Old Nov 12, 2007, 10:32 PM
jijohans is offline
Find More Posts by jijohans
ROV Pilot
jijohans's Avatar
Norway
Joined May 2002
Hacker B50-6S vs B50-5M FAI?
Is the carbon motor worth the extra cost?
Does any body have prop data for thoose two motors?
jijohans is offline Find More Posts by jijohans
Old Nov 12, 2007, 11:14 PM
skyzking is offline
Find More Posts by skyzking
smokin electrons...
skyzking's Avatar
Brisbane, Australia
Joined Jan 2007
Hacker is very good in keeping data about their FAI motors. Ive tried to find data on amps and prop before on those carbon case motors but had no success. I hope you can come across something. But one thing i know is that the carbon case ones can stand more amps i think, but then again that may not be the case.
skyzking is offline Find More Posts by skyzking
Old Nov 13, 2007, 01:18 PM
Mike Seale is offline
Find More Posts by Mike Seale
f5b-uk
Mike Seale's Avatar
United Kingdom, Dorset
Joined May 2002
Unfortunately the Hacker website is useless for direct links, and where I'm sending you does not have data for the medium can motors. Click here then the image of the white model (Antriebsbeispiele), then the black motor (wettbewerbe), then scroll right down to the B50 carbon motors and click Drehzahltabelle. I think this is as much data as you'll get from the web. I'd suggest you email Hacker to get data on the B50 5M.
As for whether the carbon motor is worth it...well, you can't get a 5M in anything other than a carbon case. So if you need the lower resistance, lower kv (I'm guessing here) and higher torque of the 5M compared to the 6S, then yes, it's worth every penny. If you are not competing you might as well save the money and buy a prop to suit the 6S.
Mike Seale is offline Find More Posts by Mike Seale
Old Nov 13, 2007, 08:56 PM
jijohans is offline
ROV Pilot
jijohans's Avatar
Norway
Joined May 2002
Did find some info in the 2007 PDF catalog, page 30-31.
Will send Hacker a email about the 5M motor...
Old Nov 15, 2007, 05:37 AM
C-MIC is offline
Find More Posts by C-MIC
Hong Kong
Joined Apr 2003
[QUOTE=jijohans]Is the carbon motor worth the extra cost?
Does any body have prop data for thoose two motors?[/QUOTE
Jijohans,
Can't tell if the carbon case is worth for extra cost or not.
But I have a 5M and ran it with a 17x18rfm blades on rfm's 36mm /6mm/7+deg. With 3s2p Conxell , thrust from it is big enough to launch without run. It is faster than a Pletti 220-30-A1P6+7:1, probably due to the higher kv of 5M. (kV=5850 as printed on the label), and I was informed by a decent F5B UK competitor that it has a rotor length in between the stocked L and S motors, the case is same as L motors--60mm.
Such a good set up was ruinned by serious glitches from an infamous xx-125 US made esc at low att. total loss in a power up....it then went back Germany fty....the bill say changes of pgb, back plate...etc,.
It is now sitting on the shelf. The Io is some 9A now, slightly higher than from NIB.
Hope my reply helps.Pls tell us more from your request to Hacker fty.
David
C-MIC is offline Find More Posts by C-MIC
Old Nov 15, 2007, 06:00 AM
jijohans is offline
ROV Pilot
jijohans's Avatar
Norway
Joined May 2002
Oki.. Have sent a email to Hacker but no respones yet..
Was thinking of 15x10 -15x15 on the 5M...
Old Nov 15, 2007, 02:48 PM
David H is offline
Find More Posts by David H
Joined Aug 2004
On the B50-6s with 3S lipos 2170 Flight power it turn an aeronaut 15x10 at 7500RPM at 106Amps. Withe larger cells you could swing a bigger prop at more current. The slightly lower Kv of the 5M will be a bit less.
David H is offline Find More Posts by David H
Aveox 36/15/1 vs. Hacker B50 6s on 10 cells down_shift High Performance 24 May 30, 2004 11:35 PM
FS: Hacker B50 6S 6.7:1 Unused Atindra Aircraft - Electric - Airplanes (FS/W) 1 Jun 11, 2003 10:51 PM
Hacker B50-15XL vs 16XL revisited Steph280 Electric Heli Talk 8 May 03, 2003 10:46 PM
Hacker B50-15XL vs 16XL on Rapp-E Steph280 Electric Heli Talk 17 Apr 08, 2003 05:54 AM
Hacker B50 9S vs B50 6L Yogi Power Systems 2 Feb 03, 2003 03:35 PM
