I think the receiver crystal is a size that's much smaller than normal.
Latest blog entry: Some stuff
Joined Jan 2009
Reading up on the thread today, I see folks are talking about the crystals. And a little light goes off in my head, THAT doesn’t happen very often!
![]() Anyways, I have a question I hope someone might have an idea about. I’ve been struggling with the tail drifting either right or left. I know I need to adjust the trim during flight, but I can never get it to stop drift either right or left. What I mean is, when the heli starts drifting left, (turning left), I give the trim a click, or two to the right, then it’s fine for a few seconds. Then it starts drifting to the right! There doesn’t seem to be any happy medium. ![]() It’s especially a nuisance when I’m practicing my nose in hovering. Which I’m terrible at to begin with! Which in turn is why I practice it so much. ![]() So my question is, could the crystal be causing this kind of problem? ![]() Also, adjusting the gyro doesn’t seem to have much of an effect. Even with this little issue, the Quark has still become my favorite heli to fly. The 180Z is collecting dust right now, and the Ufly is on the bench waiting for some new gears…again! I really need to stop backing into things with it. Mike |
It's funny - both the Quark and Blade 400 use piezoelectric elements (crystals) in their gyros (as opposed to the newer MEMS technology) and many of them act the way you describe. There are a few that don't do the drifting as much or at all, but many do and it seems no matter how much adjusting you can't get them to stay still for very long. Probably the quality of the crystals and their temperature coefficients (stability over temperature changes) used in the gyro circuitry are to blame - which are not the same as the crystals used to tune the transmitter and receiver frequencies.
I used to work at a place that made crystal oscillators. Those designs that needed to be "accurate" had to have a "heater element" included in the design in order to keep the temperature constant - a real PITA. They were large and easy to spot - and they draw a lot of current. Since there's no temperature controls or compensation in the Quark's control unit or the B400's gyro I'm not surprised they drift the way they do. Frequency "drift" is an actual term used to describe how the crystal oscillator's output frequency would change over temperature conditions. Seems fitting the term also applies to the heli's tail behavior. Sorry for the ramble - in short, the crystal that you can change on the Quark won't affect the gyro. -John
Joined Jan 2009
![]() That’s pretty much what I thought. That would be to easy. (The last part you said). ![]() Oh well, it’s really only noticeable when I’m hovering. When I’m out in the backyard, flying around, it seems to fly quite well. So I guess I’ll just learn to live with it. ![]() Mike |
I think I read in a post way back that the Berg micro crystals will work. http://www3.towerhobbies.com/cgi-bin...1p?&I=LXMAH4** |
You are correct Berg Rx crystals "which can replace" those Hirobo crystals work fine. In fact I had problems with mine and used them.
Latest blog entry: My Projects, Builds, Distractions and...
Utah
Joined Sep 2009
My quark seems to be one of the "tail drifters". It will tend to rotate CW during a flight and I have to compensate with trim.
Since I had experience with this on my Blade 400, what I do is this: Turn on the receiver. Put the tail trim slider all the way to the left. Turn on the Heli. This way I have lots of right adjustment. I tried restarting the Heli part way through the flight but it didn't help. Would be nice if I could fix the Quark the same way I fixed my Blade... With a GY401! ![]() Ciao |
Joined Jan 2009
Since no amount of trimming will correct the issue with the tail drifting from side to side, I’m considering swapping out the control unit for a Spektrum setup. I have most of what I would need, including a spare AR6100e Rx. I have a tiny HH gyro, it’s about half the size of a Telebee GR302-AD. In other words, it’s about half inch square. Can’t remember the name of it.
My problem is, I don’t know how to set up the tail motor. I know how to slave it to the main motor, but that does little good unless the tail is a variable pitch setup. And I’m not about to start messing around with that on the Quark! That’s baby!!! ![]() I’m pretty sure someone else here as done it, but I haven’t been able to find the thread. Not really sure I would do it, unless I was sure I could revert back to the original setup. Just thinking out loud… ![]() Mike |
| Thread Tools | |
| New Product FP micro heli from HIROBO | cvlex | Mini Helis | 0 | Nov 15, 2007 05:42 AM |
| Coaxial rotor indoor heli from Hirobo!!!! | totalboss | Micro Helis | 9 | Jan 17, 2007 04:07 PM |
| Zoom 400 3D: a new micro heli from Belgium | joggerke | Mini Helis | 12 | Jan 30, 2004 05:00 PM |
| FS/T HORNET FP Micro Heli and Many Parts | JoeR | Aircraft - Electric - Airplanes (FS/W) | 5 | Oct 15, 2003 07:37 PM |
| Altitude control for FP micro-heli | jeffs555 | Micro Helis | 2 | May 19, 2003 07:11 PM |
