Old Jan 11, 2009, 05:50 PM
wing1 is offline
Find More Posts by wing1
What, Me Fly?
wing1's Avatar
Lakeland, Fl
Joined Feb 2004
Dade City? I don't know....I might be able to go. I may have to ride though. I am training for a 200 mile bicycle ride.
Jim
wing1 is offline Find More Posts by wing1
Old Jan 14, 2009, 08:29 PM
DesmoHead is offline
Find More Posts by DesmoHead
DesmoHead's Avatar
USA, CT
Joined Aug 2007
Diamond D47's in Bipe
Has anyone used the D47's in the Bipe? I've run into a little problem in the lower wing. The short stringer that goes between the W1A ribs and supports the lower wing upper deck D3 doesn't seem to allow enough clearance for the aileron servo to sit in it's pocket. I think I understand that the D47's require the use of the small plywood spacers but this interference doesn't feel right. The servo stands proud of the wing about 1/8". Anyone else run into this?
-Eric
DesmoHead is offline Find More Posts by DesmoHead
Old Jan 14, 2009, 10:17 PM
jkarpy is offline
Find More Posts by jkarpy
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
-Eric
Are you using two of the plywood adapters? You may need to trim the stringer or add a shim under the plywood adapter. The D47 is a great servo, it's just a little tall.
I think I just trim the stringer.
James
jkarpy is offline Find More Posts by jkarpy
Old Jan 15, 2009, 05:52 PM
DesmoHead's Avatar
USA, CT
Joined Aug 2007
Thanks James
The gap is more than 2 shims worth. I can certainly trim/remove the stringer though. How do the HS45's fit? If they are a better fit I can always save the 47's for my 3DX.
-Eric
Old Jan 22, 2009, 10:59 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
-Eric
The HS45 requires a lot of triming.
Old Jan 26, 2009, 08:01 PM
DesmoHead's Avatar
USA, CT
Joined Aug 2007
Thanks James
Got it all sorted out I think. Pulled to covering off, trimmed the spar and recovered. Looks pretty good if I dare say so. Worth noting though if anyone plans on using the D47's.
Now all I need is some warm weather! It's 12 F here right now!
-Eric
Old Jan 28, 2009, 04:49 PM
Ducati Mechanic is online now
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
HI ERIC,
I still haven't been able to maiden mine either. The weather is horrible in CT. I built 4 new planes this winter, and I'm on my fifth. They all need there maiden. I have one cheep, profile Katana with skis that I fly in the winter.
Ducati Mechanic is online now Find More Posts by Ducati Mechanic
Old Jan 28, 2009, 09:47 PM
D.B. Hooper is offline
Find More Posts by D.B. Hooper
Flirtin With Disaster !!
D.B. Hooper's Avatar
United States, OR, Mt Angel
-Eric
Ok I'm back on track too! Got the Wb1 rib moved over where it should have been. I plan on using the AR6100 spektrum I'm hoping I won't need to extend the servo leads.
Should I run a Y for the ailerons?
Thanks to James for sending two new ribs to make the repair
D.B. Hooper is offline Find More Posts by D.B. Hooper
Old Jan 29, 2009, 10:17 AM
Joined Oct 2008
I used a Hitec mini receiver, that allows you to plug the second aileron servo into channel 5. eliminating the need for a y harness. your spectrum radio should allow the same application.
Old Jan 29, 2009, 11:07 AM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
I set my biplanes up with channel 5 also. On the spectrum radio I program for flaparons and disable the flap switch.
James
Old Jan 29, 2009, 11:10 AM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Biplane final assembly
Be sure when you mount the wing a tail section on the biplane that the tail section is mounted all the way to the end of the fuselage stick. The wing should be as far forward as possible.
James
Old Jan 30, 2009, 02:54 PM
James
Not sure I understand that?
Old Jan 31, 2009, 12:54 PM
[QUOTE=jkarpy]Be sure when you mount the wing a tail section on the biplane that the tail section is mounted all the way to the end of the fuselage stick. The wing should be as far forward as possible.
James[/QUOTE
Post #11 fig. 21 is this correct?
Finely got the Bipe together! Now if the weather will clear I have three Bipe's to maiden.
Old Jan 31, 2009, 02:58 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
[QUOTE=#1Crash Tester]
James[/QUOTE
As a minimum, if you can make it longer, the plane will fly better.
Old Feb 01, 2009, 07:04 PM
Joined Oct 2008
I had my maiden flight this morning, I still need to change a couple of things. I swaped out the motor(I cooked the old one on the bench ouch), the new motor will take a 3 cell 600mah pack. but its 1/2 the weight of the shulman fury so I need to add a little nose weight. even though she was a little tail heavy. I still ran out bolth battery packs and had 5 or 6 landings. Once this thing is dialed in its going to be awsome. It's also very fast with the dualsky xm2812ca-33 motor and 3 cell 600mah 20c pack.
Discussion micro ultrix biplane widgeteer Scratchbuilt Indoor and Micro Models 14 Jan 22, 2006 09:28 PM
Hobbico FlyZone Micro Ultrix Biplane EP RTF Dave Lauck Product Announcements 0 Jun 27, 2005 01:57 PM
Rave Micro profile biplane keven64 Foamies (Kits) 14 Feb 16, 2005 02:41 AM
Micro Ultimate Biplane video. WOW!!! Zero Six Sierra Parkflyers 3 Nov 06, 2002 04:33 PM
