| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#31 |
Micro SSX Biplane review
#32 | ||
Covering 101
Multi Color Covering
1. Cover the bottom of the wing first. 2. Make sure your glass is clean and smooth. 3. First, I cut the pieces of the covering. Make sure you cut the pieces with a 1/4” overlap. 4. Lay the pieces out onto the glass one at a time. Iron each piece to the glass as you move along. Do not forget the ¼” overlap. 5. Once you have all the pieces in place, turn the temperature up on the iron and seal all the seams. 6. Wait for the glass and covering to cool. 7. Peel the covering up from the glass. Do to put tension on the seams. 8. Place the covering on the wing and tack the four corners at the end ribs. Disregard the wing tips for now. 9. Tack the middle. Be sure to pull all the wrinkles out and continue tacking symmetrical points of the wing. 10. After all the wrinkles are gone, start at the center of the wing with the iron and in a sweeping motion work your way out to the last rib. Never apply pressure to the covering in the area between the ribs. Be careful to avoided applying too much heat to the seams. 11. Divide the wrinkles evenly throughout the wing tip. I then use the heat to shrink out the wrinkles. At the same time, I am pulling and stretching around the wing tip edge. I also use my fingers to brace the wing tip to prevent it from breaking. Use your thumb and index finger to grip the covering and the remaining fingers push the opposite side of the tip you are covering. If you have a hot grip glove, it helps. Ultracote Lite is best, but you should be able to get good results with Monokote. I recommend covering the model with the Ultracote Lite. Here are the stock numbers for the lite Ultracotes. Do not mistake standard transparent for lite transparent. Ultracote Lite Transparent Yellow HANU967 http://www.gravesrc.com/SearchResult...Search=HANU967 http://www.horizonhobby.com/Products...ProdID=HANU967 Ultracote Lite Transparent Blue HANU969 http://www.horizonhobby.com/Products...ProdID=HANU969 Ultracote Lite Transparent White HANU965 http://www.gravesrc.com/HANGER_9_ULT..._p/hanu965.htm http://www.horizonhobby.com/Products...ProdID=HANU965 Ultracote Lite Transparent Purple HANU968 http://www.gravesrc.com/HANGER_9_ULT..._p/hanu968.htm http://www.horizonhobby.com/Products...ProdID=HANU968 Ultracote Lite Transparent Clear HANU964 http://www.gravesrc.com/HANGER_9_ULT..._p/hanu964.htm http://www.horizonhobby.com/Products...ProdID=HANU964 Ultracote Lite Transparent RED HANU966 http://www.gravesrc.com/HANGER_9_ULT..._p/hanu966.htm http://www.horizonhobby.com/Products...ProdID=HANU966 Ultracote Lite Transparent Scale White HANU973 http://www.horizonhobby.com/Products...ProdID=HANU973 Ultracote lite can also be identified by the markings “ORALIGHT” on the backing. You can purchase these coverings from
#33 |
What, Me Fly?
Hello, I'm the one who bought and smashed my new plane at SEFF
I am so ready to take on this experience like no other. I have to keep busy. I have two planes that need to be built and one that needs to be repaired on your board. I May come up sat. afternoon with the diet beer
#34 | |
#35 |
Fly The Best
I picked up the Bipe at SEFF along with your motor. What size lipo do I need to go with?
MLT |
#36 | |
#37 | |
that little motor was rockin. Diggs |
#38 | |
#39 |
Fly The Best
Approximatley how long of a flight time would I get with the 480? Also would a 730 be too big?
MLT Last edited by MLT67; May 10, 2008 at 09:54 PM. |
#40 |
What, Me Fly?
Hey, Sorry we couldn't hook up today. Tim and I were talking about coming for a build next Sat. What do you think? Can't wait to get this thing in the air. This is a great flying machine.
Jim |
#41 | |
#42 | |
James |
#43 |
I beat Pud 3-4 days a week
Hey James, looks like you are getting some good coverage in rcsportflyer.... just found this in the SEFF supplement.... way to Go!
#44 | |
How did I miss this? What issue is it in? |
#45 |
the issue that just came in... August I believe
| Thread Tools | |
| Discussion micro ultrix biplane | widgeteer | Indoor and Micro Models | 14 | Jan 22, 2006 10:28 PM |
| Hobbico FlyZone Micro Ultrix Biplane EP RTF | Dave Lauck | Product Announcements | 0 | Jun 27, 2005 02:57 PM |
| Hangar 9 micro Ultimate biplane soars | John Derstine | RCSE | 0 | Apr 17, 2005 01:11 AM |
| Rave Micro profile biplane | keven64 | Foamies (Kits) | 14 | Feb 16, 2005 03:41 AM |
| Micro Ultimate Biplane video. WOW!!! | Zero Six Sierra | Parkflyers | 3 | Nov 06, 2002 05:33 PM |
