Old May 05, 2008, 06:51 AM
vrex is offline
Find More Posts by vrex
Denver
Joined Mar 2004
Originally Posted by oddlegs
HoverBovver ,
Yeah, but there isn't much chance of getting one cheaper, what with the euro being so bad against the or shipping/duties from the States . Thinking about one myself, if the quality is as good as claimed I could grin and bear it ....
Any idea if modelhelicopters are carrying spares ? I couldn't find them in the mass of Hirobo spares, I might have to ring them and find out ...
One thing that almost worries me is it almost sounds like this flies TOO well ...Can anyone out there tell me how it compares to say a Honeybee FP ? If it's too stable then it could be like flying a Co-ax (sort of feels like cheating) .
p.s. HoverBovver, coming from the UK you know that isn't my real picture, don't you ?
I have a HBFP the SRB is quite a bit easier to fly, but still a lot more difficult to fly then the XRB. I still haven't done nose in hovering on either the Bee or the SRB
vrex is offline Find More Posts by vrex
Old May 07, 2008, 04:51 PM
cst4252 is offline
Find More Posts by cst4252
San Francisco
Joined Jul 2004
Originally Posted by Ghia
Would these molex connectors work on the XRB also?
Hi,
The SRB connectors are 2-pin. The XRB uses a 3-pin connector because it is the same connector that the charger uses for balancing the XRB pack. If you check rickyblazerc.com he has ready made charger adapter cables and battery extension cables for the XRB.
Cheers,
Chapman
cst4252 is offline Find More Posts by cst4252
Old May 07, 2008, 05:38 PM
vrex is offline
Denver
Joined Mar 2004
Vrex, you can use the Thunder Power 730mAh Lipo with the Quark and they are selling for $29.99. You will get another 250mAH which will give you more flight time and the extra weight is only 3 grams.
Here are the Specs between the two Lipos:
Thunder Power RC Pro Lite 730mAh 7.4V 2 Cell LiPO
730 mAh
34 grams
Length: 55mm
Width: 33mm
Thickness: 9.5mm
Hirobo Stock 7.4V 2 Cell Lipo
480 mAh
31 grams
Length: 61.5mm
Width: 37.5mm
Thickness: 9.2mm
You will need to purchase some Molex connectors for plugging into the stock Quark module and to make a charger adapter. I ordered these from http://digi-key.com and these are their part #'s:
WM1850-ND connector for charging cable.
WM1841-ND male contacts for the charging cable connector.
WM1845-ND connector for Lipo
WM1837-ND female contacts for the Lipo connector.
I have everything on order but if you go to the following link Harv has tried this setup with great success.
Thanks!
For you guys in the states who want to try this, I found a company where you can buy these pieces one at a time.
http://www.mouser.com/
Here are the Mouser #'s
538-43645-0200
538-43030-0007
538-43640-0200
538-43031-0007
I bought 4 of each and it cost me $3.76 + $ 6.00 shipping.
This is from another forum but it you are interested in using other batteries for the SRB all the important info is here
Old May 08, 2008, 04:55 PM
Ghia is offline
Find More Posts by Ghia
Garland
Ghia's Avatar
USA, NM, Albuquerque
Joined Jul 2003
Thanks for the Molex info all in one spot Vrex!
I think I'll hack the SRB batt wire and use a JST connector so I can switch my TP 730 packs between SRB and XRB.
Ghia is offline Find More Posts by Ghia
Old May 11, 2008, 04:23 PM
itscschie is offline
Find More Posts by itscschie
itscschie's Avatar
Joined Feb 2006
fuselage for the quark
Hello folks,
I'm new to this forum but it is very exciting for me to read all the news about our little friend. I fly the quark for about 4 weeks and I really enjoy it. In a German forum I watched a thread about the quark and somebody posted a fuselage (Hughes 300) for the quark. So after five days I also got this one ;-)
Here are two pics. Its not yet really finished ... hope you enjoy the pics.
Greetings from sunny Neuss / Germany
Christoph
itscschie is offline Find More Posts by itscschie
Old May 12, 2008, 05:26 AM
itscschie's Avatar
Joined Feb 2006
Video
Hi folks,
I've just uploaded a little video with my Quark with the Hughes fuselage. Hope you'll enjoy it ... The kit is from e-heli-shop, not from proheli ...sorry.
S.R.B. Quark with Hughes fuselage
Greetings from Neuss, Germany
Christoph :-)
Old May 12, 2008, 09:37 PM
Nanocer is offline
Find More Posts by Nanocer
R/C Crash Test Pilot
Gloucester, Virginia
Joined Jul 2006
Chris it looks really good, now you need to dye the landing gear black.
-Will
Nanocer is offline Find More Posts by Nanocer
Old May 13, 2008, 03:14 PM
itscschie's Avatar
Joined Feb 2006
Hi Will,
thanks for your comment. What I want to buy is this one:
Scale Landing gear
Greetings,
Christoph
Old May 16, 2008, 01:37 AM
HoverBovver is offline
Find More Posts by HoverBovver
Scarecow
HoverBovver's Avatar
UK
Joined Sep 2004
Midland now listing Quark spares....
http://www.modelhelicopters.co.uk/ac...oQuark_75.html
15 for a set of foam blades!! Nearly $30 people!!
HoverBovver is offline Find More Posts by HoverBovver
Old May 16, 2008, 02:47 PM
itscschie's Avatar
Joined Feb 2006
Glue the foam blades
Hey HoverBovver,
just glue them together. I did it several times and my Quark just flies the way before. I used two-component adhesive and after just sand it and then balance it with the little balance. But only glue these little foam blade and not other blades, this works only for foam blades !!!
Have a look at the picture ... its just great, easy, simple and much cheaper
Greetings from Neuss / Germany
Christoph
Old May 16, 2008, 04:47 PM
vrex is offline
Denver
Joined Mar 2004
Two-component adhesive? Is that like expoxy?
Old May 16, 2008, 05:14 PM
Scarecow
UK
Joined Sep 2004
How many blades come in a pack? Would be ok I guess if there's 5 pairs or something.
Old May 16, 2008, 05:42 PM
vrex is offline
Denver
Joined Mar 2004
Here is a good place to buy them. Fxaeromodels is a great place to do business.
https://www.fxaeromodels.com//produc...oducts_id=4646
Old May 16, 2008, 10:48 PM
K2-tokyo is online now
Find More Posts by K2-tokyo
Tokyo Setagaya-Ku, Japan
Joined Jun 2004
Hi HoverBovver
1 main blade pack=4X2 blades ,1 tail blade pack=4 blades.
I was very surprised that almost all parts are made in Japan, and
the packs (except for blade packs) are with the seal of the
names of the persons in charge. Blade packs are made in
china! Stabilizers are made in Japan!
K2-tokyo is online now Find More Posts by K2-tokyo
Old May 17, 2008, 12:45 AM
itscschie's Avatar
Joined Feb 2006
Yes, sorry not to mention it. It is expoxy !
Greetings,
Christoph
New Product FP micro heli from HIROBO cvlex Mini Helis 0 Nov 15, 2007 05:42 AM
Coaxial rotor indoor heli from Hirobo!!!! totalboss Micro Helis 9 Jan 17, 2007 04:07 PM
Zoom 400 3D: a new micro heli from Belgium joggerke Mini Helis 12 Jan 30, 2004 05:00 PM
FS/T HORNET FP Micro Heli and Many Parts JoeR Aircraft - Electric - Airplanes (FS/W) 5 Oct 15, 2003 07:37 PM
Altitude control for FP micro-heli jeffs555 Micro Helis 2 May 19, 2003 07:11 PM
