Go Back   RC Groups > Vendors > Millennium R/C
Old Dec 18, 2008, 08:49 AM   #61
ducatimechanic
Bronze Member
Tim Semeraro's Avatar
Finished product
Thanks Eric, I sent you my info. I just finished my biplane. It's time to get a order together and start on my 3DX. J. Thanks, I did install the X brace, thanks for building great products.
Tim from CT.
  • Name: DSC00623.JPG
  • Name: DSC00624.JPG
Tim Semeraro is offline Find More Posts by Tim Semeraro   Reply With Quote
Old Dec 18, 2008, 07:06 PM   #62
Speed Freak
Spid's Avatar
I just finished mine. I like how it came out. I went with Transparent Red on the tops and Transparent White on teh bottoms. I also went with 1.45" DuBro Micro Sport wheels instead of the stock ones in the kit. Hopefully I can get the maiden in sometime soon, but the weather in Cleveland isn't too good this time of year to fly. Thanks for a great little kit. Here are some pics of the finished build.
~Kevin
  • Name: MicroSSX_3.jpg
  • Name: MicroSSX_4.jpg
  • Name: MicroSSX_5.jpg
Spid is offline Find More Posts by Spid   Reply With Quote
Old Dec 19, 2008, 08:43 PM   #63
Master of RC Disaster
D.B. Hooper's Avatar
Having a few problems with D2 on the top wing. The servo cut outs don't line up. Also the D47 won't fit as they bottom out. Any suggestions?
  • Name: Image001.jpg
  • Name: Image004.jpg
D.B. Hooper is offline Find More Posts by D.B. Hooper   Reply With Quote
Old Dec 19, 2008, 09:45 PM   #64
Site Sponsor
jkarpy's Avatar
Looks like the servo deck was installed backward. You should have some plywood servo adapters that raise the D47 servos up. You need two per servo. If you got the D47 servos from me, the adapters should be in the servo box. I will try and post a picture Sunday.
jkarpy is offline Find More Posts by jkarpy   Reply With Quote
Old Dec 19, 2008, 10:55 PM   #65
OK I see them now. I guess I should have put them in before attaching D1 and D2? After looking closely I did get the servo deck in backward.
I got the adapter in and the servo fits now. Is it going to cause a problem now that it's forward 1/4" ?
Old Dec 19, 2008, 11:04 PM   #66
Site Sponsor
jkarpy's Avatar
The 1/4 " should not be a problem.
Old Dec 28, 2008, 02:04 PM   #67
Ok I got the backward servo mount problem fixed
I was installing the upper wing when I noticed I have installed WB1 on the lower wing one space to the center.
The only solution I've come up with would be to beef up the W7 rib with some plywood scrap and drill new holes for the struts.
On step 31 installing the landing gear. Is the landing gear mount glued to the fuse? If so with what? My landing gear mount is louse on the fuse so CA won't hold. (epoxy?)
Step 35. I'm guessing the battery mount is glued on to the fuse and the landing gear mount?
I've put together 7 ARF's but this is my first kit build. Sorry for all the questions but.....After investing over $300 on this plane I'm not ready to give up on this build yet.
  • Name: Image071.jpg
Description: The rib WB1 should be the second rib from the wing tip. Now what???? The rib WB1 should be the second rib from the wing tip. Now what???? 29.2 KB · Views: 133
Old Dec 28, 2008, 02:13 PM   #68
ducatimechanic
Bronze Member
Its glued to the fuslage and battery mount. I used thick CA, I hope this helps.
If you have to, J sells complete wings on his web sight. I think theay are around $35.00(built). good luck.
  • Name: DSC00665.JPG
Old Dec 28, 2008, 03:20 PM   #69
Site Sponsor
jkarpy's Avatar
If you glued the plywood rib in the same spot on both wings, I think it will be ok. The battery mount is glued to the fuselage.
James
Old Dec 28, 2008, 03:43 PM   #70
James
Wish it where that easy... It's only the bottom wing. Everything else is in the right spot.
Old Dec 28, 2008, 07:21 PM   #71
Site Sponsor
jkarpy's Avatar
I can send you the plywood ribs for the bottom wing. It would not be hard to replace the whole rib.
Old Dec 28, 2008, 08:19 PM   #72
Thanks James, that may be the best bet. I'm not sure my fix would hold up.
I'll e-mail you my address at your web site.
Old Jan 11, 2009, 03:28 PM   #73
What, Me Fly?
wing1's Avatar
Send a message via Yahoo to wing1
Hey James,
I am the guy that crashed the plane at SEFF. I want you to know that I haven't ignored you or the plane. I have just built the new one and will start work on the old one soon. Look forward to seeing you at SEFF this year.
Jim
  • Name: 1231700334021.jpg
wing1 is offline Find More Posts by wing1   Reply With Quote
Old Jan 11, 2009, 06:18 PM   #74
What, Me Fly?
wing1's Avatar
Just maidened it and all I can say is wow! I am fully impressed that I could fly what I built. I have never built a kit before and this has got me hooked. Thanks again, James, for the great kit!
Jim
Old Jan 11, 2009, 06:24 PM   #75
Site Sponsor
jkarpy's Avatar
Originally Posted by wing1
Hey James,
Jim
Hi Jim, that looks great. Good to hear from you. Are you going to the FITS event this coming weekend?
James
Discussion micro ultrix biplane widgeteer Indoor and Micro Models 14 Jan 22, 2006 10:28 PM
Hobbico FlyZone Micro Ultrix Biplane EP RTF Dave Lauck Product Announcements 0 Jun 27, 2005 02:57 PM
Hangar 9 micro Ultimate biplane soars John Derstine RCSE 0 Apr 17, 2005 01:11 AM
Rave Micro profile biplane keven64 Foamies (Kits) 14 Feb 16, 2005 03:41 AM
Micro Ultimate Biplane video. WOW!!! Zero Six Sierra Parkflyers 3 Nov 06, 2002 05:33 PM
Bored? Want to fight?
Join the RCGroups clan!
