wicked EDF and Wicked EDF Extreme Motors
Two new EDF motors from DonsRC that mount directly in the Alfa EDF units, and XF fan units, and Hyperflow EDF units. A true 'plug and play' design that takes only a few seconds to install. Includes all required hardware to mount into the Alfa EDF unit. Simply tighten the two screws to mount the motor into the EDF housing, then thighten one screw to mount the rotor and you are ready to go.
Wicked EDF Extreme
KV:5400 rpm/volt
Weight as seen in photo: 67 grams
3mm shaft
Get 4S power with only a 3S lipo. That means lower flying weight and higher thrust to weight ratio.
3S lipo in Alfa with 5 blade rotor: 47,000 rpm, 40 amps, 420 watts
3S lipo in Alfa with 3 blade rotor: 53,000 rpm, 26 amps, 290 watts
4S lipo in Alfa with 3 blade rotor: 64,000 rpm, 38 amps, 530 watts
3S lipo in XF fan: 51,000 rpm, 30 amps, 330 watts
4S lipo in XF fan: 59,000 rpm, 41 amps, 540 watts
3S lipo Hyperflow fan : 45,000rpm, 38 amps, 400 watts
3S lipo GWS EDF 55: 43,000 rpm, 40 amps, 400 watts
Wicked EDF motor
KV: 4800 rpm/volt
3mm shaft
Lower KV allows more option for flying on 3S or rocket like performance on 4S.
3S lipo with Alfa 5 blade rotor: 43,000 rpm, 29 amps, 300 watts
4S lipo with Alfa 5 blade rotor: 53,000 rpm, 40 amps, 560 watts
3S lipo with Alfa 3 blade rotor: 47,000 rpm, 18 amps, 185 watts
4S lipo with Alfa 3 blade rotor: 59,000 rpm, 29 amps, 383 watts
3S lipo with Wattage Powerfan (3 blades): 40,000 rpm, 32 amps, 330 watts
3S lipo with Hyperflow fan: 43,000, 30 amps, 330 watts
4S lipo with Hyperflow fan: 52,000 rpm, 41 amps, 560 watts
3S lipo GWS EDF55: 41,000 rpm, 32 amps, 330 watts
4S lipo GWS EDF55: 50,000 rpm, 44 amps, 600 watts
3S lipo GWS EDF64: 40,000 rpm, 33 amps, 340 watts
Combine these motors with a DonsRC Pentium 40 amp ESC and you have a complete motor ESC package for only $100. No need to spend big $$$ on a Jeti Spin to make these motors run correctly. In fact these motors were tested with a Jeti spin 44 ESC an the rpm and amps were so close the difference is not worth mentioning. Great EDF performance does not have to cost big $$$$
Price is $60 ready to install.
See more info at www.donsrc.com
Here is a video of my Alfa A-4 on its maiden flight with the Wicked EDF Extreme motor using a TP Extreme 3S 2200 lipo and the 5 blade alfa rotor. Best speed was 105mph!
http://media.putfile.com/Alfa-A-4-Ma...tor-on-3S-lipo
The Don is offline Find More Posts by The Don
Old Nov 17, 2007, 07:44 AM
iceman3 is offline
Find More Posts by iceman3
Norway
Joined Mar 2005
The Don
This was very interesting, and how do I order one of the motors?
iceman3 is offline Find More Posts by iceman3
Old Nov 17, 2007, 08:31 AM
FASTBEN is offline
Find More Posts by FASTBEN
Cumulus Altimus
FASTBEN's Avatar
United States, TX, Keller
Joined Feb 2002
Great Job On That Motor On 3s??????wow.
Ben
FASTBEN is offline Find More Posts by FASTBEN
Old Nov 17, 2007, 01:47 PM
jonnyjetprop is offline
Find More Posts by jonnyjetprop
jonnyjetprop's Avatar
USA, FL, Apopka
Joined Sep 2003
Does it fit the GWS EDF55, 64 or the microfan?
John
jonnyjetprop is offline Find More Posts by jonnyjetprop
Old Nov 17, 2007, 02:10 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Yes it will on the GWS. I dont have a microfan to try.
I added more data in the first post for other EDF fans tested today.
Old Nov 17, 2007, 04:55 PM
darmar is online now
Find More Posts by darmar
USA, PA, Pittsburgh
Joined Jul 2001
great job Don
darmar is online now Find More Posts by darmar
Old Nov 17, 2007, 05:53 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
Originally Posted by iceman3
The Don
http://www.donsrc.com/cart/index.php
village_idiot is offline Find More Posts by village_idiot
Old Nov 18, 2007, 10:03 PM
Buzz Bomb is offline
Find More Posts by Buzz Bomb
Ham Call Sign: KK4KGJ
Buzz Bomb's Avatar
United States, GA, Stone Mountain
Joined May 2006
Looks good Don. I may have to order one in the future.
Joe
Buzz Bomb is offline Find More Posts by Buzz Bomb
Old Nov 19, 2007, 06:05 PM
tulz43 is offline
Find More Posts by tulz43
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Don.. the video is of the 5400 KV motor correct?
tulz43 is offline Find More Posts by tulz43
Old Nov 19, 2007, 06:20 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Yes it is.
Don
Old Nov 19, 2007, 09:22 PM
tulz43 is offline
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Thanks Don.
One more thing...what did u use to get the data?
Old Nov 19, 2007, 09:36 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Thanks Don.
Eagletree data logger with brushless RPM sensor.
Don
Old Nov 28, 2007, 11:53 AM
USA, PA, Pittsburgh
Joined Jul 2001
I got two 4800kv motors from Don and can say only great things about those.
There is one thing that bothers me regarding use of adapters in fans with shorter mounting motor tube. For example xf fan, motor with adapter sticks out back too far and is supported only at the mounting plate by two screws, thats fine, but in case of harder landing weight of the motor or any other stress imposed onto the motor mounting plate will ripp it off or bend it and cause rotor to start rubbing duct wall.
There should be support at the rear of mounting tube like ring or something.
I haven't experienced this myself so far, just wanted to get second opinion from guys that use the setup.
This will be the case with GWS fans with weaker motor mount also.
darmar
Old Nov 28, 2007, 05:24 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
I understand what you are saying but to date this not been an issue at least on the Alfa and XF fan. I have the new GWS fans coming and will check them out when they arrive. The shorter GWS may be fine now without any adapter. Or I may make a short GWS version of the adapter.
Don
Old Nov 28, 2007, 07:23 PM
Aethertek is offline
Find More Posts by Aethertek
Creations Aberration
Aethertek's Avatar
United States, OR, Newport
Joined Jan 2004
Don...
Question, what is the bolt hole spacing on the MOTOR housing, 16 & 17mm just like the adapter or do you use a single spacing on the housing?
TIA
Kevin~
Aethertek is offline Find More Posts by Aethertek
New Product DonsRC Wicked 2700KV and Wicked Jr 3000KV Outrunner Motor 90-115mph! The Don Product Announcements 6 Nov 07, 2007 10:32 PM
EDF-55 with a 350C motor, too high amps? meteor Electric Ducted Fan Jet Talk 0 Apr 29, 2004 08:47 PM
Hornet/Edf rocks! where to get motor/fins? Terkan Micro Helis 10 Oct 25, 2003 01:53 AM
EDF-50 Replacement Piccolo Motor WeatherB Micro Helis 5 May 18, 2003 09:34 AM
More EDF-50 vs. IPS Motor Talk Dave Hederich Parkflyers 0 Sep 26, 2002 01:27 PM
