Go Back   RC Groups > Vendors > Millennium R/C
Old Nov 14, 2007, 07:08 PM   #1
Site Sponsor
jkarpy's Avatar
Micro SSX Biplane (Now Available)
Flying weight: Approx. 6 - 7oz. (with recommended setup) Wing Span: 21 1/2" Wing Area: 240 sq. inches Wing Loading: 3.6 oz./ sq. ft. Length: 18”
Introduction:
The MicroSSX™ Biplane Build Kit is a fun-to-fly and build classic biplane version of the popular Millennium R/C MicroSSX airplane. The MicroSSX™ Biplane has the same wing span and length as the original Micro SSX™, and is similar in that it is aerobatic and can handle the wind fairly well, but the Biplane is capable of sustaining slower flight due to its lower wing loading.
  • Name: DSC01730.jpg
  • Name: DSC01731.jpg
  • Name: DSC01732.jpg
  • Name: DSC01733.jpg
  • Name: DSC01734.jpg
  • Name: DSC01735.jpg
  • Name: DSC01736.jpg
  • Name: DSC01737.jpg
  • Name: DSC01738.jpg
  • Name: DSC01739.jpg
  • Name: DSC01740.jpg
  • Name: DSC01741.jpg
  • Name: DSC01742.jpg
  • Name: DSC01743.jpg
  • Name: DSC01744.jpg
jkarpy is offline Find More Posts by jkarpy   Reply With Quote
Old Nov 14, 2007, 07:09 PM   #2
Site Sponsor
jkarpy's Avatar
Kit
1. 1 decal set
2. 4 balsa sticks 3/32x3/32x24
3. 4 balsa sticks 1/16x3/32x24
4. 2 sheets 1/8 balsa laser cut parts
5. 2 sheets 1/16 balsa laser cut parts
6. 1 sheet 1/32 balsa laser cut parts
7. 3 sheets plywood laser cut parts
8. 6 Dubro micro control horns
9. 2 Dubro micro light wheels
10. 2 Dubro wheel retainers
11. 3 1-foot pieces of .031” piano wire for push rods, aileron linkage and tail skid
12. Preformed wire landing gear
13. 6 control horns
14. 2 micro light wheels
15. 2 micro wheel retainers
16. 15” Wrapped carbon fuselage
17. Carbon fiber struts
18. Velcro pads
19. Velcro “One Wrap” Battery strap (RED)
20. Double-stick foam tape (Used to hold speed control in position)
21. 8 # 0 - ¼ sheet metal screws (Servos & wing adjustment)
22. 2 # 1 – ¼ sheet metal screws (Motor)
Additional Items Required:
1. Cyanoacrylate or CA Glue (thin and thick)
2. Hobby knife
3. 220-grit sandpaper
4. Sanding block
5. Hinge tape (recommend 3M Scotch ™ ¾” Transparent Tape)
6. Ruler
7. Square
8. Razor saw
9. Hand drill or small drill with #56 (.046”) drill bit.
10. 1/16” drill bit.
11. Micro screwdriver set
12. Micro-receiver (recommend Castle Creations Berg)
13. Motor (recommend Hacker A10-12S brushless outrunner motor, 2900 Kv)
14. Speed control (recommend Hacker X-5, 5 amps, or equivalent)
15. Propeller (as recommended by motor manufacturer)
16. Four servos (less than 7 grams each, recommended. Ideal is 4 grams) Best choice servo is the new JR 185.
17. Battery (recommend 2-3 cell lithium polymer battery, 480-730 mAh) Please adhere to manufacturer’s safety guidelines.
  • Name: MSSXB-001.jpg
Description: This is the Micro SSX Biplane laser cut kit This is the Micro SSX Biplane laser cut kit 123.2 KB · Views: 455
Old Nov 14, 2007, 07:10 PM   #3
Site Sponsor
jkarpy's Avatar
obsolete See below
obsolete See below
Old Nov 14, 2007, 07:10 PM   #4
Site Sponsor
jkarpy's Avatar
Wing #2 (Top)
004
Old Nov 14, 2007, 07:11 PM   #5
Site Sponsor
jkarpy's Avatar
Horizontal Stab
005
  • Name: HS-001.jpg
  • Name: HS-002.jpg
  • Name: HS-003.jpg
  • Name: Hs-004.jpg
Old Nov 14, 2007, 07:12 PM   #6
Site Sponsor
jkarpy's Avatar
Vertical Stab
006
  • Name: VS-001.jpg
  • Name: VS-002.jpg
  • Name: VS-003.jpg
  • Name: VS-004.jpg
Old Nov 14, 2007, 07:12 PM   #7
Site Sponsor
jkarpy's Avatar
Rudder
007
  • Name: R-001.jpg
  • Name: R-002.jpg
  • Name: R-003.jpg
  • Name: R-004.jpg
Old Nov 14, 2007, 07:13 PM   #8
Site Sponsor
jkarpy's Avatar
Elevator
008
  • Name: E-001.jpg
  • Name: E-002.jpg
  • Name: E-003.jpg
  • Name: E-004.jpg
Old Nov 14, 2007, 07:15 PM   #9
on a vacation
willhaney's Avatar
willhaney is offline Find More Posts by willhaney   Reply With Quote
Old Nov 14, 2007, 07:17 PM   #10
Site Sponsor
jkarpy's Avatar
Instructions
Step by Step
  • Name: FIG 1.jpg
Description: Build 2 W1B ribs from W1B, W1b and W1bb. (Glue) Fig 1 Build 2 W1B ribs from W1B, W1b and W1bb. (Glue) Fig 1 78.1 KB · Views: 276
  • Name: FIG 2.jpg
Description: Build 2 W2B ribs from W2B, W2b and W2bb. (Glue) Fig 2 Build 2 W2B ribs from W2B, W2b and W2bb. (Glue) Fig 2 95.1 KB · Views: 249
  • Name: FIG 3.jpg
Description: Build 2 frames from LE, TE and W2C. (Glue) Fig 3 Build 2 frames from LE, TE and W2C. (Glue) Fig 3 70.9 KB · Views: 264
  • Name: FIG 4.jpg
Description: Install Ribs W1A, W1B, W6 and W7 and Ply wood pieces P11/P11A, P9 and P10 for the bottom wing (No Glue) Fig 4 Install Ribs W1A, W1B, W6 and W7 and Ply wood pieces P11/P11A, P9 and P10 for the bottom wing (No Glue) Fig 4 72.3 KB · Views: 282
  • Name: FIG 5.jpg
Description: Install Ribs W2A, W2B, W6 and W7 Ply wood pieces P22/P16, P9 and P10 for the top wing. (No Glue) Fig 5 Install Ribs W2A, W2B, W6 and W7 Ply wood pieces P22/P16, P9 and P10 for the top wing. (No Glue) Fig 5 88.0 KB · Views: 274
  • Name: FIG 6.jpg
Description: Install spar crutch W10 and remaining stringers. Tack glue ribs to TE. Set wings on flat surface, square all parts and glue with thin CA. Fig 6 Install spar crutch W10 and remaining stringers. Tack glue ribs to TE. Set wings on flat surface, square all parts and glue with thin CA. Fig 6 108.6 KB · Views: 281
  • Name: FIG 7.jpg
Description: Install wing tips.W8 and W9. Slice the two parts in half to install. It will be necessary to bevel W9 where it joins with W8.  (Glue) Fig 7 Install wing tips.W8 and W9. Slice the two parts in half to install. It will be necessary to bevel W9 where it joins with W8. (Glue) Fig 7 53.5 KB · Views: 244
  • Name: FIG 8.jpg
Description: Install 1/32 deck D2 on upper wing top. Figure 8 (Glue) Fig 8 Install 1/32 deck D2 on upper wing top. Figure 8 (Glue) Fig 8 55.1 KB · Views: 268
  • Name: FIG 9.jpg
Description: Install 1/32 deck D3 on lower wing top. Fig. 9 (Glue) Install 1/32 deck D3 on lower wing top. Fig. 9 (Glue) 81.6 KB · Views: 253
  • Name: FIG 10.jpg
Description: Install 1/32 deck D1 on lower wing bottom. Fig. 10 (Glue) Install 1/32 deck D1 on lower wing bottom. Fig. 10 (Glue) 109.7 KB · Views: 248
  • Name: FIG 11.jpg
Description: Build Vertical/horizontal stabilizer and rudder/elevator as shown in Fig11 and 12. (See BP-HS.WMF and BP-VS.WMF) 2 Plywood pieces “PS1” should be doubled-up to make the leading edge of the elevator. (Glue) Build Vertical/horizontal stabilizer and rudder/elevator as shown in Fig11 and 12. (See BP-HS.WMF and BP-VS.WMF) 2 Plywood pieces “PS1” should be doubled-up to make the leading edge of the elevator. (Glue) 58.7 KB · Views: 253
  • Name: FIG 12.jpg
Description: Fig 12
Bevel bottom elevator 45 °, one side of rudder and bottom of both ailerons. Remember to mirror the ailerons.
Sand smooth all surfaces with fine sand paper.
Cover wings and tail with light model covering such as Solite or World Models Lightex. Fig 12 Bevel bottom elevator 45 °, one side of rudder and bottom of both ailerons. Remember to mirror the ailerons. Sand smooth all surfaces with fine sand paper. Cover wings and tail with light model covering such as Solite or World Models Lightex. 45.7 KB · Views: 237
  • Name: Fig 13.jpg
  • Name: Fig 14.jpg
Description: Cut openings in covering. Gray areas indicate uncovered openings. Fig13, 14 and 15 Cut openings in covering. Gray areas indicate uncovered openings. Fig13, 14 and 15 50.4 KB · Views: 246
  • Name: Fig 15.jpg
Description: Fig 15
  • Name: Fig 16.jpg
Description: Assemble receiver hatch. Fig 16 H1,H2 and H3 (Glue) Assemble receiver hatch. Fig 16 H1,H2 and H3 (Glue) 63.1 KB · Views: 236
  • Name: Fig 17.jpg
Description: Assemble tail mount. Fig 17 P1 P2 and P3 (Glue) Assemble tail mount. Fig 17 P1 P2 and P3 (Glue) 64.1 KB · Views: 222
  • Name: Fig 18.jpg
Description: Build the battery mount and two servo mounts. Make sure parts are square. Fig 18 P5, P17 and P18 (Glue)
Build the battery mount and two servo mounts. Make sure parts are square. Fig 18 P5, P17 and P18 (Glue) 63.7 KB · Views: 231
  • Name: Fig 19.jpg
Description: Assemble landing gear block. Fig 19 P19 P20 and  P21 (Glue) Assemble landing gear block. Fig 19 P19 P20 and P21 (Glue) 53.8 KB · Views: 228
Old Nov 14, 2007, 07:17 PM   #11
Site Sponsor
jkarpy's Avatar
Final Assembly
Step 20
The biplane has 8- 0.060” diameter carbon struts. 4 wing struts, 2 front and 2 center cross struts.
a. Wing struts: 4.840”
b. Front struts: 2.675”
c. Center cross struts: 5.000” (May need to be trimmed during installation)
To cut the carbon rods, use a sharp Exacto knife and a rolling action.
The cross struts are installed last.
Make sure they bottom out in the slots. Also make sure each set is exactly the same length. Do not install them until all warps are ironed out of the wings and told to do so in the instructions. Set them aside for now
Step 21 Tape a length of Scotch tape™ along the rear trailing edge of the horizontal stabilizer and secure with your finger (either side is fine). Now, flip the stabilizer and place on a work surface. See diagram below:
Step 22 Now, take the elevator. You will see that the elevator has a ‘beveled’ edge. This is important in creating the hinge. Ensure that the beveled edge is pointing up, and while holding at a 45° angle, place up against the trailing edge of the horizontal stabilizer and secure the hinge tape to the elevator with your finger. See diagrams below:
Step 23 Turn the stabilizer assembly over, and carefully fold the elevator back onto the stabilizer.
Step 24 Tape another length of Scotch tape™ along the bottom hinge line and secure with your finger.
Step 25 Fold the elevator back to normal position. Test the hinge by pulling gently on the control surface. Cut off any excess tape overhanging the stabilizer sides.
Step 26 Repeat the steps 21. thru 25. for the rudder and ailerons.
Step 27 Build the servo tray. Fig 20
Step 29 (Fig 21) Slide P12A onto the fuselage stick and glue 6-1/4” from the tail end. Slide P12 onto the fuselage and leave it loose. Slide the tail mount onto the fuselage end and align it so that it is square with the flat edge of P12A. Glue it and allow the glue to dry. Secure P12 to P12A with 2 #0-1/4 screw. Do not glue P12 to P12A. Slide the servo assembly onto the front of the fuselage, align it so that it is square with the flat edge of P12A and glue it with CA glue.
Step 30 Slide the fuselage assembly through the front lower wing mount. P12 should be glued into the slot on the trailing edge of the wing. Align the wing so that it is parallel to the tail mount. Glue the tail section vertical and horizontal stabilizer together so they are square. Glue the tail assembly to the tail mount. Make sure it is parallel with the wing. Fig 22, 23 and 24
Step 31. Slide the landing gear assembly onto the fuselage. Align it parallel to all other components. It should be 2-1/32” from the front end of the fuselage. Fig 25
Step 32. Install four 4.840” carbon wing struts. Make sure struts are fully inserted into the wing before gluing with thin CA. Fig 24
Step 33. Install two 2.675” front struts. Make sure struts are fully inserted before gluing with thin CA. Fig 25
Step 34. Install upper wing, making sure struts are fully inserted into the wing before gluing with thin CA. Also install the carbon cross struts. Fig 26
Step 35. Install battery mount. Fig 27
Step 36. Install motor mount. The kit includes mounts to accommodate different motor types. Fig. 27
Step 37. Install wheels, tail skid, control horns, pushrods and radio equipment.
Step 38. The model should be balanced at the CG 1.2” back from the top wing spar. Incidence must be adjusted to “0” using the adjustable rear wing saddle P12.
Control throws: Rudder Full deflection
Elevator 20 degrees
Ailerons 20 degrees
More extreme throws can be used as desired.
  • Name: Fig 27.jpg
  • Name: Fig 28.jpg
  • Name: Fig 31.jpg
  • Name: Fig 29.jpg
  • Name: Fig 30.jpg
  • Name: FIG 32.jpg
  • Name: FIG 33.jpg
  • Name: FIG 34.jpg
Old Nov 14, 2007, 07:18 PM   #12
Site Sponsor
jkarpy's Avatar
Details
Details
  • Name: Untitled-1.jpg
  • Name: Untitled-2.jpg
  • Name: Untitled-3.jpg
  • Name: Untitled-4.jpg
Old Nov 14, 2007, 07:18 PM   #13
Site Sponsor
jkarpy's Avatar
Latest instructions and drawings
Old Nov 14, 2007, 07:19 PM   #14
Site Sponsor
jkarpy's Avatar
Reserved 005
Reserved 005
Old Nov 14, 2007, 07:20 PM   #15
Site Sponsor
jkarpy's Avatar
Reserved 006
Reserved 006
Discussion micro ultrix biplane widgeteer Indoor and Micro Models 14 Jan 22, 2006 10:28 PM
Hobbico FlyZone Micro Ultrix Biplane EP RTF Dave Lauck Product Announcements 0 Jun 27, 2005 02:57 PM
Hangar 9 micro Ultimate biplane soars John Derstine RCSE 0 Apr 17, 2005 01:11 AM
Rave Micro profile biplane keven64 Foamies (Kits) 14 Feb 16, 2005 03:41 AM
Micro Ultimate Biplane video. WOW!!! Zero Six Sierra Parkflyers 3 Nov 06, 2002 05:33 PM
Bored? Want to fight?
Join the RCGroups clan!
