Old May 11, 2008, 08:55 PM
Alvaro Silgado is offline
Find More Posts by Alvaro Silgado
Alvaro Silgado's Avatar
Madrid, Spain
Joined Sep 2004
Hi,
I'm trying to do my own EVO 2.GHz conversion with a FASST TM-7 module. I'm not an expert on electronics, but with the help of cp1 and mmormota (thank you VERY much!), I have my first schema for the adaptation. It seems this module is easier to adapt since the original Futaba radio module socket drives the module input with open collector (I don't know exactly what it means, but mmormota says so ).
Now, I have a lot of questions:
1. Is this schema correct?
2. Are the values of the resistors correct?
3. Why to lower the voltage from 9v to 6.1v (due to my resistor's values) at the transistor's base? The base is supossed to act as a trigger with ANY value, isn't it?
4. Is this schema still necessary if I use a negative shift on the EVO?
Thank you very much and sorry for too much questions.
Alvaro.
Alvaro Silgado is offline Find More Posts by Alvaro Silgado
Old May 12, 2008, 05:31 PM
Madrid, Spain
Joined Sep 2004
IT WORKED!!!
Everithing is working perfectly, even the failsafe works OK. I haven't tried it outside home, but it is suppossed to work.
Thank you very much for your help (specially, cp1 and mmormota). This solution is simple and functional.
Now, the last question: will the same schema work with more advanced modules, like TM-10 or TM-14?
Cheers,
Alvaro.
Old May 13, 2008, 08:00 AM
arocholl is online now
Find More Posts by arocholl
Electric powered
arocholl's Avatar
Spain, Community of Madrid, Madrid
Joined Sep 2005
Quick question guys: is the "trainer port" connection version working for more than 5 channels? I'm asking because as far as I know, EVO9 trainer port only controls 5 channels, but I may be wrong...
arocholl is online now Find More Posts by arocholl
Old May 13, 2008, 08:23 AM
cp1 is offline
cp1
Find More Posts by cp1
cp1
Hannover, Germany
Joined Aug 2005
The trainer port connection works for up to 8 channels, because it uses PPM format. It is not suitable for the M-10 and the M-14.
cp1 is offline Find More Posts by cp1
Old May 13, 2008, 09:37 AM
mmormota is offline
Find More Posts by mmormota
mmormota's Avatar
Budapest
Joined Jul 2003
The necessary signal for the TM10-15 is a known format? Maybe it can be done using a uC...
mmormota is offline Find More Posts by mmormota
Old May 13, 2008, 10:23 AM
Madrid, Spain
Joined Sep 2004
Hola Arocholl
Yes, it works perfectly with the 7th channel. Is the simulator cable what only works with 4 channels.
Un saludo,
Alvaro.
Old May 13, 2008, 10:42 AM
Electric powered
arocholl's Avatar
Joined Sep 2005
Originally Posted by Alvaro Silgado
Hola Arocholl
Un saludo,
Alvaro.
Hola Asilgado
Thanks for the info. I got info from some other sources that PPM output is ok till the 5th channel, but not beyond, as apparently you couldn't select "trainer" channels beyond 5th. But I never checked that. So it's nice to know that was not the case.
Gracias illo.
Ariel
Old May 13, 2008, 02:07 PM
Madrid, Spain
Joined Sep 2004
Confirmed: it also works on the 4000.
Cheers,
Alvaro.
Old Jun 07, 2008, 09:15 PM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
Hi,
Has anyone done a similar mod with the 9-12 ch versions of the modules. Maybe internal and not thru the trainer port?
chewy
chewytm is offline Find More Posts by chewytm
Old Feb 05, 2009, 09:34 AM
darkfa8 is offline
Find More Posts by darkfa8
darkfa8's Avatar
United States, NJ, Brick
Joined Jul 2005
I'm following all these Multiplex Spektrum and FASST conversion articles with great interest.
With Multiplex set to debut their 2.4 version of the EVO radios over the next few days at Nuremburg, I'm curious to see whether or not it will be or can be used with FASST or Spektrum or something proprietory.
I've been a FASST user, but am contemplating a new transmitter for heli use.
I guess the course of these threads may change after we see what Multiplex will do. Maybe they'll make conversion modules for the FM transmitters.
darkfa8 is offline Find More Posts by darkfa8
Discussion Yet Another Aero Ace/X-Twin Conversion JRuggiero Scratchbuilt Indoor and Micro Models 5 Mar 30, 2006 09:46 AM
Cool Yet another Raptor conversion kit! Ben74 Electric Heli Talk 26 Aug 12, 2005 12:05 AM
Discussion Yet another Dumas Do335 arrow conversion C. Alan Scale Kit/Scratch Built 5 Dec 30, 2004 10:40 AM
Yippee! Yet Another Floatplane Conversion: Headwind B FLYWINGFAN Parkflyers 5 Jun 19, 2004 12:08 AM
Yet Another Foamie Conversion t-turley Scratchbuilt Indoor and Micro Models 7 Apr 18, 2002 06:27 PM
