Old Nov 15, 2007, 05:51 PM
fr4nk1yn is offline
Find More Posts by fr4nk1yn
fr4nk1yn's Avatar
Norfolk, Va
Joined May 2006
Cool
Fastest Foam Plane Challenge « pdawg: 139.6mph » Full Results: Post #2
This thread started HERE which was inspired by THIS thread.
Here's the plan, I hope some people will play along:
  • Plane must be scratch built from flat foam, Depron, Elmers, Blue or Pink, e.t.c. is OK.
  • A minimal amount of wood and/or carbon fiber is acceptable for motor mounting, structural bracing and ailerons.
  • Cost of the power system, battery, ESC, motor, must be less than $100.
  • Proof of speed by video, either to be dopplered by a third party or of a radar gun.
  • Winner gets Bragging Rights and Eternal Admiration! Until somebody trumps his/her speed (:,
A few clarifications:
  • All glues are allowed, i.e. "Gorilla Glues", CA, Epoxy
  • "Glues" as bracing are not i.e. Epoxy or Fiberglass coatings
  • No objections have been made to packing tape and "Monokote" however.
More clarifications (May 14th, 2008) :
  • Video is provided not only to provided the wav file but to prove the plane is not coming out of a dive.
  • Sales prices are NOT allowed.
    If the item is bought on sale, the full retail price must be used.
  • For parts bought used, the same as above applies.
  • "Price shopping" is allowed.
    example: If an item is bought at the LHS for more than it's available online then the online price is acceptable.
That's about it I think.
fr4nk1yn is offline Find More Posts by fr4nk1yn
Old Nov 15, 2007, 06:00 PM
fr4nk1yn is offline
fr4nk1yn's Avatar
Norfolk, Va
Joined May 2006
Current Results:
pdawg • Gordo • VIDEO • 139.6mph
3DMON • Speedy • Video • 137.8
The Don • "Dons' Shuttle Foamy" • Video • 114.4 mph
Dene • Horent II • Video • 101.6mph
jackomeister • Turbo Flea V3 • 101.36mph
RCBlackSheep • Burple • Video • 81.46
Glu it again Sam • 24" Avro Arrow Entrant • 77mph
MiseryQ • Y.et A.nother D.elta W.ing • Videos • 71mph
Old Nov 15, 2007, 06:38 PM
msmith is offline
Find More Posts by msmith
Use whatcha got!
msmith's Avatar
Metairie, LA
Joined Sep 2000
I was thinking of 'setting a date' for entries, but since this really isn't a contest, lets just keep it an ongoing, open 'challenge' as you mentioned...
Should be cool... You planning on setting the bar high MiseryQ?
I'll get an initial speed test on my 19" Skyray w/ C20 and 3S800 this weekend. We do have video, and a radar gun. Will also run some of my 'other' motors on that same airframe before I start to get into my custom 'speed' plane.
My idea for the airframe 'built for speed' is going to take me awhile to complete so I'll get a 'starting point' this weekend with something I've already got...
-mike s.
msmith is offline Find More Posts by msmith
Old Nov 15, 2007, 10:01 PM
kev0383 is offline
Find More Posts by kev0383
Joined Mar 2007
so the $100 only includes battery, esc, and motor? that's easy. an arc motor/esc combo and HXT 2200 3S lipo would come in right at $100 and might make 500 watts with the right prop. that should push foam past the century mark; but i could be wrong. if this catches on, i'll spend the buckaroos to get in on the action. too bad x-mas is right around the corner. guess i gotta spend some $$$$ before i have to spend it on somebody else :P
kev0383 is offline Find More Posts by kev0383
Old Nov 15, 2007, 10:12 PM
jonesymj is offline
Find More Posts by jonesymj
Slopeosapien
jonesymj's Avatar
Joined Jun 2006
Just an idea for an "Honorable mention" catagory, and since this is the Scratchbuilt (read:spend-thrift) forum, we should also keep track of the fastest, CHEAPEST aircraft as well... It's just an idea, mind you, but could end up really being worth the server space... LOL!!
jonesymj is offline Find More Posts by jonesymj
Old Nov 15, 2007, 10:26 PM
Bugman Jeff is offline
Find More Posts by Bugman Jeff
I'm a Registered User
Evansville, WI
Joined Dec 2006
I want to play too. How about an overall speed/cost ratio number as well as the ultimate speed? So if you hit 100 and spend $100, your ratio is 1. If you hit 100 and only spend $70, your ratio is 1.4. The higher the speed/cost ratio the better. 'Course highest speed reached still wins bragging rights, but the S/C ratio lets cheapskates like me feel competitive
Bugman Jeff is offline Find More Posts by Bugman Jeff
Old Nov 15, 2007, 10:28 PM
kev0383 is offline
Joined Mar 2007
time to do some research...
Old Nov 15, 2007, 10:39 PM
fr4nk1yn is offline
fr4nk1yn's Avatar
Norfolk, Va
Joined May 2006
The battery, as mentioned in the other thread, will be the equalizer.
I won't be the one setting the bar, my flying skills have much to be desired.
I did consider a mph/dollar "option".
Just to start it off here's my Y.A.D.W. clips.
  • UH FC 28-05 $5.95
  • ThunderPower 1320mAH 2s $36.95
  • Thunderbird 18 ESC $34.99
  • APC 6x4 sport prop approx $2.30
  • total: 77.89
After that I built a 24" pink foam Mugi to try out the hotter rewound motor, a HXT D9 Gen 2 1300mah battery and APC 4.2x4.0, it's all the LHS had in that size range, but it was destroyed on the 2nd flight.
It felt, and appeared to the fuel guys, to be faster than the Y.A.D.W. during it's brief flying time ):
I have a 26" Mugi ready to go with an APC 4.1x4.1 just as soon as I get a radio.
This power system comes in at $58.15.
-edit- Changed the battery. I was using a TP Prolite during the video.
Last edited by fr4nk1yn; Nov 15, 2007 at 10:56 PM. Reason: Changed battery in setup.
Old Nov 16, 2007, 08:41 AM
msmith is offline
Use whatcha got!
msmith's Avatar
Metairie, LA
Joined Sep 2000
I like this idea, but I think it still has to be a two-part result...
mph and mph/dollar ratio...
Otherwise someone spending $50 and going 60mph has a higher ratio than someone spending $100 and going 100mph which we all know is a harder feat to accomplish since as speed increases, power needs to increase exponentially...
So I'd vote for the ratio, but only with the overall speed as a primary gauge.
Old Nov 16, 2007, 05:33 PM
N9DP is offline
Find More Posts by N9DP
Cessna Skyhawk Pilot
Casa de Aero Airpark, Hampshire, IL
Joined Aug 2007
This is to be a speed contest; mph/$ is an entirely different contest. Power goes as cube of speed, so it takes 30% more power just to go 10% faster.
A $20 fling glider can attain instantaneous 80 mph by playing the shear winds.
I’ll depart, having imparted a few factoids for the day.
Happy landings,
Dennis
N9DP is offline Find More Posts by N9DP
Old Nov 16, 2007, 05:44 PM
Danjuan is offline
Find More Posts by Danjuan
Huh?! well waddayouknow!?
Slackramento ,CA
Joined Jul 2006
Im in built a tachyon, from charas plans. ele c 20(2500kv) ,UH 800 3cell, het tnunami10 ,berg 4
5 oz plane 22"ws should scream .and cheap cheap!
Danjuan is offline Find More Posts by Danjuan
Old Nov 16, 2007, 08:23 PM
LiveElectric is offline
Find More Posts by LiveElectric
Under-promise, Over-deliver
LiveElectric's Avatar
St. Louis Missouri (Clayton, specifically)
Joined Mar 2007
I'd put my money on GPW's Borg Cube...
Wolf
LiveElectric is offline Find More Posts by LiveElectric
Old Nov 16, 2007, 08:44 PM
callmeishmael is offline
Find More Posts by callmeishmael
AMA 42867
callmeishmael's Avatar
Joined Nov 2003
This is level flight - yes?
If no, then my Piece-of-Depron-Taped-to-A-Rock-and-Thrown-Off-A-Cliff Special will clean up both in the cost and speed categories.
callmeishmael is offline Find More Posts by callmeishmael
Old Nov 16, 2007, 09:29 PM
msmith is offline
Use whatcha got!
msmith's Avatar
Metairie, LA
Joined Sep 2000
Happy landings,
Dennis
Did I miss the election?
I thought it was MiseryQ who started the thread... and specified a dollar amount to keep it fair... and also considered the feasibility of a ratio idea...
Old Nov 16, 2007, 10:02 PM
caeman is offline
Find More Posts by caeman
Crash Test Pilot
caeman's Avatar
Joined Aug 2007
Yeah, I was going to ask about a clarification for 'fastest foamie'. The Fastest Lawn Dart would need to be a different contest.
caeman is offline Find More Posts by caeman
Scratch Built Success From $5 Foam Plane Wing saint152 Electric Sailplanes 17 Mar 29, 2008 11:18 PM
Discussion Fastest "Blu" Foam Plane. fr4nk1yn Foamies (Scratchbuilt) 31 Nov 14, 2007 11:44 PM
Perfect Plane Challenge GHarvey Sport Planes 9 Oct 24, 2001 07:27 AM
blue foam plane pics??? buckeyes1997 Foamies (Kits) 11 Jul 24, 2001 04:59 PM
Hot Batteries in Foam Plane... Aikens Foamies (Kits) 2 May 15, 2001 07:03 PM
