Old Nov 13, 2007, 09:42 PM
mmormota is online now
Find More Posts by mmormota
mmormota's Avatar
Budapest
Joined Jul 2003
Build Log
Yet another Evo9 2.4GHz conversion
I converted my Evo9 to FASST spreaded spectrum radio, using a T6EXA rf pcb and a PIC12F683 uC. Let the pictures tell the story...
The failsafe mode and the range check mode is controlled by the Evo, programmable in the usual way.
"I am not recommending this modification to anybody. I am only reporting what I did and how."
It is working for me, but there are possible errors in the code or the method itself. A malfuction may cause the loss of control, injury etc.
mmormota is online now Find More Posts by mmormota
Old Nov 13, 2007, 09:48 PM
mmormota's Avatar
Budapest
Joined Jul 2003
The source code:
Code:
;	|		Interface program for using the Futaba T6EX radio's		 	|
;	|		FASST Rf pcb in the Multiplex Royal Evo9 radio				|
; The Futaba FASST pcb needs a special 8 channel ppm input. The length of the 1st positive
; pulse determines if the module transmits on normal or reduced power level.
; 1st pulse:
;		420 usec: normal power
;		440 usec: reduced power, range check mode
; 2nd to 9th pulse:
;		400 usec
; The value of the 8th channel determinies the fail-safe value and mode.
; The failsafe mode means that in case of connection break the 3rd channel output gets the last
; value of the 8th channel.
; If the 8th channel value is 0,9 ms = -110% (on a -100% to +100% scale) then fail-safe is off, the 3rd channel just keeps the
; last valid value.
; This firmware made for a PIC12F683 uC. It receives the ppm signal from the Evo9 on GP2 pin5, and sends
; out the the modified pulses on GP0 pin7. (Vdd: pin1 Gnd:pin8 all other pins NC)
; The delay on receiving the pulses and sending them out is negligible, a few usecs only.
; The interface has 2 basic modes.
; Mode 1:
;	the Evo9 must be in 8 channel mode (8th channel assigned to a function, the 9th is not)
;   the interface sends out the pulses to choose the "normal power" mode.
; Mode 2:
;	The mode is programmable in the usual way using the 9th. channel. As the range check mode is critical, never
;	 program it to a normal switch. Use a pushbutton to avoid unwanted reduced power mode during normal flight.
; 	the Evo9 must be in 9 channel mode (the 9th channels assigned to a function)
;	the 9th channel tells to the interface the necessary power mode
;		range check mode:  set ch9 to 2000 usec or 90% (on a -100% to +100% scale)
;		normal power mode: set ch9 to 1000 usec or -90% (on a -100% to +100% scale)
;	the interface just receives ch9, but not sends out the 10th pulse, as the FASST pcb needs 8ch ppm
; A possible way to program the modes in the Evo9:
; In the setup menu, assign the H pushbutton to the AUX1 menu.
; In the servo menu, assign ch8 to AUX1. The is the servo/calibrate menu, turn all points to the same value (getting a horizontal line),
; this value is the fail-safe for the 3rd channel. Turn all points to -110% for fail-safe mode off.
; For range check, assign ch9 to AUX1. Turn the end points to -80% and +80%. Push and keep pushed the H button to get range-check mode.
; (the red led blinks to indicate the reduced power mode)
	list	 p=12f683
	#include P12F683.INC
	__CONFIG  _MCLRE_OFF&_CP_OFF&_WDT_OFF&_INTRC_OSC_NOCLKOUT
; Bit definitions for the GPIO register and the TRIS register
#DEFINE	no_pulse		0			; no output pulse on irq
#DEFINE	norm_power		D'420'		; 420 usec, normal power
#DEFINE	range_check		D'440'		; 440 usec, reduced power
#DEFINE	normal_pulse	D'400'		; 400 usec, normal 3...9th pulse
#DEFINE	ch9_range_min	D'1900'		; if 1900 < 9th_channel <2000 it's range check
#DEFINE	ch9_range_max	D'2050'		; if no 9th channel or the pulse is out of the above range it's normal power mode
; Macro to create offsets for variables in RAM
ByteAddr	SET	32		; user RAM starts here
BYTE		MACRO     ByteName
ByteName	EQU       ByteAddr
ByteAddr	SET       ByteAddr+1
			ENDM
;                 RAM Variable Definitions
	BYTE	mode			; bit7: the irq sends a message to the main program by clearing the bit
							;  it means, that an input pwm pulse received
    BYTE	counter			; time counter, 12usec / step
	BYTE	pulse_length	; the main program sets it, and the irq creates a pulse according to this value
	BYTE	first_pulse		; the length of the first pulse according to mode
	BYTE	startup_counter	; it counts the frames sat startup
	BYTE	delay_counter
;	|			Code start												|
	org 0x000
   	goto 	Start			; Start application beyond vector area
	org		04h
	goto	interrupt
;	|			Main program start										|
	org 8h
Start:
	nop
	nop
	nop
	nop
	BCF 	STATUS,RP0 		;Bank 0
	CLRF 	GPIO 			;Init GPIO
	MOVLW 	07h 			;Set GP<2:0> to
	MOVWF 	CMCON0 			;digital I/O
	BSF 	STATUS,RP0 		;Bank 1
	CLRF 	ANSEL 			;digital I/O
	MOVLW 	04h 			;Set GP2 as input
	MOVWF 	TRISIO 			;and set GP<5,4,3,1,0> as outputs
	bsf		OSCCON,4		;switch to 8MHz, default on startup is 4MHz
	bsf		INTCON,INTE
	bsf		GPIO,0				; 220 msec high on startup
	bsf		mode,7
	movlw	no_pulse
	movwf	pulse_length
	bcf		INTCON,INTF
	bsf		INTCON,GIE
	movlw	D'72'				; waits for several pulses before start
	movwf	startup_counter
wait_pulses:
	bsf		mode,7
wait_0:
	btfsc	mode,7
	goto	wait_0
	decfsz	startup_counter
	goto	wait_pulses
	bcf		GPIO,0				; startup pulse end
default_pulses:
	movlw	norm_power/4		; default mode setting: normal power
	movwf	first_pulse
wait_frame_gap:
	bsf		mode,7
	call	time_counter
	addlw	0ffh				; if the time_counter reaches 3ms, it comes back with 1
	bnz		wait_frame_gap		; jumps to wait_frame_gap, if the counter comes back before 3ms
	movf	first_pulse,w
	movwf	pulse_length
	bsf		mode,7
wait_1:
	btfsc	mode,7
	goto	wait_1
	movf	normal_pulse/4
	movwf	pulse_length
	bsf		mode,7
wait_2:
	btfsc	mode,7
	goto	wait_2
	movlw	normal_pulse/4
	movwf	pulse_length
	bsf		mode,7
wait_3:
	btfsc	mode,7
	goto	wait_3
	movwf	pulse_length
	bsf		mode,7
wait_4:
	btfsc	mode,7
	goto	wait_4
	movwf	pulse_length
	bsf		mode,7
wait_5:
	btfsc	mode,7
	goto	wait_5
	movwf	pulse_length
	bsf		mode,7
wait_6:
	btfsc	mode,7
	goto	wait_6
	movwf	pulse_length
	bsf		mode,7
wait_7:
	btfsc	mode,7
	goto	wait_7
	movwf	pulse_length
	bsf		mode,7
wait_8:
	btfsc	mode,7
	goto	wait_8
	movwf	pulse_length
	bsf		mode,7
wait_9:
	btfsc	mode,7
	goto	wait_9
wait_10:
	movlw	no_pulse/4
	movwf	pulse_length
	bsf		mode,7
	call	time_counter
	addlw	0ffh
	bz		default_pulses		; if no 9th channel (10th pulse) then use the default settings
	movlw	D'400'/D'12'
	addwf	counter,f			; because the counter starts at the end of the pulse
	movf	counter,w			; 1 counter step means 12 usec
	addlw	D'256'-ch9_range_min/D'12'
	bnc		default_pulses		; if the 9th channel is too short then use the default setting
	addlw	D'256'-ch9_range_max/D'12'
	bc		default_pulses		; if the 9th channel is too long, then use the default pulse setting
 	movlw	range_check/4		; settings for reduced power (range check) and failsafe on
	movwf	first_pulse
	goto	wait_frame_gap		; if the 9th channel is in the proper range,
								;  then use the above pulse settings
;	|			Interrupt												|
; Interrupt starts on positive edge of the irq input, GP2.
; The routine sends out a pulse_length long positive pulse on GP0. One step gives 4 usec.
; If pulse_length = 0 no pulse generated.
; The routine clears the mode.7 bit, it tells to the main program that irq occoured.
interrupt:
	movf	pulse_length,w
	addlw	0
	bz		nopulse
	bsf		GPIO,0		; output pulse start
irq1:
	nop
	nop
	nop
	nop
	nop
	decfsz	pulse_length
	goto	irq1
	bcf		GPIO,0		; output pulse end
nopulse:
	bcf		mode,7
	bcf		INTCON,INTF
	retfie
;	|			Time counter											|
; It's a 3 ms delay loop, if no input pulse received. In this case it returns with 1.
; If a pulse received, irq starts and clears the mode.7 bit. Then the routine returns with 0.
;  In this case the run time is stored in counter, 1 step means 12 usec.
time_counter:
	clrf	counter
tc1:
	btfss	mode,7
	retlw	0			; 0 means that it returns because of irq occoured
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	incfsz	counter
	goto	tc1
	retlw	1			; 1 means it counted up to 3ms
;	|			delay counter											|
; It's delay loop. delay = delay_counter * 10 usec.
delay_loop:
	goto	dl2
dl1:
	nop
	nop
	nop
	nop
	nop
	nop
dl2:
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	decfsz	delay_counter
	goto	dl1
	return
	end
The hex code:
Code:
:020000040000FA
:020000000828CE
:020008006D2861
:1000100000000000000000008312850107309900F5
:1000200083169F01043085000F1683120B160514EA
:10003000B2170030B4008B108B174830B600B217DF
:10004000B21B2028B60B1F2805106930B500B21767
:100050007D20FF3E031D27283508B400B217B21BD0
:100060002F28E408B400B217B21B34286430B4005F
:10007000B217B21B39286430B400B217B21B3E2845
:100080006430B400B217B21B43286430B400B21716
:10009000B21B48286430B400B217B21B4D2864303C
:1000A000B400B217B21B52286430B400B217B21BAE
:1000B00057280030B400B2177D20FF3E03192528D1
:1000C0002130B3073308623E031C25283308563E0F
:1000D000031825286E30B50027283408003E031980
:1000E0007A28051400000000000000000000B40B96
:1000F00072280510B2138B100900B301B21F00342F
:1001000000000000000000000000000000000000EF
:1001100000000000000000000000000000000000DF
:10012000000000000000B30F7E2801349D2800006D
:1001300000000000000000000000000000000000BF
:1001400000000000000000000000000000000000AF
:06015000B70B9728080020
:02400E00D43F9D
:00000001FF
Old Nov 21, 2007, 08:35 AM
pegase is offline
Find More Posts by pegase
France, IdF, Villeparisis
Joined Jul 2003
Hi mmormota,
I'am studying your source code to make something like for my FX18 radio.
Your modul seems to need positive input pulses and generate positive output pulses.
Is it exact ? I suppose it is.
I scope input signal of radio board : 3.3V peak to peak, positive pulses.
So as I only have PPM with negative pulses available I have to change input polarity of firmware. I'll try by patching bin.
Thanks mmormota to give us source and bin. This will be a great help for me.
Pegase
pegase is offline Find More Posts by pegase
Old Dec 24, 2007, 04:13 AM
coro is offline
Find More Posts by coro
Slovakia
Joined Apr 2005
Thank You very much for the great idea and sharing the code.
I have EVO9, and also I like Futaba FASST system much more than any other available.
Subscribed and really thank You.
Next step, I have to purchase RF module (is it usable with any Futaba FASST module?) and PIC, or perhaps I will rewrite Your code for some ATTiny mcu.
Merry Christmas!
coro is offline Find More Posts by coro
Old Jan 04, 2008, 06:29 PM
cp1 is offline
cp1
Find More Posts by cp1
cp1
Hannover, Germany
Joined Aug 2005
GCC code for an ATtiny25 is available on www.drivecalc.de. I made it for my son's MPX Cockpit SX. The adapter swaps channels 3 and 4 and adds a 0% signal on channel 8 for failsafe.
Christian
cp1 is offline Find More Posts by cp1
Old Jan 07, 2008, 01:26 PM
mmormota's Avatar
Budapest
Joined Jul 2003
Another version built with unmodified Evo9 , the external FASST box connected via trainer port. The radio is working with the internal 35MHz synth module too.
The firmware and the shamatics is the same, just the ppm input is limited to 3V using a series 47kOhm and a parallel white Led.
Range check and fail-safe function is working.
Old Jan 07, 2008, 09:53 PM
coro is offline
Slovakia
Joined Apr 2005
Thank You very much for writing and sharing GCC source code, it saves a lot of time.
External module using trainer port is excellent idea.
Old Jan 08, 2008, 06:18 AM
cp1 is offline
cp1
cp1
Hannover, Germany
Joined Aug 2005
Hi coro,
you're welcome. Are you going to use a Cockpit SX? Otherwise, if there is no need to swap channels, you could use much simpler code. PM me your address, if you want to receive that simpler version.
Christian
Old Jan 08, 2008, 05:13 PM
cp1 is offline
cp1
cp1
Hannover, Germany
Joined Aug 2005
I have posted a new software version today, featuring true 16 bit resolution.
Old Jan 17, 2008, 04:52 PM
coro is offline
Slovakia
Joined Apr 2005
Dear Christian, no, than You, I have no FASST module yet. I am using and I will be upgrading MPX Royal Evo 9. Not right now..
I have stopped thinking about new transmitter purchase, and I am glad that I found this sollution. I will look into Your code, as well as mmormota code, further, once I get ready.
And thank You for 16-bit version as well.
Old Jan 17, 2008, 06:50 PM
cp1 is offline
cp1
cp1
Hannover, Germany
Joined Aug 2005
Hi Coro,
for the Evo 9 you could use the code I have made for my Evo 12. Just PM me if want to receive it.
Christian
Old Jan 19, 2008, 06:56 AM
mmormota's Avatar
Budapest
Joined Jul 2003
Warning
The additional box version becames ZEROID.
It's possible reason, that sometimes the FASST panel didn't boot up properly (I mean the LED's keep blinking). The owner in order to test it, many times switched on and off the radio. It happened before the ZEROID issue surfaced in this forum.
The built-in pcb works without issues, and boot up properly without a single exception. The same the situation, if the additional box version is switched on with RF tilt (pushing the wrench button...).
The cause of the boot up issue is that the radio communicates first with the internal synth module. It takes some time, and during this time no proper ppm signal is generated for the FASST pcb input. The late start of the ppm signal causes that sometimes that the FASST panel just keeps blinking.
Old Jan 19, 2008, 01:11 PM
cp1 is offline
cp1
cp1
Hannover, Germany
Joined Aug 2005
At this time there are 4 external moduls in our club, all driven by my ATtiny code, and we have checked them for the zero ID issue, of course. So far, there is no evidence.
mmormota, how do you identify a zero ID transmitter modul? You cannot read the ID, can you? The only way that I know of is by trying to connect to someone else's RX. If that person also has a zero ID TX, you will be able to take over the control. If you have a zero ID module, how can you be sure it had an ID when you purchased it?
By the way, I still have to see the boot up issue you are talking about. Ever since I am using code that produces accurate timing, the LEDs never kept blinking.
Old Jan 19, 2008, 01:46 PM
mmormota's Avatar
Budapest
Joined Jul 2003
Most probally the reason was the test, not the modification. During the test, the radio was many times rapidly switched on/off to check if it starts properly. That time the ZGUID problem was not surfaced, so we didn§t know that this is dangerous.
A brand new receiver is working with the radio without binding.
Old Jan 29, 2008, 01:31 PM
cp1 is offline
cp1
cp1
Hannover, Germany
Joined Aug 2005
Today I have posted another software version for transmitters that do not need channel swapping, like the MPX Evo. It features latency free transmission, since without swapping there is no need to record and replay the signals. Nevertheless it also adds the motor off signal on channel 8 for the failsafe function, and in case the PPM stream carries less than 7 channels, it amends the missing channels on neutral servo positions.
Christian
Discussion Yet Another Aero Ace/X-Twin Conversion JRuggiero Scratchbuilt Indoor and Micro Models 5 Mar 30, 2006 08:46 AM
Cool Yet another Raptor conversion kit! Ben74 Electric Heli Talk 26 Aug 11, 2005 11:05 PM
Discussion Yet another Dumas Do335 arrow conversion C. Alan Scale Kit/Scratch Built 5 Dec 30, 2004 09:40 AM
Yippee! Yet Another Floatplane Conversion: Headwind B FLYWINGFAN Parkflyers 5 Jun 18, 2004 11:08 PM
Yet Another Foamie Conversion t-turley Scratchbuilt Indoor and Micro Models 7 Apr 18, 2002 05:27 PM
