Hey Linac, how are you doing; it's been awhile. I was referring to the location of the linkage balls on the stabilizer bar, washout assembly and seesaw, as shown in the images John posted here: http://www.rcgroups.com/forums/showp...postcount=7645. If you have maxed those settings and are comfortable with them, you ARE good. I found the response to be too fast and extreme for my tastes. It requires a much more deft touch than normal settings and can move a lot before you realize it. I can fly with this setup, but it sure isn't relaxing!
Latest blog entry: Some stuff
At first the settings were quite intimidating to me (almost like going from the mCX to the Quark) but it's okay now (and makes my mSR feel sluggish now). I would like to clarify that just because I am comfortable with max settings does not mean I am good! Thanks John.-Martin |
![]() Great hobby for us old retired dudes, eh? |
Retirement sucks! I've tried it for about 1 1/2 years and I don't like it. I've got a lot more time than money. I'm going back to work in October... for a Canadian company located in Ottawa; Data Kinetics.
wow, I find mine to be quite sensitive in the beginner settings, I would however like to diminish the see saw effect, nose up; I get the thing rocking and its a battle to settle in... maybe a little more practice will help only 6 flights so far...and two broken blades?? just when I think I am in control some crazy thing jumps in front of it!! lol
Chapel Hill, NC
Joined Apr 2009
Are you going to sell those things? It looks like an insane amount of labor for each one. Maybe just sell a kit? |
Actually - it started out as this: http://hobbyking.com/hobbyking/store...arging_harness (one of those evil parallel charging adapters) I could have bought an official JST-XH connector with wires but I would have had to order one, wait for it, etc. This was quick and dirty - just to see how everything would work. A little PC board would make for a lot less assembly work, but that would cost more too. We'll see - I just wanted to throw it out there in case someone else may be interested in doing something similar. The adapters for the 2S and 3S packs might be better suited on a PC board ... -John Update: Hey, never mind on the two 3S charger adapter - it already exists: http://hobbyking.com/hobbyking/store...S%296S_w/_XT60 |
carbon tail boom
Is this a worthy upgrade in terms of weight? How much weight difference is the aluminum versus the carbon? I installed the led kit, and wanted to do some weight reduction. Also, I noticed the new tail fain is different then the one that came with my quark. Is it the same as the SG now? Thanks.
Justin |
If I recall correctly, the CF boom will save about 1.5 grams of weight which is not significant in weight savings but will help just a bit with the relatively heavy load of the LED light kit. The CF is much stiffer than the Al boom and will hold its shape in crashes (and also looks good!). Another way I save weight sometimes is by using other lighter batteries such as the Rhino 360 or 460. Also, there has been recent discussion of better lift using the SG blades - which may also help with flight performance. There are two tail fin versions of the quark, with newer fins being 77mm and older ones being 71mm. I do not know if this is the same as the SG. Have fun! -Linac |
I have not heard of the SG blades being laminated by the Brotherhood and it may not be necessary as I also hear they are stronger than the SRB blades. Thanks. -Linac |
| Thread Tools | |
| New Product FP micro heli from HIROBO | cvlex | Mini Helis | 0 | Nov 15, 2007 05:42 AM |
| Coaxial rotor indoor heli from Hirobo!!!! | totalboss | Micro Helis | 9 | Jan 17, 2007 04:07 PM |
| Zoom 400 3D: a new micro heli from Belgium | joggerke | Mini Helis | 12 | Jan 30, 2004 05:00 PM |
| FS/T HORNET FP Micro Heli and Many Parts | JoeR | Aircraft - Electric - Airplanes (FS/W) | 5 | Oct 15, 2003 07:37 PM |
| Altitude control for FP micro-heli | jeffs555 | Micro Helis | 2 | May 19, 2003 07:11 PM |
