Old Dec 13, 2002, 11:34 AM
rcman is offline
Find More Posts by rcman
rcman's Avatar
Logan, Utah, United States
Joined May 2002
Electrifly C-20 ESC with more then 2 servos help
I would like to know if anyone as used this ESC with more then the recomanded 2 servos I have a plane that needs 4 servos
Will this ESC work
Rcman
rcman is offline Find More Posts by rcman
Old Dec 13, 2002, 11:49 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Yep
I used 4-9gram servos in my Miniflash. The Miniflash did have a special provision for this that I liked. It had you slip the ESC out the bottom of the fuse - so it was hanging in the air so to speak. All this was with 8 cells as well.
I too was woried about this so I tested on the ground quite a bit before my first flights. It got warm, but not too bad. I figured that it would be fine so long as it had proper cooling. No issues to date.
