Old Nov 16, 2007, 05:13 AM
flyinhigh025 is offline
Find More Posts by flyinhigh025
How can we stop winter?
flyinhigh025's Avatar
Frederick, CO
Joined Sep 2005
HET F-104 Starfighter
Hi all! Just received shipment of my new -RED- HET F-104. This is my first true EDF. I have been flying RC Aircraft for nearly 15 years, have always thought the F-104 was the best looking most amazing fighter ever produced... So I had to have one!!!
The reason I am starting this post is, I'm hoping as I start the build, gather the equipment to get this thing going, I can gain some suggestions from others that have built this awesome model, and I will also add pics. and feedback of my upcoming experience.
So, please feel free to add ANYTHING to this post in regards to the HET F-104, or even just chat about 104's in general would be cool!
So, to get things started...
Question #1! What is the best way to build a bungee/rail launcher for the HET F-104?! I have not a clue where to start here...
flyinhigh025 is offline Find More Posts by flyinhigh025
Old Nov 16, 2007, 01:44 PM
CTulanko is offline
Find More Posts by CTulanko
CTulanko's Avatar
Cincinnati, Ohio
Joined Mar 2004
Go to www.warbirds-rc.com to see bungee pedals, ramps, and dollys you can build yourself, as well as a construction article on the F-104 model as well as others. You will find this in the "Research Center" area. Good luck and keep us posted.
Carl
CTulanko is offline Find More Posts by CTulanko
Old Nov 16, 2007, 03:03 PM
Frederick, CO
Joined Sep 2005
Power
Carl
Thanks Carl! I will check it out... Good stuff.
I will try to get things rolling here by discussing my choice of power system. This might end up a little controversial, but I will try to explain myself...
Motor: ARC-28-47-1 (From www.lightflightrc.com)
Speed Control: SP 60 Amp ESC (From www.lightflightrc.com)
Battery: Planning on using a Thunder Power 3850-3SX-TP-25C
-Yes, a 3s Battery!!
Fan Unit: HET 6904 fan
Here is my reasoning...
The ARC motor is a drop in replacement for the HET EDF 2W20 with one distinct advantage, greater KV/RPM's per Volt rating.
ARC's KV = 4250 (Approx. 47175 RPM's @ 11.1V)
HET 2W20's KV = 3350 (Approx. 49580 RPM's @ 14.8V)
Disadvantage: That's telling me I will lose approx. 2405 RPM's switching to the ARC motor and using a 3S battery.
Advantages: Weight! The F-104 will shed about 2.7 to 3.2 ounces AUW. Lighter wing loading = nicer flying F-104?! Cheaper battery packs!
I'm hoping to achieve similar performance as compared to the "Stock HET" set-up. Dave at www.lightflightrc.com is #1 in my book when it comes to customer service. He is excellent at answering all questions, stands behind his products, overall good person. Light Flight RC has a link to a thread containing much information about the ARC line, even a video of the (lighter) HET F-16 being flown on the power system I have chosen with AMAZING results.
One more thing, if I ever want to I can move up to a 4S pack / larger speed control... and have a ballistic RC F-104 if I so choose!!! (62,900 RPM's!!!)
So, all that said... Let me have it! What do you all think?
Old Nov 16, 2007, 06:19 PM
mario alvarez is offline
Find More Posts by mario alvarez
Fight On!
mario alvarez's Avatar
San Salvador, El Salvador
Joined May 2001
Like 104's. Check this out. Actually it's an Aeritalia F-104.
mario alvarez is offline Find More Posts by mario alvarez
Old Nov 16, 2007, 08:02 PM
Frederick, CO
Joined Sep 2005
That's funny you showed that pic! I am converting my F-104 to look like that model/paint job! I have a friend currently working on the "Ferrari" decal for that tail... Should be cool.
Old Nov 16, 2007, 11:56 PM
hole digger is offline
Find More Posts by hole digger
hole digger
hole digger's Avatar
USA, CA, Los Angeles
Joined Aug 2002
Always loved the F-104 has anybody found tip tanks for the HET kit?
hole digger is offline Find More Posts by hole digger
Old Nov 17, 2007, 07:16 AM
CTulanko is offline
CTulanko's Avatar
Cincinnati, Ohio
Joined Mar 2004
Digger...check with Markos at www.warbirds-rc.com as he had some in stock and if not, EJF also has some.
Carl
Old Nov 17, 2007, 10:38 AM
Frederick, CO
Joined Sep 2005
Carl
I read a report that the tip tanks give the HET F-104 the "feel" that it has more wing area, can anyone confirm this?
Old Nov 17, 2007, 11:31 AM
mediq is offline
Find More Posts by mediq
Buckley wa
Joined Mar 2005
Still feels like a jet with stubby wing i found no difference with tanks on tanks off
mediq is offline Find More Posts by mediq
Old Nov 17, 2007, 11:52 AM
Frederick, CO
Joined Sep 2005
Thanks! I was actually planning on NOT using the tanks... So I take it you have to treat the HET F-104 like and F-104? Fly fast!
Old Nov 17, 2007, 08:45 PM
lavochkin is offline
Find More Posts by lavochkin
lavochkin's Avatar
Mokena,Illinois -United States
Joined Oct 2006
Flyinghigh, That arc motor is VERY underated. I believe they say 500 watts? I know for a fact either quiet flyer or backyard flyer tested it in a wemotec minifan 480 (70mm) And they put out over 1400 watts but it came at a price of hi amp draw (over 100). So I'm sure it can support 5s and 6s also. It spun that fan at over 70,000 rpm's.
I'll check, it's in a back issue from late this summer.
My point is with that setup if you ever want more speed then you got it!!! Let me know how it flies. I have one thats gonna go in a het 609 fan in a skyray.
Joe
lavochkin is offline Find More Posts by lavochkin
Old Nov 17, 2007, 10:38 PM
Scarey is offline
Find More Posts by Scarey
Registered EDF abuser
Scarey's Avatar
Michigan
Joined Jan 2006
Some good video of the F-104
http://rcb.shopnz.biz/catalog/produc...de54b6677dd15d
Scarey is offline Find More Posts by Scarey
Old Nov 17, 2007, 10:59 PM
lavochkin's Avatar
Joined Oct 2006
That last one with the 2w-23 on 5s was haulin MAJOR ass!!!!
Old Nov 18, 2007, 01:02 AM
Frederick, CO
Joined Sep 2005
Joe
I will let you know how it turns out! Thanks for the input... After talking directly with Light Flight I feel you are correct that the 500w is a VERY concervative rating. I would like to start with an economy set-up, and see how that goes. And then if all goes well, I will upgrade to a 4S+ Lipo like you said and try to keep the wings on!
Old Nov 18, 2007, 01:04 AM
Frederick, CO
Joined Sep 2005
Originally Posted by Scarey
WOW.. 5S?!
Thanks for the video, awesome!
My F-104 Starfighter terje s Electric Ducted Fan Jet Talk 55 Nov 01, 2008 11:08 AM
F-104 Starfighter Project 1/16th scale lphan Pusher Prop Jet Models 308 Jul 31, 2006 08:34 PM
F-104 Starfighter rising stegre Slope 45 May 30, 2004 01:26 AM
Wanting to make a F 104 starfighter kushal_22 Electric Ducted Fan Jet Talk 4 Dec 23, 2002 11:08 AM
F-104 Starfighter for EDF-50, is it possible ? Rudi Electric Ducted Fan Jet Talk 48 Nov 15, 2002 06:03 PM
