| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#46 |
East Coast Slacker
Build started
I decided to start on the bipe while waiting for the second trainer kit.
#47 | |
James |
#48 |
East Coast Slacker
I wondered what those little triangles were for.
#49 |
Just finished mine and am awaiting the first flight. Covered the top of the wings in trans red and the bottoms in trans yellow. I did not use two servos for the wings but linked the ailerons together with a new horn and a small carbon rod.
Photos in a bit but this was a great kit to build. Jay |
#50 |
do any of you have the auw of this.. we have an indoor limit of 6 oz but i think i should be able to keep it at or under there with a few modification
#51 | |
1. Pull-pull for rudder and elevator 2. 1 servo for ailerons 3. 9 gram motor from my website (Micro Indoor Power pack) 4. Move servos and electronics as far forward as possible. 5. Use blue arrow 3.6 gram servos. 6. 2 gram AR6300 receiver 7. 250 mAh 2 cell battery |
#52 |
British Biplane
I used Solite for this biplane.
#53 |
ducatimechanic
my first kit build
I was wateing to get a micro biplane, hopeing for a ARF kit. I have a little extra time On my hands due to a knee injury, so I ordered the build kit. J, is right when he says these kits are easy to build. the hardest part is covering the wings. I have done some cover repair work in the past, but this is my first complete build. I'm getting the new 3dx mini next.
#54 |
Nice looking Bipe
Time,
I'm there with you Tim! My 3DX arrived today. Gotta get building!! BTW- Your bipe looks great! What covering did you use? -Eric |
#55 | |
ducatimechanic
You got me!, I used what I had left. I only had enough light weight, yellow(coverite)to do what you see here. I had enough red(monocote) to do the whole plane one color, but what fun would that be. So the end product is what you see here.I also have found there is no way I could do this with just a iron, I have a high end heat gun that works great. thanks, Tim |
#56 | |
James |
#57 |
Looks great!
Tim,
I did mine in transparent yellow Solite. I found it easy to work with just an iron. I've never worked with monocote. I wonder is it's thicker and therefore needs more BTU's to get moving. I spent yesterday afternoon cutting the links I'm going to use to tie my ailerons together. I cut them out of black modified acrylic on a CNC router. They came out pretty good for an amateur. Cheers! -Eric |
#58 |
ducatimechanic
Eric, That sounds very cool, you might have to make me a set. the monocote is a little on the thick side, I was trying to make the lower wing a little stronger. If it's to heavy, it will give me a reason to buy a bigger motor. I am useing the schulmen fury, it's a good little motor. I used it on a couple of scratch built(my design),depron, edge 500 models. theay were so small and fast, theay were a handfull to fly. the guys at the field got a kick out of it. Thanks, Tim
#59 | |
James |
#60 |
Aileron links
Tim,
We'll see how they work. I made a bunch of 'em. If you want a set, PM me your address and I'll send you some to try. The tops have a .032 hole for a wire z-bend, the bottoms have a .063 for a quick link. I'm going to make tie rods out of carbon rod and use kevlar thread and CA to lash the wire to the carbon. I'm going for style points. If it all works, I'm going to start on a bomb release for mine ![]() -Eric |
| Thread Tools | |
| Discussion micro ultrix biplane | widgeteer | Indoor and Micro Models | 14 | Jan 22, 2006 10:28 PM |
| Hobbico FlyZone Micro Ultrix Biplane EP RTF | Dave Lauck | Product Announcements | 0 | Jun 27, 2005 02:57 PM |
| Hangar 9 micro Ultimate biplane soars | John Derstine | RCSE | 0 | Apr 17, 2005 01:11 AM |
| Rave Micro profile biplane | keven64 | Foamies (Kits) | 14 | Feb 16, 2005 03:41 AM |
| Micro Ultimate Biplane video. WOW!!! | Zero Six Sierra | Parkflyers | 3 | Nov 06, 2002 05:33 PM |
